Home » Newcomers » Newcomers » Programs won't run -Ant Build Window to select build
Programs won't run -Ant Build Window to select build [message #1385049] Wed, 04 June 2014 01:19 Go to next message
Samuel Davis is currently offline Samuel DavisFriend
I cannot run any programs. Every time I press run I am taken immediately to a window which demands that I select from 2 choices: 1) ant build and 2) ant build... . When I make the selection an error messages tells me that the run fails because their is no build files. Also, my past projects are not lined up in explorer pane. When I open a program it opens in the workbench, but not listed in the explorer pane.Sad
[Updated on: Wed, 04 June 2014 21:25]
Report message to a moderator
Re: Programs won't run -Ant Build Window to select build [message #1385438 is a reply to message #1385049] Fri, 06 June 2014 12:40 Go to previous messageGo to next message
Brett Olsen is currently offline Brett OlsenFriend
I am having the same issue. Some help would be great!
Re: Programs won't run -Ant Build Window to select build [message #1385523 is a reply to message #1385438] Sun, 08 June 2014 16:15 Go to previous message
Jaroslav K. is currently offline Jaroslav K.Friend
have you tried to create a new Workspace and import one of your projects to that Workspace?
Previous Topic:Eclipse 4.3.2 closes the first access in ubuntu 14:04
Next Topic:No Java virtual machine found
Current Time: Mon Jun 14 10:15:48 GMT 2021
Powered by FUDForum. Page generated in 0.03194 seconds
