java.lang.RuntimeException: No application id has been found. [message #1384864] |
Mon, 02 June 2014 15:57 |
Tim Schwalbe Messages: 27 Registered: May 2014 |
Hey guys,
after adding a Webservice Provider I get an error. I can´t solve it on my own.
The error is still there after deleting the webservice provider.
!SESSION 2014-06-02 17:54:04.085 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_60
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product de.mind.conversation.ui.swing.product
Command-line arguments: -product de.mind.conversation.ui.swing.product -data C:\Users\tschwalbe\workspaceScout/../runtime-conversation-swing-client-dev.product -dev file:C:/Users/tschwalbe/workspaceScout/.metadata/.plugins/org.eclipse.pde.core/conversation-swing-client-dev.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.app 0 0 2014-06-02 17:54:11.156
!MESSAGE Product de.mind.conversation.ui.swing.product could not be found.
!ENTRY org.eclipse.osgi 2 0 2014-06-02 17:54:11.297
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-06-02 17:54:11.298
!MESSAGE Bundle update@../../../Users/tschwalbe/workspaceScout/de.mind.conversation.client/ was not resolved.
!SUBENTRY 2 de.mind.conversation.client 2 0 2014-06-02 17:54:11.299
!MESSAGE Missing imported package de.mind.conversation.server.services.ws.consumer_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2014-06-02 17:54:11.349
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-06-02 17:54:11.350
!MESSAGE Bundle de.mind.conversation.ui.swing_1.0.0.qualifier [53] was not resolved.
!SUBENTRY 2 de.mind.conversation.ui.swing 2 0 2014-06-02 17:54:11.351
!MESSAGE Missing required bundle de.mind.conversation.client_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-06-02 17:54:11.351
!MESSAGE Bundle de.mind.conversation.client_1.0.0.qualifier [55] was not resolved.
!SUBENTRY 2 de.mind.conversation.client 2 0 2014-06-02 17:54:11.352
!ENTRY org.eclipse.osgi 2 0 2014-06-02 17:54:11.461
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-06-02 17:54:11.461
!SUBENTRY 2 de.mind.conversation.client 2 0 2014-06-02 17:54:11.463
!ENTRY org.eclipse.osgi 2 0 2014-06-02 17:54:11.488
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-06-02 17:54:11.488
!SUBENTRY 2 de.mind.conversation.ui.swing 2 0 2014-06-02 17:54:11.489
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-06-02 17:54:11.490
!SUBENTRY 2 de.mind.conversation.client 2 0 2014-06-02 17:54:11.491
!ENTRY org.eclipse.osgi 4 0 2014-06-02 17:54:11.510
!MESSAGE Application error
!STACK 1
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
[Updated on: Mon, 02 June 2014 16:12] Report message to a moderator
Re: java.lang.RuntimeException: No application id has been found. [message #1384952 is a reply to message #1384878] |
Tue, 03 June 2014 09:30 |
Thanks a lot, now it works to provide a Webservice and I tested it successfull wih SoapUI.
but when I want to use the service in the load-Method similar to the tutorial another failure appears.
public PtrTool0FormData load(PtrTool0FormData formData) throws ProcessingException {
if (!ACCESS.check(new ReadPtrTool0Permission())) {
throw new VetoException(TEXTS.get("AuthorizationFailed"));
System.out.println("LOADED!!!");
PrintTemplateWebServiceClient service = SERVICES.getService(PrintTemplateWebServiceClient.class);
PrintTemplateWebServicePortType portType = service.getPortType();
portType.getFilledTemplate("aha");
System.out.println("Loaded over!");
return formData;
Failure:
!ENTRY org.eclipse.scout.rt.client 2 0 2014-06-03 11:22:18.441
!MESSAGE org.eclipse.scout.rt.client.ui.desktop.outline.pages.AbstractPage.pageActivatedNotify(AbstractPage.java:454) Caught a failure, probably due to operation cancelation by the user
!STACK 0
ProcessingException[ProcessingStatus[ERROR code=0 PtrTool0Form / Calling IPtrTool0Service.load() / Verarbeitungsfehler]]
at org.eclipse.scout.rt.client.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:167)
at org.eclipse.scout.rt.client.servicetunnel.http.internal.InternalHttpServiceTunnel.invokeService(InternalHttpServiceTunnel.java:175)
at org.eclipse.scout.rt.client.servicetunnel.http.HttpServiceTunnel.invokeService(HttpServiceTunnel.java:115)
at org.eclipse.scout.rt.client.servicetunnel.ServiceTunnelInvocationHandler.invoke(ServiceTunnelInvocationHandler.java:47)
at com.sun.proxy.$Proxy9.load(Unknown Source)
at de.mind.conversation.client.PtrTool0Form$ModifyHandler.execLoad(PtrTool0Form.java:188)
at org.eclipse.scout.rt.client.ui.form.AbstractFormHandler.onLoad(AbstractFormHandler.java:181)
at org.eclipse.scout.rt.client.ui.form.AbstractForm.loadStateInternal(AbstractForm.java:1205)
at org.eclipse.scout.rt.client.ui.form.AbstractForm.startInternal(AbstractForm.java:692)
at de.mind.conversation.client.PtrTool0Form.startModify(PtrTool0Form.java:45)
at de.mind.conversation.client.ui.desktop.outlines.pages.Ptr2Page.execPageActivated(Ptr2Page.java:36)
at org.eclipse.scout.rt.client.ui.desktop.outline.pages.AbstractPage.pageActivatedNotify(AbstractPage.java:446)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutline.makeActivePageToContextPage(AbstractOutline.java:410)
