[EMF] Localized feature description in EObjectValidator messages [message #1385816] |
Wed, 11 June 2014 11:48 |
Leonid Ripeynih Messages: 150 Registered: February 2012 |
Hi all!
I'd like to know, how can I get localized feature descriptions in default EObjectValidator diagnistics?
For now, that's what I observe:
1. EObjectValidator uses SubstitutionLabelProvider to get feature label.
2. Diagnostician provides such an interface by itself, unfortunately delegating directly to eStructuralFeature.getName().
3. There is an existing method in org.eclipse.emf.edit.provider.ItemProviderAdapter.getFeatureText(Object) which can get a nice feature description, but unfortunately it's not API.
Since org.eclipse.emf.edit.ui.action.ValidateAction already uses .Edit framework to obtain a resource set, (and moreover, it creates it's own diagnostician), it would make sense to obtain some sort of an Adapter from it's AdapterFactory, to delegate to it to get a lozalized feature label?
For now, i did amost the same thing, except for obtaining IItemLabelProvider as an adapter, and using reflection to call to getFeatureLabel(), and it works.
I wonder,
a) if it's the best (easiest) method of doing it
b) should't such a capability being provided by framework? If so, i could provide a patch.
Re: [EMF] Localized feature description in EObjectValidator messages [message #1385861 is a reply to message #1385816] |
Wed, 11 June 2014 17:24 |
Ed Merks Messages: 33133 Registered: July 2009 |
There's quite an old bugzilla about this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=309019
It would be nice for there to be API for it, so I'd be interested to see
your suggestion.
On 11/06/2014 1:48 PM, Leonid Ripeynih wrote:
> Hi all!
> delegating directly to eStructuralFeature.getName(). 3. There is an
> existing method in
> label?
> I wonder, a) if it's the best (easiest) method of doing it
Ed Merks
FUDForum. Page generated in 0.01585 seconds
