Home » Eclipse Projects » Dali » Dali generates incomplete and corrupted JPA metamodel
icon5.gif  Dali generates incomplete and corrupted JPA metamodel [message #1384804] Mon, 02 June 2014 08:22 Go to next message
Sergej Logis is currently offline Sergej LogisFriend
I'm using Dali feature to generate JPA metamodel in my projects. Previosly it was generated perfectly, but after that something happened and now my metamodel classes are generated incomplete/wrong. Please note, that entity classes themselves didn't change a bit.
That's how it was generated just a few months ago:
@Generated(value="Dali", date="2014-03-03T15:27:31.931+0200")
@StaticMetamodel(AsmensZyma.class)
public class AsmensZyma_ {
    public static volatile SingularAttribute<AsmensZyma, Long> id;
    public static volatile SingularAttribute<AsmensZyma, Asmuo> asmuo;
    public static volatile SingularAttribute<AsmensZyma, AsmensZymaSource> registas;
    public static volatile SingularAttribute<AsmensZyma, Date> data;
    public static volatile SingularAttribute<AsmensZyma, String> roik;
    public static volatile SingularAttribute<AsmensZyma, String> pastaba;
And how it is being generated now:
@Generated(value="Dali", date="2014-05-30T11:48:56.816+0300")
   public static volatile SingularAttribute<AsmensZyma, Object> asmuo;
Note that there are plenty of missing fields, and fields types are not detected properly. This happens TO ALL my entity classes in ALL my projects... What I have tried:
  • Upgrading STS (currently using 3.5.1)
  • Cleaning/refreshing/updating projects
  • Re-configuring JPA metamodel generation in STS
  • Creating brand new clean workspace and importing only one project to it
Nothing helps so far...
Also, as suggested on StackOverflow, i have checked JPA Structure/Details views. And I have found out, that missing fields are treated as "unmapped". But they are all annotated with @Column! And @ManyToOne relation is picked properly, however, field generic type is missing anyway in generated metamodel...
Any suggestions or help is highly appretiated!
Re: Dali generates incomplete and corrupted JPA metamodel [message #1405346 is a reply to message #1384804] Thu, 07 August 2014 06:29 Go to previous message
Tobias Liefke is currently offline Tobias LiefkeFriend
We had a similar problem.
In our project we once had used another library for static metamodel generation, which still existed in the project properties under Java Compiler/Annotation Processing/Factory Path.
We had turned off annotation processing under Java Compiler/Annotation Processing, but the defined library distracted DALI, and it generated incomplete and incorrect metamodel classes.
Deleting all libraries under Java Compiler/Annotation Processing/Factory Path fixed that problem.
Previous Topic:eclipse not creating table from jpa entities
Next Topic:Mistaken JPA Validation Error (Luna)
Current Time: Fri Sep 18 14:28:18 GMT 2020
Powered by FUDForum. Page generated in 0.01439 seconds