at org.eclipse.scout.rt.client.ui.desktop.outline.DefaultPageChangeStrategy.pageChanged(DefaultPageChangeStrategy.java:39)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutline.handleActivePageChanged(AbstractOutline.java:430)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutline.access$0(AbstractOutline.java:423)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutline$P_OutlineListener.treeChanged(AbstractOutline.java:466)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.fireTreeEventInternal(AbstractTree.java:2177)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.fireNodesSelected(AbstractTree.java:2014)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.selectNodes(AbstractTree.java:1659)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.selectNode(AbstractTree.java:1619)
at org.eclipse.scout.rt.client.ui.desktop.AbstractDesktop.setOutline(AbstractDesktop.java:912)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutlineViewButton.execAction(AbstractOutlineViewButton.java:141)
at org.eclipse.scout.rt.client.ui.action.AbstractAction.doAction(AbstractAction.java:292)
at org.eclipse.scout.rt.client.ui.action.AbstractAction$P_UIFacade.fireActionFromUI(AbstractAction.java:629)
at org.eclipse.scout.rt.ui.swing.action.AbstractSwingScoutActionButton$2.run(AbstractSwingScoutActionButton.java:183)
at org.eclipse.scout.rt.ui.swing.concurrency.SwingScoutSynchronizer$1.runVoid(SwingScoutSynchronizer.java:71)
at org.eclipse.scout.rt.client.ClientJob.runStatus(ClientJob.java:189)
at org.eclipse.scout.rt.client.ClientJob.runTransactionWrapper(ClientJob.java:172)
at org.eclipse.scout.rt.client.ClientJob.run(ClientJob.java:159)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
The failure definetly depends on this line: portType.getFilledTemplate("aha");
Edit:
System.out.println(portType.toString());
Prints: JAX-WS RI 2.2.4-b01: Stub for localhost:8080/conversation_server/jaxws/PrintTemplateWebService
Everything seems to be correct.
Tim
[Updated on: Tue, 03 June 2014 10:00] Report message to a moderator
Re: java.lang.RuntimeException: No application id has been found. [message #1384966 is a reply to message #1384965] |
Tue, 03 June 2014 10:50 |
Thank you!
!SESSION 2014-06-03 12:49:12.460 -----------------------------------------------
Framework arguments: -product de.mind.conversation.server.product
Command-line arguments: -product de.mind.conversation.server.product -data C:\Users\tschwalbe\workspaceScout/../runtime-conversation-server-dev.product -dev file:C:/Users/tschwalbe/workspaceScout/.metadata/.plugins/org.eclipse.pde.core/conversation-server-dev.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY de.mind.conversation.server 1 0 2014-06-03 12:49:20.707
!MESSAGE de.mind.conversation.server.ServerApplication.start(ServerApplication.java:35) conversation server initialized
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.219
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.<clinit>(ConfigIniUtility.java:71) Config Bean Properties
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.229
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.<clinit>(ConfigIniUtility.java:73) org.eclipse.scout.jaxws.security.provider.ConfigIniCredentialValidationStrategy#credentials=eclipse=scout;
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.238
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.<clinit>(ConfigIniUtility.java:73) org.eclipse.scout.rt.server.services.common.file.RemoteFileService#rootPath=C:/Users/Jack/workspace/de.mind.conversation.server/j2ee/ear/war/WEB-INF/remotefiles
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.246
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.<clinit>(ConfigIniUtility.java:73) org.eclipse.scout.http.servletfilter.security.BasicSecurityFilter#active=false
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.255
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.<clinit>(ConfigIniUtility.java:73) org.eclipse.scout.http.servletfilter.security.AnonymousSecurityFilter#active=true
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.264
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.<clinit>(ConfigIniUtility.java:73) org.eclipse.scout.http.servletfilter.security.BasicSecurityFilter#realm=conversation Development
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.268
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.<clinit>(ConfigIniUtility.java:73) org.eclipse.scout.http.servletfilter.security.BasicSecurityFilter#users=admin=manager,allen=allen,blake=blake
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.274
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for org.eclipse.scout.http.servletfilter.security.BasicSecurityFilter
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.278
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:96) users=admin=manager,allen=allen,blake=blake
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.281
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:96) realm=conversation Development
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.285
