Home » Modeling » EMF » CDATA appearing in xsd:any data
CDATA appearing in xsd:any data [message #1385978] Thu, 12 June 2014 15:09 Go to next message
Rob Mising name is currently offline Rob Mising nameFriend
Hi Ed,
I have stumbled accross something a little strange that I would really appreciate your input on.
I have a schema as follows:
<xs:element name="person">
	<xs:complexType>
		<xs:sequence>
			<xs:element name="firstname" type="xs:string"/>
			<xs:element name="lastname" type="xs:string"/>
			<xs:any processContents="lax" minOccurs="0" maxOccurs="5" ecore:name="customAny"/>
		</xs:sequence>
	</xs:complexType>
</xs:element>
Then if I do something like:
Car createCar = ElmAndComplexFactory.eINSTANCE.createCar();
createCar.setColour("red");
// Now create the Complex object with the any
personType createpersonType = SimpleAnyNamedFactory.eINSTANCE.createpersonType();
createpersonType.setFirstname("Betty");
createpersonType.setLastname("Rubble");
createpersonType.setCustomAny(createCar);
String s = serialize(createpersonType);
// Remove from the package reg for the value we are putting into the xsd:any
// Need to first save off the entry - we will add it later
String regKey = ElmAndComplexFactory.eINSTANCE.getEPackage().getNsURI();
OSGiEnabledPackageRegistry.INSTANCE.remove(regKey);
personType personType2 = (personType) deserialize(s);
s = serialize(personType2);
System.out.println(s);
It's a bit contrived in this example - our case is a bit more complicated, the key bit is once we have it in an XML format we then make sure the type in the "xsd:any" is no longer in the EMF Registry. The serialise/deserialise methods just do a save/load on the resource. When sysout is done it will print:
<named:person xmlns:ElmAndComplex="http://example.com/ElmAndComplex" xmlns:named="http://example.com/SimpleAnyNamed">
  <firstname>Betty</firstname>
  <lastname>Rubble</lastname>
  <ElmAndComplex:myCarElement>
    <colour>red</colour>
  </ElmAndComplex:myCarElement>
</named:person>
This is all good, but if we now set the following option to "true":
XMLResource.OPTION_ESCAPE_USING_CDATA
Then we get the following XML:
  <ElmAndComplex:myCarElement><![CDATA[
    ]]><colour>red</colour><![CDATA[
  ]]></ElmAndComplex:myCarElement>
</named:person>
The problem is "<![CDATA[" values which appear where there is any white space in the XML - it is a bit like it is treating the xsd:any as a string, and hence escaping it.
Any thoughts you have would be appreciated.
Rob
Re: CDATA appearing in xsd:any data [message #1386031 is a reply to message #1385978] Fri, 13 June 2014 06:46 Go to previous messageGo to next message
Comments below.
On 12/06/2014 5:09 PM, Rob Mising name wrote:
> Hi Ed,
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> xsd:any
I have no idea what this means, but it sounds bad.
I don't understand this statement or why you'd do it...
> </named:person>
> </named:person>
So likely this comes down to having windows line feeds in your data.
But I have no idea how you built the instance...
> Thanks
> Rob
Re: CDATA appearing in xsd:any data [message #1386079 is a reply to message #1386031] Fri, 13 June 2014 11:14 Go to previous message
OK, I have looked a little further into this, it appears that whenever data is stored into an "xsd:any" it assumes that it is "mixed xml" - this means that it always believes that it should print it exactly as the input data. When mixed isn't supported for the XML added to the xsd:any, then this isn't normally a problem as it would just be white space - which will be ignored within the generated XML.
However, when you set EMF to add CDATA to everything - then it will detect this white-space between elements - and add a CDATA around it. (Which may not be valid if the original schema for the object stored into the xsd:any did not support mixed)
I have managed to work around this by editing XMLSaveImpl in the method saveElementFeatureMap, so that in the if for "MLTypePackage.Literals.XML_TYPE_DOCUMENT_ROOT__TEXT" we now have:
if (entryFeature == XMLTypePackage.Literals.XML_TYPE_DOCUMENT_ROOT__TEXT)
	String svalue = value.toString();
	if (escape != null)
		boolean convertTxt = true;
		// CHANGE START
		// This could be done in a single line, but it is quite hard to
		// work out the rules when viewed this way, so I have split it
		// into several lines
		if (usingCData)
			if ((o instanceof AnyType) && (f instanceof EAttribute))
				if (svalue.trim().length() == 0)
					convertTxt = false;
		// CHANGE END
		if( convertTxt )
			svalue = escape.convertText(svalue);
	if (!toDOM)
		doc.addText(svalue);
	else
		Node text = document.createTextNode(svalue);
		currentNode.appendChild(text);
		handler.recordValues(text, o, f, entry);
The "usingCData" variable is the value read out of the passed in options to "init".
Previous Topic:[CDO] Advice on best approach to replacing model content
Next Topic:CDO and trasient feature
Current Time: Mon Feb 17 22:04:06 GMT 2020
Powered by FUDForum. Page generated in 0.02175 seconds
