Home » Archived » Test and Performance Tools Platform (TPTP) » JVM crash on TPTP run
JVM crash on TPTP run [message #23768] |
Wed, 27 July 2005 07:49 |
Originally posted by: tristano.people.it
Every time I launch a profile run the JVM crash with an "Unmanaged
Win32 Exception" error. I try to disable the JIT compiler with the
-Djava.compiler=none JVM option but I don't resolve the problem.
My system:
Windows XP Professional
Sun Java 1.4.2
Eclipse 3.1
tptp.runtime-TPTP-4.0.0-200507181519
Agent Controller tptpdc.win_ia32-TPTP-4.0.0-200507181519
Any help is appreciated...
Bye
Scritto con MesNews: http://www.mesnews.net
Re: JVM crash on TPTP run [message #23897 is a reply to message #23768] |
Thu, 28 July 2005 14:56 |
Originally posted by: (Navid Mehregani)nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0052159D8525704C_=
Content-Type: text/plain; charset="US-ASCII"
Can you try using the IBM JRE instead:
http://www-307.ibm.com/pc/support/site.wss/document.do?sites tyle=lenovo&lndocid=MIGR-56888
You'll need to regen the agent controller's config file and to change your
JRE in the Eclipse workbench click on Windows->preferences-> Java->
installed JREs -> Add
Navid Mehregani
IBM Canada
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Can you try using the IBM JRE instead:
http://www-307.ibm.com/pc/support/site.wss/document.do?sites tyle=lenovo&lndocid=MIGR-56888</font>
<br>
<br><font size=2 face="sans-serif">You'll need to regen the agent controller's
config file and to change your JRE in the Eclipse workbench click on Windows->preferences->
Java-> installed JREs -> Add</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
<br><font size=2 face="sans-serif">IBM Canada</font>
--=_alternative 0052159D8525704C_=--
Re: JVM crash on TPTP run [message #24384 is a reply to message #23897] |
Tue, 02 August 2005 16:43 |
Originally posted by: dawood.us.ibm.com
--------------070407070307090308000003
Content-Type: text/plain; charset=us-ascii; format=flowed
I'm having similar problems. My scenario uses 3.1.0 with the 4.0
release of TPTP and required components EMF and XMI. I can successfully
run the profiler against an raserver running on the same machine (call
it A). The problem comes when I try and profile the same app on machine
A from a remote machine running the same platform. I'm using the IBM
Classic 1.4.2 JVM dated 12/2004 on the machine A. I've attached the
java core file in case this helps. It does NOT seem to help to turn on
-Djava.compiler=none as was suggested in a separate thread. All
machines involved are running Windows XP.
Thanks for any help.
> your JRE in the Eclipse workbench click on Windows->preferences-> Java->
> Navid Mehregani
> IBM Canada
name="javacore.20050802.123144.2372.txt"
Content-Disposition: inline;
filename="javacore.20050802.123144.2372.txt"
NULL ------------------------------------------------------------ ------------
0SECTION TITLE subcomponent dump routine
NULL ===============================
1TISIGINFO signal 11 received
1TIDATETIME Date: 2005/08/02 at 12:31:44
1TIFILENAME Javacore filename: C:\DOCUME~1\dawood\LOCALS~1\Temp\javacore.20050802.123144.23 72.txt
0SECTION XHPI subcomponent dump routine
1XHEXCPCODE Exception code: C0000005 Access Violation
1XHEXCPADDRESS Fault address: 7C91142E 01:0001042E
1XHEXCPMODULE Fault module: C:\WINDOWS\system32\ntdll.dll
NULL
1XHREGISTERS Registers:
2XHREGISTER EAX:80676582
2XHREGISTER EBX:01FA0000
2XHREGISTER ECX:000000FF
2XHREGISTER EDX:01FA7A98
2XHREGISTER ESI:01FA7A90
2XHREGISTER EDI:00000083
2XHREGISTER CS:EIP:001B:7C91142E
2XHREGISTER SS:ESP:0023:0760F858 EBP:0760FA78
2XHREGISTER DS:0023 ES:0023 FS:003B GS:0000
NULL
1XHFLAGS Flags:00010246
NULL
0SECTION CI subcomponent dump routine
1CIJAVAVERSION J2RE 1.4.2 IBM Windows 32 build cn142sr1a-20050209
1CIRUNNINGAS Running as a standalone JVM
1CICMDLINE c:\java\j9142sr1a\jre\bin\java.exe -XrunpiAgent:server=controlled org.eclipse.core.launcher.Main -application ConsoleApp.consoleApp
1CIJAVAHOMEDIR Java Home Dir: c:\java\j9142sr1a\jre
1CIJAVADLLDIR Java DLL Dir: c:\java\j9142sr1a\jre\bin
1CISYSCP Sys Classpath: c:\java\j9142sr1a\jre\lib\core.jar;c:\java\j9142sr1a\jre\lib \graphics.jar;c:\java\j9142sr1a\jre\lib\security.jar;c:\java \j9142sr1a\jre\lib\server.jar;c:\java\j9142sr1a\jre\lib\xml. jar;c:\java\j9142sr1a\jre\lib\charsets.jar;c:\java\j9142sr1a \jre\lib\ibmcertpathprovider.jar;c:\java\j9142sr1a\jre\lib\i bmjaasactivelm.jar;c:\java\j9142sr1a\jre\lib\ibmjaaslm.jar;c :\java\j9142sr1a\jre\lib\ibmjcefw.jar;c:\java\j9142sr1a\jre\ lib\ibmjgssprovider.jar;c:\java\j9142sr1a\jre\lib\ibmjssefip s.jar;c:\java\j9142sr1a\jre\lib\ibmjsseprovider.jar;c:\java\ j9142sr1a\jre\lib\ibmorb.jar;c:\java\j9142sr1a\jre\lib\ibmor bapi.jar;c:\java\j9142sr1a\jre\lib\ibmpkcs.jar
1CIUSERARGS UserArgs:
2CIUSERARG -Dconsole.encoding=Cp850
2CIUSERARG vfprintf 0x403000
2CIUSERARG -XrunpiAgent:server=controlled
2CIUSERARG -Dinvokedviajava
2CIUSERARG -Djava.class.path=c:\dev\benchmarks\ca-x86\startup.jar;C:\de v\raserver\plugins\org.eclipse.tptp.platform.collection.fram ework_4.0.0\hcframe.jar;C:\dev\raserver\plugins\org.eclipse. hyades.execution_4.0.0\hexr.jar;C:\dev\raserver\plugins\org. eclipse.hyades.execution_4.0.0\hexl.jar;C:\dev\raserver\plug ins\org.eclipse.hyades.execution_4.0.0\hexcore.jar;;C:\dev\r aserver\plugins\org.eclipse.core.runtime_3.1.0.jar
2CIUSERARG vfprintf
NULL
1CIJVMMI JVM Monitoring Interface (JVMMI)
2CIJVMMIOFF No events are enabled.
