Re: SWTBot hangs at click() [message #1384642 is a reply to message #1384640] |
Thu, 29 May 2014 21:29 |
On 29/05/2014 22:42, Robert Munteanu wrote:
> I'm trying to automate a simple new project wizard using SwtBot 2.2.1 .
> The code is the one that I've found in the tutorial
> bot.menu("File").menu("New").menu("Project...").click();
after click() is executed what does your test do? Is it getting the
shell corresponding to the dialog?
> The problem is that the click() method call never returns. My target
You say that it never returns because you're debugging it? In case
you're debugging it, then I think that method will never return because
you "stole" the focus to the Swtbot test....
> platform is Eclipse Kepler on Linux x86_64 . The new project dialog is
> brought up however, so I'm not sure why the call does not return. Here's
> a screenshot of what the Eclipse instance under test looks like when the
> test hangs
> The stack trace of the main thread is
> "main" prio=10 tid=0x00007f12c0006000 nid=0x428b runnable
> [0x00007f12c68d2000]
> java.lang.Thread.State: RUNNABLE
> at org.eclipse.swt.internal.gtk.OS.Call(Native Method)
> at org.eclipse.swt.widgets.Display.sleep(Display.java:4233)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
> at org.eclipse.jface.window.Window.open(Window.java:802)
> at
> org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction.java:117)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:499)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1392)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1416)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1401)
> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1187)
> at
> org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot$2.run(AbstractSWTBot.java:166)
> at
> org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$5.doRun(UIThreadRunnable.java:221)
> at
> org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable.run(UIThreadRunnable.java:78)
> at
> org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable.asyncExec(UIThreadRunnable.java:223)
> at
> org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.asyncExec(AbstractSWTBot.java:576)
> at
> org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.notify(AbstractSWTBot.java:155)
> at
> org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.notify(AbstractSWTBot.java:136)
> at
> org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.notify(AbstractSWTBot.java:126)
> at
> org.eclipse.swtbot.swt.finder.widgets.SWTBotMenu.click(SWTBotMenu.java:60)
> at
> org.apache.sling.ide.test.impl.ui.NewContentPackageWizardTest.createNewContentProject(NewContentPackageWizardTest.java:55)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:47)
> at
> org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
> at
> org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:44)
> at
> org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
> at org.junit.rules.ExternalResource$1.evaluate(ExternalResource.java:48)
> at org.junit.rules.RunRules.evaluate(RunRules.java:20)
> at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:271)
> at
> org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
> at
> org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
> at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
> at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
> at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
> at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
> at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
> at
> org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:26)
> at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
> at
> org.eclipse.swtbot.swt.finder.junit.SWTBotJunit4ClassRunner.run(SWTBotJunit4ClassRunner.java:54)
> at
> org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
> at
> org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
> at
> org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:62)
> at
> org.eclipse.pde.internal.junit.runtime.PlatformUITestHarness$1.run(PlatformUITestHarness.java:47)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
> - locked <0x00000000fe4fc480> (a org.eclipse.swt.widgets.RunnableLock)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3717)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3366)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
> at
> org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
> at
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.pde.internal.junit.runtime.NonUIThreadTestApplication.runApp(NonUIThreadTestApplication.java:54)
> at
> org.eclipse.pde.internal.junit.runtime.UITestApplication.runApp(UITestApplication.java:47)
> at
> org.eclipse.pde.internal.junit.runtime.NonUIThreadTestApplication.start(NonUIThreadTestApplication.java:48)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
> at
> at
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
> What can I do to make the test run successfully?
> (also posted at
> https://stackoverflow.com/questions/23778686/swtbot-hangs-at-click , not
> sure if you watch stackoverflow for questions and thought I'd try here
> as well ).
> Robert
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: SWTBot hangs at click() [message #1384671 is a reply to message #1384642] |
Fri, 30 May 2014 08:11 |
Robert Munteanu Messages: 30 Registered: July 2009 |
Member |
>> Hi,
> Hi
>> test hangs
Aaargh, nevermind. I was running the test as a JUnit Plug-In test and
'Run in UI Thread' was checked. Unchecking it makes the test work as
expected.
I only noticed the FAQ entry at [1] now, and I imagine I'm not the only
one. Would it be possible for SWTBot to assert early on that the test is
not running on the UI thread? I can open a bug if needed.
Robert
[1]:
https://wiki.eclipse.org/SWTBot/FAQ#Why_do_I_have_to_run_tests_as_SWTBot_tests.2C_instead_of_PDE-JUnit_tests.3F
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> (also posted at
>> as well ).
>> Thanks,
>> Robert
Re: SWTBot hangs at click() [message #1384703 is a reply to message #1384671] |
Fri, 30 May 2014 14:32 |
>>> Hi,
>> Hi
>>> test hangs
> expected.
> Robert
> [1]:
Hi Robert
if you run the test using the SWTBot test launch instead of Plug-in test
launch it will take care of using the right thread
cheers
Lorenzo
Xtext Book:
FUDForum. Page generated in 0.02337 seconds
