Home » Modeling » TMF (Xtext) » Completion proposal with multiple selected regions
Completion proposal with multiple selected regions [message #1384706] Fri, 30 May 2014 15:05 Go to next message
Arne Johanson is currently offline Arne JohansonFriend
for content assist I would like to implement context-sensitive (this prevents using templates.xml) templates with multiple selected regions. So far, I used a ConfigurableCompletionProposal in the following way:
var proposal = (createCompletionProposal("Template content", "Title", null, context)
                as ConfigurableCompletionProposal)
proposal.setSelectionStart(proposal.replacementOffset + 1);
proposal.setSelectionLength(5);
proposal.setSimpleLinkedMode(context.viewer, '\t')
acceptor.accept(proposal)
However, this approach allows only for one selected region. How can I insert multiple selected regions?
All the best
Arne
Re: Completion proposal with multiple selected regions [message #1384742 is a reply to message #1384706] Sat, 31 May 2014 05:56 Go to previous message
I found useful JFace classes to complete the task. This is my helper function to create a template proposal object that can be passed to an Xtext CompletionProposalAcceptor:
def TemplateProposal createTemplateProposal(
	String template,
	String name,
	String description,
	String contextTypeId,
	String icon,
	ContentAssistContext context
	new TemplateProposal(
		new Template(name, description, contextTypeId, template, true),
		new DocumentTemplateContext(
			new TemplateContextType(contextTypeId, name),
			context.document,
			context.offset,
			context.replaceContextLength
		context.replaceRegion,
		loadImage(icon)
However, a problem remains: if I use the ${cursor} variable to specify the location for the caret after editing, the word "cursor" is actually printed in the content proposal (but otherwise ${cursor} works as intended). Any suggestions why this is the case?
Besides this last question, I would really like to see Xtext-specific abstractions for this task (so that you don't have to fiddle around with JFace classes that -- at least to me -- don't seem to integrate well with the Xtext abstractions (why should I know something about TemplateContextTypes?)).
Cheers
Arne
Previous Topic:the formatter and modification in a unit of work
Next Topic:Cannot reference elements in other files using xtext editor in papyrus
Current Time: Fri Feb 21 17:14:24 GMT 2020
Powered by FUDForum. Page generated in 0.01876 seconds