NULL
0SECTION DC subcomponent dump routine
1DCHEADEREYE Header eye catcher DCST
1DCHEADERLEN Header length 24
1DCHEADERVER Header version 1
1DCHEADERMOD Header modification 0
1DCINTERFACE DC Interface at 0x1015DD1C with 15 entries
2DCINTERFACE 1 - dcCString2JavaString 0x1006E7F0
2DCINTERFACE 2 - dcInt642CString 0x1006E9B0
2DCINTERFACE 3 - dcJavaString2NewCString 0x1006EBD0
2DCINTERFACE 4 - dcJavaString2CString 0x1006EAF0
2DCINTERFACE 5 - dcJavaString2NewPlatformString 0x1006ED20
2DCINTERFACE 6 - dcJavaString2UTF 0x1006F0C0
2DCINTERFACE 7 - dcPlatformString2JavaString 0x1006EE40
2DCINTERFACE 8 - dcUnicode2UTF 0x1006EFF0
2DCINTERFACE 9 - dcUnicode2UTFLength 0x1006EF60
2DCINTERFACE 10 - dcUTF2JavaString 0x1006F490
2DCINTERFACE 11 - dcUTFClassName2JavaString 0x1006F790
2DCINTERFACE 12 - dcJavaString2ClassName 0x1006F190
2DCINTERFACE 13 - dcUTF2UnicodeNext 0x1006FA10
2DCINTERFACE 14 - dcVerifyUTF8 0x1006FB00
2DCINTERFACE 15 - dcDumpRoutine 0x10070190
1DCARRAYINFO Array info at 0x101129A8 with 16 entries
2DCARRAYINFO 1 - index 0 signature 0 name N/A factor 0
2DCARRAYINFO 2 - index 0 signature 0 name N/A factor 0
2DCARRAYINFO 3 - index 2 signature L name class[] factor 4
2DCARRAYINFO 4 - index 0 signature 0 name N/A factor 0
2DCARRAYINFO 5 - index 4 signature Z name bool[] factor 1
2DCARRAYINFO 6 - index 5 signature C name char[] factor 2
2DCARRAYINFO 7 - index 6 signature F name float[] factor 4
2DCARRAYINFO 8 - index 7 signature D name double[] factor 8
2DCARRAYINFO 9 - index 8 signature B name byte[] factor 1
2DCARRAYINFO 10 - index 9 signature S name short[] factor 2
2DCARRAYINFO 11 - index 10 signature I name int[] factor 4
2DCARRAYINFO 12 - index 11 signature J name long[] factor 8
2DCARRAYINFO 13 - index 0 signature 0 name uint[] factor 0
2DCARRAYINFO 14 - index 0 signature 0 name uint1[] factor 0
2DCARRAYINFO 15 - index 0 signature 0 name uint2[] factor 0
2DCARRAYINFO 16 - index 0 signature 0 name uint3[] factor 0
0SECTION DG subcomponent dump routine
1DGTRCENABLED Trace enabled: Yes
2DGTRCTYPE Trace: Internal
2DGTRCBUFFERS Buffer specification: 8k
2DGTRCBUFALLOC Buffers allocated: 0
2DGTRCBUFUSED Buffers in use: 0
1DGJDUMPBUFF Javadump buffer size (allocated): 2621440
0SECTION ST subcomponent dump routine
1STGCMODES Resettable GC: No
1STGCMODES Concurrent GC: No
1STCURHBASE Current Heap Base: 0x101801FC
1STCURHLIM Current Heap Limit: 0x1057FBFC
1STMWHBASE Middleware Heap Base: 0x101801FC
1STMWHLIM Middleware Heap Limit: 0x1057FBFC
1STGCHELPERS Number of GC Helper Threads: 0
1STJVMOPTS -Xconcurrentlevel: 0
1STJVMOPTS -Xconcurrentbackground: 0
1STGCCTR GC Counter: 1
1STAFCTR AF Counter: 1
1STHEAPFREE Bytes of Heap Space Free: 151f40
1STHEAPALLOC Bytes of Heap Space Allocated: 3ffa00
1STSMBASE SM Base: 0x0
1STSMEND SM End: 0x0
1STPAMSTART PAM Start: 0x0
1STPAMEND PAM End: 0x0
1STCOMACTION Compact Action: 0
0SECTION XE subcomponent dump routine
1XETHRESHOLD MMI threshold for java methods is set to 2000
1XEJITINIT JIT is initialized
1XEJVMPIOFF JVMPI is not activated
1XEJNITHRESH MMI threshold for JNI methods is set to 0
1XETRCHIS Trace history length is set to 4
1XEJITDUMP JIT dump routine is not yet implemented.
0SECTION LK subcomponent dump routine
NULL
1LKPOOLINFO Monitor pool info:
2LKPOOLINIT Initial monitor count: 32
2LKPOOLEXPNUM Minimum number of free monitors before expansion: 5
2LKPOOLEXPBY Pool will next be expanded by: 16
2LKPOOLTOTAL Current total number of monitors: 32
2LKPOOLFREE Current number of free monitors: 28
NULL
1LKMONPOOLDUMP Monitor Pool Dump (flat & inflated object-monitors):
2LKMONINUSE sys_mon_t:0x002BB388 infl_mon_t: 0x002BADE4:
3LKMONOBJECT java.lang.ref.Reference$Lock@10200598/102005A0: <unowned>
3LKNOTIFYQ Waiting to be notified:
3LKWAITNOTIFY "Reference Handler" (0x2431620)
2LKMONINUSE sys_mon_t:0x002BB418 infl_mon_t: 0x002BAE3C:
3LKMONOBJECT java.lang.ref.ReferenceQueue$Lock@102002D0/102002D8: <unowned>
3LKWAITNOTIFY "Finalizer" (0x23A5AD8)
NULL
1LKREGMONDUMP JVM System Monitor Dump (registered monitors):
2LKREGMON JITC PIC Lock (0x024DC9F8): <unowned>
2LKREGMON JITC CHA lock (0x024DC9B0): <unowned>
2LKREGMON JITC MB UPDATE lock (0x027A0070): <unowned>
2LKREGMON JITC Global_Compile lock (0x027A0020): owner "main" (0x2B1AE8), entry count 1
2LKREGMON Free Class Loader Cache Entry lock (0x00038F28): <unowned>
2LKREGMON IO lock (0x00038EE0): <unowned>
2LKREGMON Evacuation Region lock (0x00038E50): <unowned>
2LKREGMON Heap Promotion lock (0x00038E08): <unowned>
2LKREGMON Sleep lock (0x00038DC0): <unowned>
3LKWAITNOTIFY "State Data Manager" (0x7134360)
2LKREGMON Method trace lock (0x00038D78): <unowned>
2LKREGMON Heap lock (0x00038C58): owner "Framework Event Dispatcher" (0x713C6C8), entry count 1
2LKREGMON Monitor Cache lock (0x00038BC8): owner "Framework Event Dispatcher" (0x713C6C8), entry count 1
2LKREGMON JNI Pinning lock (0x00038CA0): <unowned>
2LKREGMON JNI Global Reference lock (0x00038C10): <unowned>
2LKREGMON Classloader lock (0x00038D30): <unowned>
2LKREGMON Binclass lock (0x00038B80): <unowned>
2LKREGMON Thread queue lock (0x002B18C0): owner "Framework Event Dispatcher" (0x713C6C8), entry count 1
2LKREGMON Monitor Registry lock (0x00038CE8): owner "Framework Event Dispatcher" (0x713C6C8), entry count 1
2LKREGMON System Heap lock (0x002BBE78): <unowned>
2LKREGMON ACS Heap lock (0x002BBEC0): <unowned>
2LKREGMON PAM lock (0x002BBF08): <unowned>
2LKREGMON Intern String Table lock (0x002BBF50): <unowned>
2LKREGMON Classloader lock (0x002BBF98): <unowned>
2LKREGMON JIT Byte Code lock (0x00038008): <unowned>
2LKREGMON JIT Global Compile lock (0x00038050): <unowned>
2LKREGMON JIT BINCLASS lock (0x00038098): <unowned>
2LKREGMON JIT Debug lock (0x000380E0): <unowned>
2LKREGMON JIT Log lock (0x00038128): <unowned>
2LKREGMON JITmemT 1 lock (0x00038170): <unowned>
2LKREGMON JITspaceT 1 lock (0x000381B8): <unowned>
2LKREGMON JITcodeT 1 lock (0x00038200): <unowned>
2LKREGMON JITnccbT 1 lock (0x00038248): <unowned>
2LKREGMON JIT Invoke Interface Cache lock (0x00038290): <unowned>
