Question about incompatibilities [message #1384985] |
Tue, 03 June 2014 13:16 |
Ignacio Arechaga Fernandez Messages: 14 Registered: May 2014 Location: Madrid |
Hi all,
I'm using Sirius to create a proof of concept to see if Sirius fits in to build a new editor for our application.
I am using the latest version (nightly) of Sirius and Eclipse Luna.
Once the editor is built, I have to include it in our main project.
The problem is that the project is being done under Eclipse Helios.
Will this be a problem even if Sirius is used to build the editor in Eclipse Luna?
Kind regards,
Ignacio
[Updated on: Tue, 03 June 2014 13:16] Report message to a moderator
Re: Question about incompatibilities [message #1385002 is a reply to message #1384985] |
Tue, 03 June 2014 14:31 |
Le 03/06/2014 15:16, Ignacio Arechaga Fernandez a écrit :
> Hi all,
As mentioned in [1] and [2], Sirius is not supposed to be compatible
with Eclipse Helios (3.6). If you try to deploy the editor in Helios,
you might give us some feedback with the identified issues to see if
there are only minor modifications to be compatible.
> Eclipse Luna?
If your targeted environment is different from your development
environmment, you might look into target platforms [3]
> Kind regards,
> Ignacio
Maxime
[1]
https://wiki.eclipse.org/Sirius/Compatibility_and_Migration#Supported_Platforms
[2] https://wiki.eclipse.org/Sirius/1.0.0M7#Compatibility
[3]
http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.pde.doc.user%2Fconcepts%2Ftarget.htm
Maxime Porhel - Obeo
FUDForum. Page generated in 0.02849 seconds