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:96) active=false
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.289
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.293
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.296
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.300
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.305
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for org.eclipse.scout.http.servletfilter.security.AnonymousSecurityFilter
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.308
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:96) active=true
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.317
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.321
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.325
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.330
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.335
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.339
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:32.804
!MESSAGE org.eclipse.scout.commons.xmlparser.ScoutXmlParser.<init>(ScoutXmlParser.java:110) Missing dependency to org.apache.xerces. Using alternative com.sun.org.apache.xerces.internal.parsers.SAXParser
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:33.354
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for org.eclipse.scout.jaxws.security.provider.BasicAuthenticationHandler
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:33.362
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for org.eclipse.scout.jaxws.security.provider.ConfigIniCredentialValidationStrategy
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:33.366
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:96) credentials=eclipse=scout;
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:33.409
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for org.eclipse.scout.rt.server.services.common.session.ServerSessionRegistryService
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:33.456
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for de.mind.conversation.server.services.common.security.AccessControlService
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:33.472
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for org.eclipse.scout.rt.server.services.common.clientnotification.internal.ClientNotificationService
!ENTRY de.mind.conversation.server 1 0 2014-06-03 12:49:33.481
!MESSAGE de.mind.conversation.server.ServerSession.execLoadSession(ServerSession.java:25) created a new session for anonymous
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:33.505
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for org.eclipse.scout.rt.server.services.common.code.CodeService
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:42.634
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for de.mind.conversation.server.PtrTool0Service
LOADED!!!
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:42.668
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for de.mind.conversation.server.services.ws.consumer.PrintTemplateWebServiceClient
JAX-WS RI 2.2.4-b01: Stub for http://localhost:8080/conversation_server/jaxws/PrintTemplateWebService
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:42.888
!MESSAGE org.eclipse.scout.jaxws.internal.servlet.EndpointServlet.installServletAdapters(EndpointServlet.java:128) Successfully installed JAX-WS endpoint 'PrintTemplateWebService' on URL '/jaxws/PrintTemplateWebService'
!ENTRY org.eclipse.scout.commons 2 0 2014-06-03 12:49:42.945
!MESSAGE org.eclipse.scout.jaxws.internal.SessionHelper.createNewServerSession(SessionHelper.java:60) No subject found in calling AccessContext. That is why the principal 'anonymous' is registered with the subject. This subject is used to create sessions for transactional handlers as long as the request is not authenticated. The default principal can be changed by configuring the prinicipal in 'org.eclipse.scout.jaxws.txhandler.sessionfactory.principal' in config.ini.
!ENTRY de.mind.conversation.server 1 0 2014-06-03 12:49:42.973
!ENTRY org.eclipse.scout.commons 1 0 2014-06-03 12:49:43.035
!MESSAGE org.eclipse.scout.commons.ConfigIniUtility.getProperties(ConfigIniUtility.java:94) Properties for org.eclipse.scout.rt.shared.services.common.exceptionhandler.LogExceptionHandlerService
!ENTRY org.eclipse.scout.rt.shared 4 0 2014-06-03 12:49:43.054
!MESSAGE org.eclipse.scout.rt.shared.services.common.exceptionhandler.LogExceptionHandlerService.differentiatedLog(LogExceptionHandlerService.java:76) ProcessingStatus[ERROR code=0 invoking de.mind.conversation.shared.IPtrTool0Service:load / service: class de.mind.conversation.server.PtrTool0Service, operation: load, args: de.mind.conversation.shared.PtrTool0FormData@5a6efc31 com.sun.xml.internal.ws.client.ClientTransportException: The server sent HTTP status code 401: Unauthorized]
!STACK 0
ProcessingException[ProcessingStatus[ERROR code=0 invoking de.mind.conversation.shared.IPtrTool0Service:load / service: class de.mind.conversation.server.PtrTool0Service, operation: load, args: de.mind.conversation.shared.PtrTool0FormData@5a6efc31 com.sun.xml.internal.ws.client.ClientTransportException: The server sent HTTP status code 401: Unauthorized]]