2LKREGMON JIT Class Map lock (0x000382D8): <unowned>
2LKREGMON JIT Code lock (0x00038320): <unowned>
2LKREGMON JITmblkT 1 lock (0x00038368): <unowned>
2LKREGMON JIT MB Update lock (0x000383B0): <unowned>
2LKREGMON Permanent Variable subpool lock (0x000383F8): <unowned>
2LKREGMON Intern String Buckets subpool lock (0x00038440): <unowned>
2LKREGMON UTF8 Cache subpool lock (0x00038488): <unowned>
2LKREGMON Namespace Cache subpool lock (0x000384D0): <unowned>
2LKREGMON Class Storage subpool lock (0x00038518): <unowned>
2LKREGMON CL Tables subpool lock (0x00038560): <unowned>
2LKREGMON JIT General subpool lock (0x000385A8): <unowned>
NULL
1LKFLATMONDUMP Thread identifiers (as used in flat monitors):
2LKFLATMON ident 0x08 "Framework Event Dispatcher" (0x713C6C8) ee 0x0713C4F0
2LKFLATMON ident 0x07 "State Data Manager" (0x7134360) ee 0x07134188
2LKFLATMON ident 0x05 "Finalizer" (0x23A5AD8) ee 0x023A5900
2LKFLATMON ident 0x04 "Reference Handler" (0x2431620) ee 0x02431448
2LKFLATMON ident 0x03 "Signal dispatcher" (0x242F140) ee 0x0242EF68
2LKFLATMON ident 0x02 "main" (0x2B1AE8) ee 0x002B1910
NULL
1LKOBJMONDUMP Java Object Monitor Dump (flat & inflated object-monitors):
2LKINFLATEDMON java.lang.ref.ReferenceQueue$Lock@102002D0/102002D8
3LKINFLDETAILS locknflags 80000400 Monitor inflated infl_mon 0x002BAE3C
2LKINFLATEDMON java.lang.ref.Reference$Lock@10200598/102005A0
3LKINFLDETAILS locknflags 80000200 Monitor inflated infl_mon 0x002BADE4
2LKFLATLOCKED org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl$Properties@103E3908/103E3910
3LKFLATDETAILS locknflags 00020000 Flat locked by thread ident 0x02, entry count 1
2LKFLATLOCKED org.eclipse.osgi.framework.internal.core.ServiceRegistryImpl @1044D588/1044D590
0SECTION XM subcomponent dump routine
NULL
1XMCURTHDINFO Current Thread Details
3XMTHREADINFO "Framework Event Dispatcher" (TID:0x101EB4F8, sys_thread_t:0x713C6C8, state:R, native ID:0x8FC) prio=5
1XMTHDINFO All Thread Details
NULL
2XMFULLTHDDUMP Full thread dump Classic VM (J2RE 1.4.2 IBM Windows 32 build cn142sr1a-20050209, native threads):
3XMTHREADINFO "State Data Manager" (TID:0x101EB560, sys_thread_t:0x7134360, state:CW, native ID:0xC74) prio=5
4XESTACKTRACE at java.lang.Thread.sleep(Native Method)
4XESTACKTRACE at org.eclipse.osgi.framework.adaptor.core.StateManager.run(Sta teManager.java:289)
4XESTACKTRACE at java.lang.Thread.run(Thread.java:568)
3XMTHREADINFO "Finalizer" (TID:0x101EB8B0, sys_thread_t:0x23A5AD8, state:CW, native ID:0xC8) prio=8
4XESTACKTRACE at java.lang.Object.wait(Native Method)
4XESTACKTRACE at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:144)
4XESTACKTRACE at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:160)
4XESTACKTRACE at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:2 11)
3XMTHREADINFO "Reference Handler" (TID:0x101EB908, sys_thread_t:0x2431620, state:CW, native ID:0xB28) prio=10
4XESTACKTRACE at java.lang.ref.Reference.process(Native Method)
4XESTACKTRACE at java.lang.ref.Reference.access$300(Reference.java:50)
4XESTACKTRACE at java.lang.ref.Reference$ReferenceHandler.run(Reference.java: 130)
3XMTHREADINFO "Signal dispatcher" (TID:0x101EB960, sys_thread_t:0x242F140, state:R, native ID:0x724) prio=5
3XMTHREADINFO "main" (TID:0x101EB9B8, sys_thread_t:0x2B1AE8, state:R, native ID:0x318) prio=5
4XESTACKTRACE at java.lang.Class.searchMethods(Class.java:2013)
4XESTACKTRACE at java.lang.Class.getMethod1(Class.java:2033)
4XESTACKTRACE at java.lang.Class.getMethod1(Class.java:2042)
4XESTACKTRACE at java.lang.Class.getMethod(Class.java:1076)
4XESTACKTRACE at org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl$Properties.cloneValue(ServiceRegistrationImpl.java:627)
4XESTACKTRACE at org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl$Properties.setProperty(ServiceRegistrationImpl.java:563 )
4XESTACKTRACE at org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl.createProperties(ServiceRegistrationImpl.java:263)
4XESTACKTRACE at org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl. <init>(ServiceRegistrationImpl.java:92)
4XESTACKTRACE at org.eclipse.osgi.framework.internal.core.BundleContextImpl.c reateServiceRegistration(BundleContextImpl.java:649)
4XESTACKTRACE at org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:601)
4XESTACKTRACE at org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:667)
4XESTACKTRACE at org.eclipse.core.runtime.adaptor.EclipseStarter.publishSplas hScreen(EclipseStarter.java:473)
4XESTACKTRACE at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:292)
4XESTACKTRACE at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:166)
4XESTACKTRACE at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
4XESTACKTRACE at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:85)
4XESTACKTRACE at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:58)
4XESTACKTRACE at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:60)
4XESTACKTRACE at java.lang.reflect.Method.invoke(Method.java:391)
4XESTACKTRACE at org.eclipse.core.launcher.Main.invokeFramework(Main.java:335 )
4XESTACKTRACE at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
4XESTACKTRACE at org.eclipse.core.launcher.Main.run(Main.java:987)
4XESTACKTRACE at org.eclipse.core.launcher.Main.main(Main.java:962)
0SECTION CL subcomponent dump routine
1CLCLASSPATH Classpath Z(c:\java\j9142sr1a\jre\lib\core.jar),Z(c:\java\j9142sr1a\jr e\lib\graphics.jar),Z(c:\java\j9142sr1a\jre\lib\security.jar ),Z(c:\java\j9142sr1a\jre\lib\server.jar),Z(c:\java\j9142sr1 a\jre\lib\xml.jar),Z(c:\java\j9142sr1a\jre\lib\charsets.jar) ,Z(c:\java\j9142sr1a\jre\lib\ibmcertpathprovider.jar),Z(c:\j ava\j9142sr1a\jre\lib\ibmjaasactivelm.jar),Z(c:\java\j9142sr 1a\jre\lib\ibmjaaslm.jar),Z(c:\java\j9142sr1a\jre\lib\ibmjce fw.jar),Z(c:\java\j9142sr1a\jre\lib\ibmjgssprovider.jar),Z(c :\java\j9142sr1a\jre\lib\ibmjssefips.jar),Z(c:\java\j9142sr1 a\jre\lib\ibmjsseprovider.jar),Z(c:\java\j9142sr1a\jre\lib\i bmorb.jar),Z(c:\java\j9142sr1a\jre\lib\ibmorbapi.jar),Z(c:\j ava\j9142sr1a\jre\lib\ibmpkcs.jar)
1CLFLAGOLDJAVA Oldjava mode false
