Home » Eclipse Projects » Remote Application Platform (RAP) » Error: object doesn't support property or method 'attachevent'
Error: object doesn't support property or method 'attachevent' [message #1385612] Tue, 10 June 2014 03:08 Go to next message
Tomas Normark is currently offline Tomas NormarkFriend
I want to run an Eclipse RAP application integrated in a Windows Presentation Foundation (WPF) application that we have. To do that I use the WPF browser widget which is just Internet Explorer 11 running in a widget in WPF.
However when I set the URL of the web browser widget to load the application I get the error:
When searching for this I see that support for attachevent has been removed in Internet Explorer 11 and that addEventListener should be used instead.
When running the application directly in an Internet Explorer 11 web browser it works fine.
Does anyone know what might be going on here? Is there some code in RAP that tries to detect the IE version to account for the removed attachevent method that might fail when running IE11 in the WPF browser widget?
Tomas Normark
Re: Error: object doesn't support property or method 'attachevent' [message #1385664 is a reply to message #1385612] Tue, 10 June 2014 10:56 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Tomas,
when using IE in a browser control (SWT Browser widget or other), it
does not run in "standard" mode or it is not identified as IE11. Please
load http://www.useragentstring.com/ in your WPF browser widget and post
here the result.
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Error: object doesn't support property or method 'attachevent' [message #1385688 is a reply to message #1385664] Tue, 10 June 2014 13:46 Go to previous messageGo to next message
Hi Ivan,
This is the user agent string that I get:
Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; Win64; x64; Trident/7.0; .NET CLR 2.0.50727; SLCC2; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E; InfoPath.3)
It appears to identify itself as an IE7 browser when running in the WPF widget. On the other hand if I run the URL you recommended in a standalone IE11 I get:
Mozilla/5.0 (Windows NT 6.1; WOW64; Trident/7.0; rv:11.0) like Gecko
Do you have any recommendations about how to proceed considering this information?
Tomas Normark
Re: Error: object doesn't support property or method 'attachevent' [message #1385765 is a reply to message #1385688] Wed, 11 June 2014 06:18 Go to previous message
I managed to solve this now by adding a registry key to force IE to run as IE11 in the WPF browser widget as described on this page:
http://weblog.west-wind.com/posts/2011/May/21/Web-Browser-Control-Specifying-the-IE-Version
Thanks for your hints in looking into the user agent string Ivan.
Tomas Normark
Previous Topic:[RAP] [E4] UIThreadTerminatedError in LoginLifecycle
Next Topic:[RAP] [E4] How to disable MinMax-Icons/Functionality
Current Time: Sat May 30 06:37:16 GMT 2020
Powered by FUDForum. Page generated in 0.02448 seconds
