Merge? [message #23851] |
Wed, 06 August 2008 12:28 |
Originally posted by: douglas.palmer.prismtech.com
Hi everyone
I notice there is a new version of buckminster on the downloads site
with fixes for recent issues. Is there any chance this could be merged
into the eclipse 3.3 branch?
Doug
Re: Merge? [message #23892 is a reply to message #23851] |
Wed, 06 August 2008 12:57 |
Hi Douglas,
I plan to do the merge later this week. I just haven't got around to it yet.
There will always be some latency between the 3.4 updates and merges to
3.3. If you want to stay on the bleeding edge, and unless you have
experienced some problems with the configuration, perhaps you should
consider using the 3.4 version on a 3.3 target platform?
Thomas Hallgren
Douglas Palmer wrote:
> Hi everyone
> Thanks
> Doug
Re: Merge? [message #23933 is a reply to message #23892] |
Wed, 06 August 2008 13:08 |
Thomas Hallgren wrote:
> Hi Douglas,
> yet.
> Regards,
> Thomas Hallgren
Hi Thomas
I've be thinking about moving up to 3.4; I haven't had time to
investigate this yet. My current build relies on installing emf/jet
into buckminster 3.3 and I'm not sure whether changing to 3.4 will cause
problems.
I will give this a try and see what happens.
Doug
Re: Merge? [message #24161 is a reply to message #24137] |
Wed, 06 August 2008 18:14 |
Hi Douglas,
No, nothing different in 3.4. This is an exception that I haven't seen
before and it's not in a bundle that has a special 3.3 branch. You use
the same in the 3.3 version.
I'll have to investigate this further.
Can you try setting the number of parallel resolution threads to 1 and
see if the problem goes away? What value are you using today?
Thomas Hallgren
>> Hi Thomas
>> cause problems.
>> Regards
>> Doug
> Hello again
> I tried switching my build to the eclipse 3.4 buckminster but I having a
> problem with it. Whenever I try to resolve my product I get a
> concurrent modification exception and the resolution fails. The stack
> trace is shown below. Do I need to do something differently with the
> eclipse 3.4 product?
> Regards
> Doug
> WARN: java.util.ConcurrentModificationException
> at
> org.tmatesoft.svn.core.internal.util.SVNHashMap$TableIterato r.next(SVNHashMap.java:437)
> at
> org.tmatesoft.svn.core.internal.util.SVNHashMap$KeyIterator. next(SVNHashMap.java:468)
> at
> org.tmatesoft.svn.core.io.SVNRepositoryFactory.create(SVNRep ositoryFactory.java:190)
> at
> org.tmatesoft.svn.core.wc.DefaultSVNRepositoryPool.createRep ository(DefaultSVNRepositoryPool.java:214)
> at
> org.tmatesoft.svn.core.wc.SVNClientManager.createRepository( SVNClientManager.java:247)
> at
> org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SV NBasicClient.java:297)
> at
> org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SV NBasicClient.java:289)
> at
> org.tmatesoft.svn.core.wc.SVNBasicClient.getLocations(SVNBas icClient.java:792)
> at
> org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SV NBasicClient.java:483)
> at org.tmatesoft.svn.core.wc.SVNLogClient.doList(SVNLogClient.j ava:775)
> at org.tmatesoft.svn.core.javahl.SVNClientImpl.list(SVNClientIm pl.java:351)
> at org.tmatesoft.svn.core.javahl.SVNClientImpl.list(SVNClientIm pl.java:338)
> at
> org.polarion.team.svn.connector.svnkit.SVNKitConnector.list( SVNKitConnector.java:1211)
> at
> org.eclipse.team.svn.core.extension.factory.ThreadNameModifi er.list(ThreadNameModifier.java:276)
> at org.eclipse.team.svn.core.utility.SVNUtility.list(SVNUtility .java:365)
> at
> org.eclipse.buckminster.subversive.internal.SubversiveSessio n.listFolder(SubversiveSession.java:949)
> at
> org.eclipse.buckminster.subversive.internal.SubversiveSessio n.getDirEntry(SubversiveSession.java:894)
> at
> org.eclipse.buckminster.subversive.internal.SubversiveSessio n.getRootEntry(SubversiveSession.java:883)
> at
> org.eclipse.buckminster.subversive.internal.SubversiveVersio nFinder.getTrunk(SubversiveVersionFinder.java:81)
> at