1CLFLAGBOOTSTRP Bootstrapping false
1CLFLAGVERBOSE Verbose class dependencies false
1CLENUMVERIFY Class verification VERIFY_REMOTE
1CLPNTRNAMECLLO Namespace to classloader 0x00000000
1CLPNTRCHAINLO Start of cache entry pool 0x070A2008
1CLPNTRCHFREE Start of free cache entries 0x070A5C9C
1CLPNTRMETHODTB Location of method table 0x02399BA0
1CLPNTRANCHRGLN Global namespace anchor 0x002B296C
1CLPNTRCLSLOADS System classloader shadow 0x00366620
1CLPNTRSYSLOADS Classloader shadows 0x070EC008
1CLPNTRCLSEXT Extension loader 0x101EB830
1CLPNTRSYSLOADR System classloader 0x101EB7B0
1CLTEXTCLLOS Classloader summaries
1CLTEXTCLLSS 12345678: 1=primordial,2=extension,3=shareable,4=middleware,5=system,6 =trusted,7=application,8=delegating
2CLTEXTCLLOADER ------a- Loader org/eclipse/osgi/framework/adaptor/core/AbstractFrameworkAda ptor$ParentClassLoader(0x070EC008), Shadow 0x101EB5B8, Parent *none*(0x00000000)
3CLNMBRLOADEDCL Number of loaded classes 0
3CLNMBRCACHECLS Number of cached classes 0
3CLHEXDALLOCTIO Allocation used for loaded classes 1
3CLHEXDPCKGEOWN Package owner 0x101EB5B8
2CLTEXTCLLOADER ------a- Loader org/eclipse/core/runtime/internal/adaptor/ContextFinder(0x02 56F7E8), Shadow 0x101EB618, Parent sun/misc/Launcher$AppClassLoader(0x101EB7B0)
3CLHEXDPCKGEOWN Package owner 0x101EB618
2CLTEXTCLLOADER ------a- Loader org/eclipse/core/launcher/Main$StartupClassLoader(0x02552B08 ), Shadow 0x101EB678, Parent *none*(0x00000000)
3CLNMBRLOADEDCL Number of loaded classes 194
3CLNMBRCACHECLS Number of cached classes 310
3CLHEXDPCKGEOWN Package owner 0x101EB678
2CLTEXTCLLOADER -----ta- Loader sun/misc/Launcher$AppClassLoader(0x024F1A60), Shadow 0x101EB7B0, Parent sun/misc/Launcher$ExtClassLoader(0x101EB830)
3CLNMBRLOADEDCL Number of loaded classes 5
3CLNMBRCACHECLS Number of cached classes 275
3CLHEXDPCKGEOWN Package owner 0x101EB7B0
2CLTEXTCLLOADER -xh-st-- Loader sun/misc/Launcher$ExtClassLoader(0x024E3228), Shadow 0x101EB830, Parent *none*(0x00000000)
3CLHEXDALLOCTIO Allocation used for loaded classes 3
3CLHEXDPCKGEOWN Package owner 0x101EB830
2CLTEXTCLLOADER p-h-st-- Loader *System*(0x00366620), Shadow 0x00000000
3CLNMBRLOADEDCL Number of loaded classes 410
3CLNMBRCACHECLS Number of cached classes 411
3CLHEXDPCKGEOWN Package owner 0x00000000
1CLTEXTCLLOD ClassLoader loaded classes
2CLTEXTCLLOAD Loader org/eclipse/osgi/framework/adaptor/core/AbstractFrameworkAda ptor$ParentClassLoader(0x070EC008)
2CLTEXTCLLOAD Loader org/eclipse/core/runtime/internal/adaptor/ContextFinder(0x02 56F7E8)
2CLTEXTCLLOAD Loader org/eclipse/core/launcher/Main$StartupClassLoader(0x02552B08 )
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/ServiceReferenceImp l(0x101D4D00)
3CLTEXTCLASS org/eclipse/osgi/framework/console/CommandProvider(0x101D1C5 0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/StartLevelManager(0 x101D9570)
3CLTEXTCLASS org/eclipse/osgi/framework/debug/Debug(0x101DA870)
3CLTEXTCLASS org/eclipse/osgi/framework/eventmgr/EventManager$EventThread (0x101D06F0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/ServiceRegistry(0x101DC9B 0)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/EclipseStarter(0x101DEAF0)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/BundleDescriptionImpl$Laz yData(0x101D1660)
3CLTEXTCLASS org/eclipse/osgi/service/pluginconversion/PluginConversionEx ception(0x101D6390)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/SystemBundleData$1( 0x101D8730)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/AbstractBundleData(0 x101D8AC0)
3CLTEXTCLASS [Lorg/eclipse/osgi/framework/eventmgr/EventListeners$ListEle ment;(0x101D4970)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/EclipseElementFactory(0x101 D6850)
3CLTEXTCLASS [Lorg/eclipse/core/runtime/adaptor/EclipseStarter$InitialBun dle;(0x101DE040)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/BundleLocalization Impl(0x101D18C0)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/ExportPackageDescription(0 x101D32E0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/ServiceRegistration Impl$Properties(0x101D6F70)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/StateImpl(0x101D4120)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/StateManager(0x101D4 250)
3CLTEXTCLASS [Lorg/eclipse/osgi/service/resolver/ImportPackageSpecificati on;(0x101D1400)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/HostSpecification(0x101D35 40)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/URLConverterImpl(0 x101D1D80)
3CLTEXTCLASS org/eclipse/osgi/service/pluginconversion/PluginConverter(0x 101D44B0)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/EclipseAdaptor$DomParsingSe rvice(0x101D4710)
3CLTEXTCLASS org/osgi/framework/Filter(0x101DAE60)
3CLTEXTCLASS org/eclipse/osgi/service/debug/DebugOptions(0x101DB910)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/Locker(0x101DD460)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleLoaderProxy$R eexportPackageSource(0x101D0A80)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/BundleDescription(0x101D3A 00)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/SystemBundleData(0x 101D8BF0)
3CLTEXTCLASS org/osgi/framework/FrameworkEvent(0x101D0820)
3CLTEXTCLASS org/eclipse/osgi/internal/module/VersionSupplier(0x101D2240)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/protocol/URLStreamHandle rProxy(0x101D78F0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleURLConnection (0x101D6130)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/PackageSource(0x101 D0CE0)
3CLTEXTCLASS org/eclipse/osgi/framework/log/FrameworkLog(0x101DE9C0)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/VersionConstraint(0x101D36 70)
3CLTEXTCLASS org/osgi/util/tracker/ServiceTracker$AllTracked(0x101D7560)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/MessageResourceBund le$MessagesProperties(0x101DA610)
3CLTEXTCLASS org/eclipse/osgi/framework/debug/FrameworkDebugOptions(0x101 DBA40)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleLoader(0x101D 1070)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/BundleEntry$FileBund leEntry(0x101D6000)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/KeyedElement(0x101D B1F0)
