Home » Eclipse Projects » e(fx)clipse » Hot to programmatically tell the framework to clear the persisted state
Hot to programmatically tell the framework to clear the persisted state [message #1384815] Mon, 02 June 2014 05:51 Go to next message
I am looking for a way to give the user the possibility to "reset" the ui to it's initial layout. My idea is to restart the application (using IWorkbench.restart()) and then have the framework clear the persisted state.
1) Using -clearPersistedState as a startup command is difficult, since I'm using IApplication.RESTART to do the restarting.
2) There is IApplication.RELAUNCH. I played with this, but didn't find the way to get it to work. Does that even work with e4 applications? Anyway ... the api is not realy intuitive.
Looking at the code I see that IWorkbench.CLEAR_PERSISTED_STATE is saved to the context before the application model is loaded. That's great Smile! I would like to reuse that and set the value during @PostcontextCreate. Unfortunately this is overwritten in loadApplicationModel. In @ProcessAdditions it is already to late, because the app-model hasbeen built be then.
So I am thinking about changing AbstractE4Application to check first if the value is already in the context before setting it. This could also make sense for IWorkbench.PERSIST_STATE, IWorkbench.XMI_URI_ARG and IWorkbench.MODEL_RESOURCE_HANDLER.
I'll do the work, but wanted to get some input first. Maybe I am missing something? Is there already a good way to do this?
Christoph
Re: Hot to programmatically tell the framework to clear the persisted state [message #1384817 is a reply to message #1384815] Mon, 02 June 2014 06:13 Go to previous messageGo to next message
Yes that sounds like the way to go and sounds like a nice new feature
and certainly the first important step!
An even improved version (and future step) would make this feature
available without having to deal with @PostContextCreate one idea might
to allow someone to store this information in the perferences and on
next start we make use of this preference value (and remove it
immediately afterwards).
Another reason to clear the state is that someone installed/uninstalled
plugins using p2 and now you want to start from a clean ui state!
Tom
On 02.06.14 11:51, Christoph Keimel wrote:
> Hello,
> state.
> to the context before the application model is loaded. That's great :)!
> built be then.
> Christoph
Re: Hot to programmatically tell the framework to clear the persisted state [message #1384824 is a reply to message #1384817] Mon, 02 June 2014 07:24 Go to previous messageGo to next message
An implementation is up vor review:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=436351
That is the way I am handling it. The question would be where to put the API.
IWorkbench seems a good candidate: maybe IWorkbench.restartWithClearedPersistedState()
next to the already available IWorkbench.restart().
Yeah. I mark plug-ins with a special property in a p2.inf, so that I can
check weather the persisted state has to be cleared after an update.
Re: Hot to programmatically tell the framework to clear the persisted state [message #1384830 is a reply to message #1384824] Mon, 02 June 2014 07:56 Go to previous messageGo to next message
> API.
IWorkbench is defined by upstream, because restart() is there already it
makes sense to have such a method there as well.
The problem I see with IWorkbench is that you drag in too much things.
I would be in favor of a service definition which only exposes:
* restart(boolean clear)
* shutdown()
found in org.eclipse.fx.ui.services and in our E4Application we push a
service to the context which implements the semantics. Does that make
sense to you?
Do you think we can generalize such a thing somehow? We already have a
(not yet maintained p2 install support in org.eclipse.fx.core.p2) - I'm
not sure about the quality of the code in there.
Something we yet miss completely is a p2 update UI (nothing as complex
as the IDE has)
Tom
Re: Hot to programmatically tell the framework to clear the persisted state [message #1384847 is a reply to message #1384830] Mon, 02 June 2014 09:57 Go to previous message
> * shutdown()
> sense to you?
Yeah. Let's have a bug to continue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=436369
> as the IDE has)
I'll have a look at it when I migrate our e4-swt p2-update-stuff to e4-fx.
Previous Topic:Resize a Part in pixel
Next Topic:2 Parts shared the same model
Current Time: Tue May 13 17:43:18 EDT 2025
Powered by FUDForum. Page generated in 0.03367 seconds