at org.eclipse.scout.service.ServiceUtility.invoke(ServiceUtility.java:189)
at org.eclipse.scout.rt.server.DefaultTransactionDelegate.invokeImpl(DefaultTransactionDelegate.java:218)
at org.eclipse.scout.rt.server.DefaultTransactionDelegate.invoke(DefaultTransactionDelegate.java:92)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.runServerJobTransactionWithDelegate(ServiceTunnelServlet.java:396)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.runServerJobTransaction(ServiceTunnelServlet.java:392)
at org.eclipse.scout.rt.server.ServiceTunnelServlet$RemoteServiceJob.runTransaction(ServiceTunnelServlet.java:420)
at org.eclipse.scout.rt.server.ServerJob.runTransactionWrapper(ServerJob.java:202)
at org.eclipse.scout.rt.server.ServerJob.access$0(ServerJob.java:190)
at org.eclipse.scout.rt.server.ServerJob$1.run(ServerJob.java:161)
at org.eclipse.scout.rt.server.ServerJob$1.run(ServerJob.java:1)
at javax.security.auth.Subject.doAs(Subject.java:415)
at org.eclipse.scout.rt.server.ServerJob.run(ServerJob.java:156)
at org.eclipse.scout.commons.job.JobEx.runNow(JobEx.java:50)
at org.eclipse.scout.rt.server.ServerJob.runNow(ServerJob.java:148)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.doPost(ServiceTunnelServlet.java:300)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.scout.http.servletfilter.HttpServletEx.access$0(HttpServletEx.java:1)
at org.eclipse.scout.http.servletfilter.HttpServletEx$1.service(HttpServletEx.java:38)
at org.eclipse.scout.http.servletfilter.internal.FilterChainImpl.doFilter(FilterChainImpl.java:44)
at org.eclipse.scout.http.servletfilter.helper.HttpAuthJaasFilter.doFilter(HttpAuthJaasFilter.java:62)
at org.eclipse.scout.http.servletfilter.internal.FilterChainImpl.doFilter(FilterChainImpl.java:41)
at org.eclipse.scout.http.servletfilter.helper.DevelopmentAuthFilter.doFilter(DevelopmentAuthFilter.java:61)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.doFilterInternal(AbstractChainableSecurityFilter.java:220)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.access$0(AbstractChainableSecurityFilter.java:219)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter$1.run(AbstractChainableSecurityFilter.java:157)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.doFilter(AbstractChainableSecurityFilter.java:149)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.doFilter(AbstractChainableSecurityFilter.java:103)
at org.eclipse.scout.http.servletfilter.ServletFilterDelegate.delegateServiceMethod(ServletFilterDelegate.java:57)
at org.eclipse.scout.http.servletfilter.HttpServletEx.service(HttpServletEx.java:35)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:386)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:684)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:229)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1086)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:428)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1020)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:370)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:494)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:982)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:1043)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:865)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:240)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:667)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Thread.java:745)
Caused by: com.sun.xml.internal.ws.client.ClientTransportException: The server sent HTTP status code 401: Unauthorized
at com.sun.xml.internal.ws.transport.http.client.HttpTransportPipe.checkStatusCode(HttpTransportPipe.java:296)
at com.sun.xml.internal.ws.transport.http.client.HttpTransportPipe.createResponsePacket(HttpTransportPipe.java:245)
at com.sun.xml.internal.ws.transport.http.client.HttpTransportPipe.process(HttpTransportPipe.java:203)
at com.sun.xml.internal.ws.transport.http.client.HttpTransportPipe.processRequest(HttpTransportPipe.java:122)
at com.sun.xml.internal.ws.transport.DeferredTransportPipe.processRequest(DeferredTransportPipe.java:123)
at com.sun.xml.internal.ws.api.pipe.Fiber.__doRun(Fiber.java:626)
at com.sun.xml.internal.ws.api.pipe.Fiber._doRun(Fiber.java:585)
at com.sun.xml.internal.ws.api.pipe.Fiber.doRun(Fiber.java:570)
at com.sun.xml.internal.ws.api.pipe.Fiber.runSync(Fiber.java:467)
at com.sun.xml.internal.ws.client.Stub.process(Stub.java:308)
at com.sun.xml.internal.ws.client.sei.SEIStub.doProcess(SEIStub.java:163)
at com.sun.xml.internal.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:98)
at com.sun.xml.internal.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:78)
at com.sun.xml.internal.ws.client.sei.SEIStub.invoke(SEIStub.java:135)
at com.sun.proxy.$Proxy33.getFilledTemplate(Unknown Source)
at de.mind.conversation.server.PtrTool0Service.load(PtrTool0Service.java:47)
at org.eclipse.scout.service.ServiceUtility.invoke(ServiceUtility.java:172)
... 62 more
FUDForum. Page generated in 0.04650 seconds