3CLTEXTCLASS org/osgi/framework/BundleActivator(0x101D57B0)
3CLTEXTCLASS org/eclipse/osgi/framework/eventmgr/EventListeners(0x101D91E 0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/AbstractFrameworkAda ptor$ParentClassLoader(0x101DCAE0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/Framework(0x101DB6B 0)
3CLTEXTCLASS org/eclipse/osgi/service/urlconversion/URLConverter(0x101D1E B0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/PermissionStorage(0x101DC 030)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/State(0x101D3FF0)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/BasicLocation$Mock Locker(0x101DA150)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/BundleData(0x101DC750)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/protocol/ContentHandlerF actory(0x101D6AB0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/protocol/bundleresource/ Handler(0x101D8600)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/FilteredSourcePacka ge(0x101D0950)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/ManifestLocalizatio n$BundleResourceBundle(0x101D5420)
3CLTEXTCLASS org/osgi/framework/ServiceListener(0x101D7300)
3CLTEXTCLASS org/osgi/framework/ServicePermission(0x101DAC00)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/SystemBundleLoader( 0x101D0E10)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/BundleSpecification(0x101D 37A0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/reliablefile/ReliableFil e(0x101DA020)
3CLTEXTCLASS org/eclipse/osgi/internal/module/ResolverImpl(0x101D2370)
3CLTEXTCLASS org/eclipse/osgi/framework/eventmgr/EventDispatcher(0x101DB5 80)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/ClassLoaderDelegate(0x101 D0F40)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/Util(0x101D5A10)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/OSGi(0x101DDF10)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/BundleDescriptionImpl(0x1 01D2CF0)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/StateObjectFactoryImpl(0x 101D3B30)
3CLTEXTCLASS org/osgi/framework/InvalidSyntaxException(0x101DE500)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/EclipseBundleData(0x101D672 0)
3CLTEXTCLASS org/eclipse/osgi/framework/util/Headers(0x101D9A30)
3CLTEXTCLASS org/eclipse/osgi/framework/util/SecureAction(0x101DD200)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/StateObjectFactory(0x101D3 D90)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/reliablefile/ReliableFil eOutputStream(0x101DA280)
3CLTEXTCLASS org/osgi/framework/FrameworkListener(0x101DE760)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/protocol/bundleentry/Han dler(0x101D8990)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/FilteredServiceList ener(0x101D6D10)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/Tokenizer(0x101D990 0)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/StreamManagerOutputStream(0 x101DBCA0)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/EclipseAdaptor(0x101DCD40)
3CLTEXTCLASS org/osgi/framework/BundleException(0x101DE630)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/PackageAdminImpl(0x 101D97D0)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/EclipseStarter$1(0x101D05C0 )
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/SystemBundle(0x101D B0C0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/BundleOperation(0x101DC16 0)
3CLTEXTCLASS org/eclipse/osgi/internal/module/PermissionChecker(0x101D211 0)
3CLTEXTCLASS [Lorg/eclipse/osgi/framework/internal/core/AbstractBundle;(0 x101D5B40)
3CLTEXTCLASS org/eclipse/osgi/service/environment/EnvironmentInfo(0x101DD 920)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/IPluginInfo(0x101D 4380)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/PluginConverterImp l(0x101D45E0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/protocol/ContentHandlerP roxy(0x101D6980)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/ExportPackageDescriptionI mpl(0x101D2960)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/ManifestLocalizatio n(0x101D5550)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/EclipseCommandProv ider(0x101D1B20)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/UserState(0x101D31B0)
3CLTEXTCLASS org/osgi/framework/Constants(0x101D7DB0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/Constants(0x101D7EE 0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/BundleFile$ZipBundle File(0x101DC3C0)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/LocationManager(0x101DD7F0)
3CLTEXTCLASS org/eclipse/osgi/service/localization/BundleLocalization(0x1 01D19F0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/BundleEntry(0x101D84 D0)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/StateDelta(0x101D25D0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/KeyedHashSet(0x101D 5C70)
3CLTEXTCLASS [Lorg/eclipse/osgi/service/resolver/ExportPackageDescription ;(0x101D1530)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/ContextFinder$Find er(0x101DCE70)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/protocol/StreamHandlerFa ctory(0x101D7A20)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/BasicLocation(0x10 1DD590)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/StateReader(0x101D2F50)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/StreamManager(0x101D9C90)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/FileManager(0x101DA4E0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/ServiceRegistration Impl(0x101D4E30)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/SingleSourcePackage (0x101D0BB0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleContextImpl$2 (0x101D5680)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/BundleProtectionDomain(0x 101D7B50)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/PlatformAdmin(0x101DC880)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/reliablefile/ReliableFil eInputStream(0x101DA3B0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/ManifestLocalizatio n$EmptyResouceBundle(0x101D51C0)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/ContextFinder(0x10 1DD0D0)
