Re: Hi all, help with Ubuntu install of Kepler [message #1384714 is a reply to message #1384711] |
Fri, 30 May 2014 16:16 |
Prahlad Yeri Messages: 3 Registered: May 2014 |
>>I still get the same weird RSE_UI_INIT at startup followed by the kind of minimalist UI (starts in a project display mode *NOT* the nice fresh startup UI
This error doesn't look like its because of any workspace metadeta, but something related to the platform itself. Though I don't work in JBoss, etc. (I use Eclipse mostly for Android and PyDev), I faced a similar issue with Kepler a while ago. Though there wasn't any error, the program crashed frequently and had GUI issues in ubuntu. This has something to do with your eclipse.ini file. You can experiment with some settings like -XX:PermSize=128m and -XX:MaxPermSize=400m. Do a google search on that, you will got some pointers.
Can't you try it on a 32-bit ubuntu machine? I'm running eclipse-JEE with ADT+PyDev+Webtools plugins and still goes w/o any problems from 12.04 to 14.04 since I upgraded recently. I did face a lot more issues when I tried 64bit earlier with Android ADT plugin.
[Updated on: Fri, 30 May 2014 16:16] Report message to a moderator
Re: Hi all, help with Ubuntu install of Kepler [message #1384729 is a reply to message #1384714] |
Fri, 30 May 2014 20:38 |
Scott Kay Messages: 4 Registered: May 2014 |
Prahlad Yeri wrote on Fri, 30 May 2014 12:16>>I still get the same weird RSE_UI_INIT at startup followed by the kind of minimalist UI (starts in a project display mode *NOT* the nice fresh startup UI
Many thanks for your help Prahlad, but the problem was just incomplete cleanup of the previous install. Interesting that at startup I still see the RSE_UI_INIT very breifly, I am thinking it is simply a process status notification, but it lasts only shortly as the "proper" UI is initialized. I need the 64 bit support for the 64 bit target instance in AWS cloud.
FUDForum. Page generated in 0.08831 seconds
