Home » Language IDEs » Java Development Tools (JDT) » the annotaion @NonNull is disallowed for this location
the annotaion @NonNull is disallowed for this location [message #1382022] Sun, 25 May 2014 20:58 Go to next message
Nicola Zanaga is currently offline Nicola ZanagaFriend
Member
now, i'm sure to use eclipse 4.4rc3, jdk.8 and the correct org.eclipse.jdt.annotation, but i get the error: the annotaion @NonNull is disallowed for this location
It seems that using the complete name "java.io.File" instead of "File" generates the error.
import java.io.File;
import org.eclipse.jdt.annotation.NonNull;
public class Test6 {
@NonNull File testOk() {
return new File("x");
@NonNull java.io.File testErr() {
Re: the annotaion @NonNull is disallowed for this location [message #1382023 is a reply to message #1382022] Sun, 25 May 2014 20:58 Go to previous messageGo to next message
Member
eclipse 4.4rc2 Smile
Re: the annotaion @NonNull is disallowed for this location [message #1383892 is a reply to message #1382022] Mon, 26 May 2014 22:06 Go to previous message
Stephan Herrmann is currently offline Stephan HerrmannFriend
Nicola Zanaga wrote on Sun, 25 May 2014 22:58
You're right, with type annotations in Java 8 the correct syntax is:
	java.io.@NonNull File testErr()  {
best,
Stephan
Previous Topic:"enable syntactic null analysis for fields" broken with eclise 4.4rc1 jdk1.8
Next Topic:Eclipse + Git, more than just an egit question
Current Time: Wed Jun 19 01:02:33 GMT 2024
Powered by FUDForum. Page generated in 0.03587 seconds
