Home » Language IDEs » Java Development Tools (JDT) » Java8 Nullness question: annotation is not applicable at this location(After I upgraded my project to Java8, I started getting new errors)
icon5.gif  Java8 Nullness question: annotation is not applicable at this location [message #1385672] Tue, 10 June 2014 08:16 Go to next message
Hi everyone,
First of all, if this is not the correct forum, please feel free to move the topic and/or let me know where I should post these questions.
I have recently upgraded my projects to Java8 and starting using the new and better type qualifiers. I am using Eclipse Standard / SDK Luna RC3 Release (4.4.0RC3) with the new annotations package (org.eclipse.jdt.annotation 2.0.0).
Below are some new errors/warning I get with this upgrade in my projects. I have tried my best to reduce the examples into minimal working code examples. If you need more details or the actual projects (to test is easier), please let me know.
1.
package "nullness" has the following package-info.java:
@org.eclipse.jdt.annotation.NonNullByDefault
package nullness;
"Generics.java":
package nullness;
public abstract class Generics<Ex extends Throwable>
    protected abstract void compute() throws Ex;
Here, on line
, I get the following error for "Ex":
Nullness annotations are not applicable at this location
I think they are related to generics I use (e.g., Ex) since if I change the code to:
package nullness;
    protected abstract void compute() throws Exception;
the error disappears.
I could not understand what the error means (to be honest it is rather vague). Does anyone have an idea what is causing the error and how I can fix it?
Thanks and best regards,
Re: Java8 Nullness question: annotation is not applicable at this location [message #1385675 is a reply to message #1385672] Tue, 10 June 2014 08:52 Go to previous messageGo to next message
This looks like a bug, which is probably caused by a bad interaction between two factors:
  • @NonNullByDefault now affects more locations (tunable by its 'value' attribute)
  • types in a throws clause cannot be marked as nullable or nonnull (is nonnull by construction)
Please file a bug against JDT/Core with your examples and I will take a look.
As for a workaround: you may want to try adding this to method compute():
@NonNullByDefault({})
Regarding details of null type annotations, please see this new section in the help (temporary location): http://help.eclipse.org/staging/luna/topic/org.eclipse.jdt.doc.user/tasks/task-using_null_type_annotations.htm?cp=1_3_9_1
(or search for "null type annotations" in the online help since 4.4 RC4).
Stephan
Re: Java8 Nullness question: annotation is not applicable at this location [message #1385677 is a reply to message #1385675] Tue, 10 June 2014 09:05 Go to previous messageGo to next message
I have written a longer reply, but for some reason the form decided to switch to "tree view" rather than posting my reply.
Thanks for the workaround, it works with one caveat:
The following code gives the same exception:
package nullness;
import org.eclipse.jdt.annotation.NonNullByDefault;
The following code works:
package nullness;
I generally don't like raising the level of the annotations is that is not necessary, not sure whether it is a problem in this case.
I will create a bug report with my working example soon. Again, thanks for the help!
Re: Java8 Nullness question: annotation is not applicable at this location [message #1385681 is a reply to message #1385677] Tue, 10 June 2014 09:15 Go to previous messageGo to next message
What you write let's me infer what the compiler is doing internally:
The nullness default expands "Ex extends Throwable" to "Ex extends @NonNull Throwable", good.
When analysing "throws Ex" the compiler sees that "Ex" is a nonnull type, OK.
It concludes that "Ex" has an explicit, illegal @NonNull annotation, wrong.
You may fine tune the workaround by excluding only one element from the nullness default: TYPE_BOUND, to make the declaration at class level:
@NonNullByDefault({ PARAMETER, RETURN_TYPE, FIELD, TYPE_ARGUMENT })
(hope it works, haven't tried ...)
Still only a workaround, but less drastic than your variant.
best,
Stephan
Re: Java8 Nullness question: annotation is not applicable at this location [message #1385682 is a reply to message #1385677] Tue, 10 June 2014 09:18 Go to previous message
Stephan, I have just created the bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=437050
Previous Topic:Connecting to SQL Server
Next Topic:System property Problem
Current Time: Sat Nov 08 17:35:01 EST 2025
Powered by FUDForum. Page generated in 0.04431 seconds