3CLTEXTCLASS org/eclipse/osgi/framework/util/Headers$ArrayEnumeration(0x1 01D5090)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/ImportPackageSpecification (0x101D3410)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/Resolver(0x101D3C60)
3CLTEXTCLASS [Lorg/osgi/framework/ServiceReference;(0x101D6BE0)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/ImportPackageSpecificatio nImpl(0x101D2830)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/CachedManifest(0x1 01D64C0)
3CLTEXTCLASS org/osgi/framework/BundleContext(0x101DB7E0)
3CLTEXTCLASS org/osgi/util/tracker/ServiceTracker$Tracked(0x101D7430)
3CLTEXTCLASS org/osgi/framework/ServiceReference(0x101D8D20)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleFragment(0x10 1D8F80)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/SignedBundle(0x101DC 290)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/BundleEntry$DirZipBu ndleEntry(0x101D83A0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/FilePath(0x101D6260)
3CLTEXTCLASS org/osgi/framework/AllServiceListener(0x101D71D0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/EventPublisher(0x101DB450 )
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/ManifestLocalizatio n$LocalizationResourceBundle(0x101D52F0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleResourceHandl er(0x101D8860)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/AliasMapper(0x101DA 9A0)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/EclipseAdaptor$SaxParsingSe rvice(0x101D4840)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/BundleClassLoader(0x101D6 5F0)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/EclipseEnvironment Info(0x101DDA50)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleRepository(0x 101D5DA0)
3CLTEXTCLASS org/osgi/framework/Bundle(0x101DE3D0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/BundleEntry$ZipBundl eEntry(0x101D8270)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleLoaderProxy(0 x101D12D0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleHost(0x101DAF 90)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/StateBuilder(0x101D1790)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleContextImpl$1 (0x101D4F60)
3CLTEXTCLASS org/eclipse/osgi/framework/eventmgr/EventManager(0x101D9310)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/reliablefile/ReliableFil e$CacheInfo(0x101D9EF0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/MessageResourceBund le(0x101DA740)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/BundleInstaller(0x10 1DBF00)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/EclipseLog(0x101DD330)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleContextImpl(0 x101DAAD0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/BundleFile(0x101DC62 0)
3CLTEXTCLASS org/eclipse/osgi/framework/log/FrameworkLogEntry(0x101DE890)
3CLTEXTCLASS org/osgi/service/packageadmin/RequiredBundle(0x101D11A0)
3CLTEXTCLASS org/osgi/framework/AdminPermission(0x101DAD30)
3CLTEXTCLASS org/eclipse/osgi/framework/eventmgr/ListenerQueue(0x101D4AA0 )
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/BaseDescriptionImpl(0x101 D2E20)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/BundleResourcePermi ssion(0x101D8E50)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/BundleFile$DirBundle File(0x101DC4F0)
3CLTEXTCLASS org/osgi/util/tracker/ServiceTrackerCustomizer(0x101D77C0)
3CLTEXTCLASS org/osgi/framework/Version(0x101D8140)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/ServiceRegistryImpl (0x101D9B60)
3CLTEXTCLASS org/eclipse/osgi/internal/profile/ProfileLogger(0x101DDB80)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/EclipseStarter$InitialBundl e(0x101DE170)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/VersionConstraintImpl(0x1 01D2BC0)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/EclipseBundleInsta ller(0x101D3080)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/FilterImpl$Parser(0 x101D6E40)
3CLTEXTCLASS org/osgi/framework/ServiceEvent(0x101D4BD0)
3CLTEXTCLASS org/eclipse/osgi/util/ManifestElement(0x101D8010)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/AdaptorElementFactor y(0x101DBDD0)
3CLTEXTCLASS org/eclipse/core/runtime/internal/adaptor/ContextFinder$1(0x 101DCFA0)
3CLTEXTCLASS [Lorg/osgi/framework/Bundle;(0x101DE2A0)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/SystemState(0x101D3EC0)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/FilterImpl(0x101D70 A0)
3CLTEXTCLASS org/osgi/service/packageadmin/PackageAdmin(0x101D96A0)
3CLTEXTCLASS org/osgi/framework/ServiceRegistration(0x101D7C80)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/FrameworkAdaptor(0x101DDD E0)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/VersionRange(0x101D24A0)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/HostSpecificationImpl(0x1 01D2700)
3CLTEXTCLASS org/eclipse/osgi/service/resolver/BaseDescription(0x101D38D0 )
3CLTEXTCLASS org/osgi/util/tracker/ServiceTracker(0x101D7690)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/AbstractBundle(0x10 1DB320)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/BundleWatcher(0x101DBB70)
3CLTEXTCLASS org/eclipse/osgi/internal/profile/Profile(0x101DDCB0)
3CLTEXTCLASS org/eclipse/osgi/framework/eventmgr/EventListeners$ListEleme nt(0x101D90B0)
3CLTEXTCLASS org/osgi/framework/ServiceFactory(0x101D9440)
3CLTEXTCLASS org/eclipse/osgi/service/datalocation/Location(0x101DD6C0)
3CLTEXTCLASS [Lorg/eclipse/osgi/service/resolver/BundleDescription;(0x101 D1FE0)
3CLTEXTCLASS [Lorg/eclipse/osgi/framework/adaptor/BundleData;(0x101D5ED0)
3CLTEXTCLASS org/eclipse/core/runtime/adaptor/FileManager$Entry(0x101D9DC 0)
3CLTEXTCLASS org/eclipse/osgi/framework/adaptor/core/AbstractFrameworkAda ptor(0x101DCC10)
