Re: Fixed layout [message #1385146 is a reply to message #1385127] |
Wed, 04 June 2014 15:06 |
Le 04/06/2014 15:27, Ignacio Arechaga Fernandez a écrit :
> Hi all,
> I have described a layout for an element, but I cannot manage to define the layout as the default layout for all the element mappings.
> In particular, I have this node with some bordered nodes. I have arranged them like this :
> But when I have a new instance of that element, the layout of the newer element is different :
> How can I set a layout as the default one?
> Many thanks
If it the new diagram elements points to the same semantic elements, you
can try the copy layout / paste layout actions (available from the
tabbar and the contextual menu).
Else you will have to look into the GMF/Sirius layout extension points,
you might have to develop a new layout adapted to your domain.
Maxime
Maxime Porhel - Obeo
FUDForum. Page generated in 0.03891 seconds