> org.eclipse.buckminster.core.version.AbstractSCCSVersionFind er.getBestTrunkMatch(AbstractSCCSVersionFinder.java:347)
> at
> org.eclipse.buckminster.core.version.AbstractSCCSVersionFind er.getBestVersion(AbstractSCCSVersionFinder.java:155)
> at
> org.eclipse.buckminster.core.rmap.model.Provider.findMatch(P rovider.java:218)
> at
> org.eclipse.buckminster.core.rmap.model.SearchPath.getProvid er(SearchPath.java:104)
> at
> org.eclipse.buckminster.core.rmap.model.ResourceMap.resolve( ResourceMap.java:165)
> at
> org.eclipse.buckminster.core.resolver.ResourceMapResolver.in nerResolve(ResourceMapResolver.java:250)
> at
> org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.re solve(ResolverNodeWithJob.java:218)
> at
> org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.ru n(ResolverNodeWithJob.java:95)
> at
> org.eclipse.buckminster.core.resolver.ResolverNodeWithJob$No deResolutionJob.run(ResolverNodeWithJob.java:50)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> ERROR [0004] : java.util.ConcurrentModificationException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.buckminster.subversive.internal.SubversiveRemote FileReader. <init>(SubversiveRemoteFileReader.java:85)
> at
> org.eclipse.buckminster.subversive.internal.SubversiveReader Type.getReader(SubversiveReaderType.java:57)
> at
> org.eclipse.buckminster.core.version.ProviderMatch.getReader (ProviderMatch.java:148)
> at
> org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:275)
> at
> org.eclipse.buckminster.core.ctype.AbstractComponentType.get ComponentVersion(AbstractComponentType.java:144)
> at
> org.eclipse.buckminster.core.version.AbstractVersionFinder.g etVersionFromArtifacts(AbstractVersionFinder.java:75)
> at
> org.eclipse.buckminster.core.version.AbstractSCCSVersionFind er.getBestTrunkMatch(AbstractSCCSVersionFinder.java:378)
> at
> at
> at
> at
> at
> at
> at
> at
> ERROR [0012] : java.util.ConcurrentModificationException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:170)
> at
> org.eclipse.buckminster.core.rmap.model.ResourceMap.resolve( ResourceMap.java:172)
> at
> at
> at
> at
> ERROR [0018] : java.util.ConcurrentModificationException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ERROR [0024] : java.util.ConcurrentModificationException
> Errors and Warnings
> [0][0004] : java.util.ConcurrentModificationException
> Caused by: [0]java.util.ConcurrentModificationException
> [0][0012] : java.util.ConcurrentModificationException
> [0][0018] : java.util.ConcurrentModificationException
> [0][0024] : java.util.ConcurrentModificationException
Re: Merge? [message #24237 is a reply to message #24199] |
Wed, 06 August 2008 18:29 |
You can use this headless command:
buckminster setpref maxParallelResolutions=1
or, set it using the Buckminster preferences in the IDE.
Thomas Hallgren
>> Hi Douglas,
>> Regards,
>> Thomas Hallgren
> Hi Thomas
> I'm not sure how many parallel resolution threads I'm using; I'll be
> using the default number for the 3.4 headless product. How would I go
> about setting the number to 1?
> Regards
> Doug
Re: Merge? [message #24402 is a reply to message #24278] |
Thu, 07 August 2008 15:02 |
I asked about the ConcurrentModificationException on the SVNKit forum.
As it turns out, it's not available for Subversive at this point (they
are at revision 4583) but a binary is available elsewhere. This is the
reply:
Hello Thomas,
We've fixed that problem in 1.2.x branch of SVNKit (r4592). You may get
SVNKit binaries with the fix at our build server at
https://teamcity.svnkit.com/ - this fix also will be included into the
next version of SVNKit (1.2.0-beta5).
Alexander Kitaev,
TMate Software,
http://svnkit.com/ - Java [Sub]Versioning Library!
>> Regards,
>> Thomas Hallgren
> Hi Thomas
> Setting maxParallelResolutions=1 fixes the problem; surprisingly it
> didn't impact the build time much either.
> Regards
> Doug
> P.s. My buckmister install includes
> org.eclipse.team.svn.core_0.7.2.I20080801-1500.jar
FUDForum. Page generated in 0.03824 seconds
