Re: Calling eInstance on RCP fails [message #1385760 is a reply to message #1385718] |
Wed, 11 June 2014 05:31 |
Ed Merks Messages: 33140 Registered: July 2009 |
Anduril,
It's impossible to diagnose the problem from your short description.
Note that you can remote debug an application. I.e., put lines like
this in your application's *.ini
-Xdebug
-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8123
And attach to the process. You can set suspend=y to stop the process
very early (immediately) to see initialization, i.e., it doesn't really
start until you attach the debugger.
Most likely you've not included something in the build.properties for
binary bundles that are needed at runtime.
On 10/06/2014 6:49 PM, anduril elendil wrote:
> I am working on an Eclipse e4 application and use a generated emf
> model. As long as I work under Eclipse directly from source there is
> no problem. But as far as I export my RCP and call MyFactory.eInstance
> nothing is going to happen. The factory isn't null, the code execution
> of this method just stops. The program itself doesn't hang up but as a
> result, all the button and menu items are disabled. I guess it is a
> dependency problem but there are no error logs or the like. So I have
> no idea what to do.
> Greetings
Ed Merks
FUDForum. Page generated in 0.04095 seconds