3CLTEXTCLASS org/eclipse/osgi/framework/internal/core/SystemBundleActivat or(0x101D58E0)
3CLTEXTCLASS org/eclipse/osgi/internal/resolver/BundleSpecificationImpl(0 x101D2A90)
2CLTEXTCLLOAD Loader sun/misc/Launcher$AppClassLoader(0x024F1A60)
3CLTEXTCLASS org/eclipse/core/launcher/Main(0x101DF0E0)
3CLTEXTCLASS org/eclipse/core/launcher/Main$EclipsePolicy(0x101DEE80)
3CLTEXTCLASS org/eclipse/core/launcher/Main$1(0x101DEFB0)
3CLTEXTCLASS org/eclipse/core/launcher/Main$Identifier(0x101DEC20)
3CLTEXTCLASS org/eclipse/core/launcher/Main$StartupClassLoader(0x101DED50 )
2CLTEXTCLLOAD Loader sun/misc/Launcher$ExtClassLoader(0x024E3228)
2CLTEXTCLLOAD Loader *System*(0x00366620)
3CLTEXTCLASS java/util/PropertyResourceBundle(0x024BD708)
3CLTEXTCLASS java/lang/ref/ReferenceQueue$Null(0x002D70E8)
3CLTEXTCLASS javax/xml/parsers/SAXParserFactory(0x024BEB38)
3CLTEXTCLASS com/ibm/bidiTools/bdlayout/BidiFlag(0x024BBF48)
3CLTEXTCLASS java/net/URLEncoder(0x024B9358)
3CLTEXTCLASS java/io/File(0x002DCEB8)
3CLTEXTCLASS sun/reflect/MagicAccessorImpl(0x002D0D28)
3CLTEXTCLASS java/io/SyncFailedException(0x024BCEB8)
3CLTEXTCLASS java/io/PrintWriter(0x024BC798)
3CLTEXTCLASS java/util/EventListener(0x024BC1A8)
3CLTEXTCLASS java/security/Principal(0x024B8518)
3CLTEXTCLASS java/util/jar/Attributes(0x024B6638)
3CLTEXTCLASS java/util/Collections$ReverseComparator(0x002DEB38)
3CLTEXTCLASS java/lang/StringCoding(0x002DD5D8)
3CLTEXTCLASS java/lang/OutOfMemoryError(0x002D3F08)
3CLTEXTCLASS java/util/Collections$SynchronizedCollection(0x024BE8D8)
3CLTEXTCLASS java/nio/charset/CodingErrorAction(0x024BDE28)
3CLTEXTCLASS com/ibm/jvm/Constants(0x024B9BA8)
3CLTEXTCLASS java/io/FilePermissionCollection(0x024B8058)
3CLTEXTCLASS sun/misc/Resource(0x024B6178)
3CLTEXTCLASS java/lang/reflect/ReflectAccess(0x002DAD78)
3CLTEXTCLASS java/lang/IncompatibleClassChangeError(0x002D7A68)
3CLTEXTCLASS java/lang/NoClassDefFoundError(0x002D0018)
3CLTEXTCLASS java/io/FilePermission(0x024B7F28)
3CLTEXTCLASS sun/net/www/MessageHeader(0x024B7DF8)
3CLTEXTCLASS java/util/jar/JarFile(0x024B4AE8)
3CLTEXTCLASS [Ljava/lang/reflect/Field;(0x024B36B8)
3CLTEXTCLASS sun/misc/NativeSignalHandler(0x024B11E8)
3CLTEXTCLASS com/ibm/io/FileExists(0x002DF978)
3CLTEXTCLASS [B(0x002D17D8)
3CLTEXTCLASS java/nio/ByteBuffer(0x024BE088)
3CLTEXTCLASS java/util/zip/ZipEntry(0x024B5208)
3CLTEXTCLASS java/nio/Buffer(0x024BE1B8)
3CLTEXTCLASS sun/io/MalformedInputException(0x024BB108)
3CLTEXTCLASS java/util/Random(0x002DE418)
3CLTEXTCLASS java/lang/ref/SoftReference(0x002DB6F8)
3CLTEXTCLASS java/lang/Package(0x024B62A8)
3CLTEXTCLASS sun/misc/Launcher$ExtClassLoader(0x024B16A8)
3CLTEXTCLASS java/util/Properties(0x002D49B8)
3CLTEXTCLASS java/util/MissingResourceException(0x024BD5D8)
3CLTEXTCLASS java/net/URLConnection(0x024B7A68)
3CLTEXTCLASS java/security/CodeSource(0x024B75A8)
3CLTEXTCLASS sun/io/ByteToCharConverter(0x024B6C28)
3CLTEXTCLASS sun/net/www/ParseUtil(0x024B2158)
3CLTEXTCLASS java/lang/ThreadLocal(0x002D8518)
3CLTEXTCLASS java/util/Comparator(0x002D11E8)
3CLTEXTCLASS java/io/UnsupportedEncodingException(0x024B89D8)
3CLTEXTCLASS java/util/zip/InflaterInputStream(0x024B57F8)
3CLTEXTCLASS java/io/PrintStream(0x024B0278)
3CLTEXTCLASS [Ljava/lang/Object;(0x002DA8B8)
3CLTEXTCLASS java/util/jar/Attributes$Name(0x002D8E98)
3CLTEXTCLASS sun/nio/cs/StreamDecoder$CharsetSD(0x024BDCF8)
3CLTEXTCLASS java/nio/charset/Charset(0x024BDBC8)
3CLTEXTCLASS sun/net/www/protocol/file/FileURLConnection(0x024B7808)
3CLTEXTCLASS java/util/HashMap(0x002D7348)
3CLTEXTCLASS java/lang/reflect/AccessibleObject(0x002D5A58)
3CLTEXTCLASS [D(0x002D2618)
3CLTEXTCLASS sun/nio/cs/StreamDecoder(0x024BA068)
3CLTEXTCLASS java/net/FileNameMap(0x024B9818)
3CLTEXTCLASS java/net/URLClassLoader$1(0x024B70E8)
3CLTEXTCLASS java/io/InputStreamReader(0x024B9F38)
3CLTEXTCLASS sun/nio/cs/StreamEncoder(0x024B0608)
3CLTEXTCLASS sun/reflect/NativeConstructorAccessorImpl(0x002DF388)
3CLTEXTCLASS sun/misc/SoftCache(0x002D6D58)
3CLTEXTCLASS java/lang/ClassNotFoundException(0x002D3918)
3CLTEXTCLASS java/io/Serializable(0x002D04D8)
3CLTEXTCLASS sun/security/util/Debug(0x024B1908)
3CLTEXTCLASS java/io/ObjectStreamException(0x002D95B8)
3CLTEXTCLASS java/util/AbstractList(0x002D2C08)
3CLTEXTCLASS sun/misc/Launcher$Factory(0x024B1448)
3CLTEXTCLASS java/security/Guard(0x002D6048)
3CLTEXTCLASS com/ibm/misc/BASE64Decoder(0x024B7348)
3CLTEXTCLASS java/io/ByteArrayInputStream(0x024B6508)
3CLTEXTCLASS java/util/jar/JarEntry(0x024B50D8)
3CLTEXTCLASS java/lang/ThreadLocal$ThreadLocalMap(0x002DD708)
3CLTEXTCLASS java/security/AccessController(0x002D63D8)
3CLTEXTCLASS java/security/BasicPermission(0x002D5DE8)
3CLTEXTCLASS java/security/AccessControlContext(0x002DB108)
3CLTEXTCLASS [[C(0x002D7F28)
3CLTEXTCLASS sun/reflect/DelegatingClassLoader(0x002D5338)
3CLTEXTCLASS java/io/IOException(0x002D4AE8)
3CLTEXTCLASS java/lang/String$CaseInsensitiveComparator(0x002D10B8)
3CLTEXTCLASS java/nio/charset/IllegalCharsetNameException(0x024BDA98)
3CLTEXTCLASS java/util/Arrays(0x024BCC58)
3CLTEXTCLASS java/io/FilterInputStream(0x002DC668)
3CLTEXTCLASS java/lang/reflect/Modifier(0x002DAC48)
3CLTEXTCLASS java/io/FileNotFoundException(0x002D4C18)
3CLTEXTCLASS [J(0x002D2158)
3CLTEXTCLASS java/io/BufferedOutputStream(0x002DFE38)
3CLTEXTCLASS sun/security/action/LoadLibraryAction(0x002DCD88)
3CLTEXTCLASS java/lang/reflect/InvocationTargetException(0x002DA2C8)
3CLTEXTCLASS java/io/InputStream(0x002D9818)
3CLTEXTCLASS java/lang/InterruptedException(0x002D3CA8)
3CLTEXTCLASS java/lang/Object(0x002D0278)
3CLTEXTCLASS java/lang/StringCoding$DecoderCache(0x024B6898)
3CLTEXTCLASS java/lang/ClassLoader$NativeLibrary(0x002DFAA8)
3CLTEXTCLASS java/io/WinNTFileSystem(0x002DD118)
3CLTEXTCLASS java/lang/Float(0x002D7478)
3CLTEXTCLASS java/io/CharConversionException(0x024BA528)
3CLTEXTCLASS java/security/BasicPermissionCollection(0x024B83E8)
3CLTEXTCLASS java/io/DataInputStream(0x024B5598)
3CLTEXTCLASS sun/misc/Unsafe(0x024B0BF8)
3CLTEXTCLASS java/io/FilenameFilter(0x024B1C98)
3CLTEXTCLASS java/io/FileOutputStream(0x002DC408)
3CLTEXTCLASS java/util/AbstractMap(0x002D6E88)
3CLTEXTCLASS java/security/PrivilegedActionException(0x002D4D48)
3CLTEXTCLASS java/lang/StackTraceElement(0x024BBCE8)
3CLTEXTCLASS java/text/Format(0x024B8D68)
3CLTEXTCLASS java/lang/SecurityException(0x024B8778)
3CLTEXTCLASS com/ibm/jvm/classloader/TransientAllocation(0x002D50D8)
3CLTEXTCLASS sun/net/www/protocol/file/Handler(0x024B2748)
3CLTEXTCLASS java/io/FileDescriptor(0x002DC1A8)
3CLTEXTCLASS java/util/HashMap$Entry(0x002D76D8)
3CLTEXTCLASS java/lang/reflect/Field(0x002D6898)
3CLTEXTCLASS java/util/Collection(0x002D2E68)
3CLTEXTCLASS [S(0x002D1C98)
3CLTEXTCLASS java/util/AbstractList$Itr(0x024BF128)
3CLTEXTCLASS javax/xml/parsers/DocumentBuilderFactory(0x024BEC68)
3CLTEXTCLASS java/lang/ClassCastException(0x024BC9F8)
3CLTEXTCLASS [Ljava/lang/StackTraceElement;(0x024BBE18)
3CLTEXTCLASS java/util/zip/ZipException(0x024B5CB8)
3CLTEXTCLASS java/lang/Compiler(0x024B3F08)
3CLTEXTCLASS java/net/URLClassLoader$ClassFinder(0x024B29A8)
3CLTEXTCLASS java/io/BufferedWriter(0x024B0998)
3CLTEXTCLASS sun/reflect/ConstructorAccessor(0x002D57F8)
3CLTEXTCLASS sun/net/www/protocol/jar/URLJarFile(0x024BAEA8)
3CLTEXTCLASS sun/net/www/protocol/jar/Handler(0x024B3B78)
3CLTEXTCLASS java/util/Collections(0x002DE2E8)
3CLTEXTCLASS sun/io/CharToByteConverter(0x002DE088)
3CLTEXTCLASS java/lang/ref/PhantomReference(0x002DBCE8)
3CLTEXTCLASS java/lang/IllegalArgumentException(0x002D3DD8)
3CLTEXTCLASS sun/misc/Cleaner(0x024BD4A8)
3CLTEXTCLASS sun/io/ConversionBufferFullException(0x024BA3F8)
3CLTEXTCLASS sun/misc/Launcher$1(0x024B1A38)
3CLTEXTCLASS java/util/StringTokenizer(0x002DF718)
3CLTEXTCLASS [Ljava/io/ObjectStreamField;(0x002D9358)
3CLTEXTCLASS java/lang/Character(0x002D7DF8)
3CLTEXTCLASS com/ibm/bidiTools/bdlayout/BidiText(0x024BB958)
3CLTEXTCLASS java/util/Collections$EmptyMap(0x002DEA08)
3CLTEXTCLASS java/io/DataOutput(0x002DA068)
3CLTEXTCLASS java/lang/Exception(0x002D36B8)
3CLTEXTCLASS java/util/zip/CRC32(0x024BCD88)
3CLTEXTCLASS sun/security/action/GetPropertyAction(0x002DC8C8)
3CLTEXTCLASS sun/reflect/ReflectionFactory$GetReflectionFactoryAction(0x0 02D6178)
3CLTEXTCLASS sun/misc/FileURLMapper(0x024B4758)
3CLTEXTCLASS sun/reflect/UnsafeObjectFieldAccessorImpl(0x024B37E8)
3CLTEXTCLASS java/lang/Runtime(0x002DBE18)
3CLTEXTCLASS java/util/List(0x002D2F98)
3CLTEXTCLASS java/net/URLConnection$1(0x024BA788)
3CLTEXTCLASS java/io/Reader(0x024B9E08)
3CLTEXTCLASS java/util/Hashtable$Enumerator(0x024B4298)
3CLTEXTCLASS java/lang/Boolean(0x002D7CC8)
3CLTEXTCLASS sun/reflect/MethodAccessor(0x002D5598)
3CLTEXTCLASS java/lang/ref/Reference(0x002DB368)
3CLTEXTCLASS com/ibm/bidiTools/bdlayout/BidiShape(0x024BBBB8)
3CLTEXTCLASS sun/misc/Launcher$AppClassLoader(0x024B3918)
3CLTEXTCLASS [Ljava/lang/String;(0x024B1EF8)
3CLTEXTCLASS java/security/PrivilegedAction(0x002D62A8)
3CLTEXTCLASS com/ibm/jvm/io/LocalizedInputStream$1(0x002DFD08)
3CLTEXTCLASS java/lang/ref/Reference$ReferenceHandler(0x002DB5C8)
3CLTEXTCLASS sun/reflect/Reflection(0x002D90F8)
3CLTEXTCLASS sun/net/www/MimeTable(0x024B96E8)
3CLTEXTCLASS java/util/jar/Manifest(0x024B63D8)
3CLTEXTCLASS [Ljava/security/cert/Certificate;(0x024B2D38)
3CLTEXTCLASS com/ibm/jvm/ExtendedSystem$3(0x002D8FC8)
3CLTEXTCLASS java/lang/System(0x002D6768)
3CLTEXTCLASS java/lang/IllegalStateException(0x024B5F18)
3CLTEXTCLASS java/lang/Terminator(0x024B0E58)
3CLTEXTCLASS java/util/Hashtable(0x002D4168)
3CLTEXTCLASS java/util/Stack(0x002D3328)
3CLTEXTCLASS java/lang/Compiler$1(0x024B4038)
3CLTEXTCLASS java/util/WeakHashMap(0x024BED98)
3CLTEXTCLASS java/io/BufferedReader(0x024B9CD8)
3CLTEXTCLASS java/util/jar/JavaUtilJarAccessImpl(0x024B4C18)
3CLTEXTCLASS java/io/Writer(0x024B04D8)
3CLTEXTCLASS sun/io/CharToByteCp1252(0x002DEEC8)
3CLTEXTCLASS java/lang/Cloneable(0x002D31F8)
3CLTEXTCLASS java/nio/HeapByteBuffer(0x024BE2E8)
3CLTEXTCLASS java/lang/StringCoding$4(0x002DDA98)
3CLTEXTCLASS sun/misc/Launcher$5(0x024BCFE8)
3CLTEXTCLASS java/util/zip/Checksum(0x024BCB28)
3CLTEXTCLASS java/util/jar/JarVerifier(0x024B6E88)
3CLTEXTCLASS java/io/ObjectInputStream(0x002D96E8)
3CLTEXTCLASS java/lang/Runnable(0x002D2878)
3CLTEXTCLASS java/io/FilterOutputStream(0x024B0018)
3CLTEXTCLASS java/lang/RuntimeException(0x002D37E8)
3CLTEXTCLASS java/io/ObjectStreamField(0x002D0F88)
3CLTEXTCLASS [Ljava/lang/reflect/Method;(0x024BC538)
3CLTEXTCLASS [Ljava/net/URL;(0x024B3CA8)
3CLTEXTCLASS java/lang/StringCoding$2(0x002DDBC8)
3CLTEXTCLASS com/ibm/jvm/io/ConsoleInputStream(0x002DC798)
3CLTEXTCLASS java/lang/Void(0x002D7B98)
3CLTEXTCLASS sun/reflect/UnsafeBooleanFieldAccessorImpl(0x024B3588)
3CLTEXTCLASS java/io/BufferedInputStream(0x002DC538)
3CLTEXTCLASS java/lang/InstantiationException(0x002DA198)
3CLTEXTCLASS java/util/Dictionary(0x002D4298)
3CLTEXTCLASS java/lang/CloneNotSupportedException(0x024BD248)
3CLTEXTCLASS sun/reflect/DelegatingMethodAccessorImpl(0x024B95B8)
3CLTEXTCLASS sun/io/Converters(0x002DDE28)
3CLTEXTCLASS java/io/FileSystem(0x002DCFE8)
3CLTEXTCLASS java/lang/Integer$1(0x002D83E8)
3CLTEXTCLASS java/lang/Class(0x002D0148)
3CLTEXTCLASS sun/net/www/protocol/jar/JarFileFactory(0x024BAD78)
3CLTEXTCLASS java/lang/IndexOutOfBoundsException(0x024B49B8)
3CLTEXTCLASS java/security/PrivilegedExceptionAction(0x002DDCF8)
3CLTEXTCLASS java/lang/SystemClassLoaderAction(0x024B3DD8)
3CLTEXTCLASS java/lang/VirtualMachineError(0x002D4038)
3CLTEXTCLASS sun/misc/Launcher(0x024B1318)
3CLTEXTCLASS [Ljava/lang/Thread;(0x002DB238)
3CLTEXTCLASS java/lang/Class$3(0x002D9228)
3CLTEXTCLASS java/lang/LinkageError(0x002D3A48)
3CLTEXTCLASS java/util/HashSet(0x024BEFF8)
3CLTEXTCLASS sun/misc/SignalHandler(0x024B10B8)
3CLTEXTCLASS java/util/Iterator(0x002D4888)
3CLTEXTCLASS java/util/zip/ZipFile$1(0x024B56C8)
3CLTEXTCLASS sun/misc/URLClassPath$JarLoader(0x024B44F8)
3CLTEXTCLASS java/lang/IllegalAccessException(0x002DA528)
3CLTEXTCLASS java/lang/UnsupportedOperationException(0x002DA3F8)
3CLTEXTCLASS java/lang/Short(0x002D8188)
3CLTEXTCLASS sun/io/CharToByteCp850(0x024B0868)
3CLTEXTCLASS java/lang/ref/FinalReference(0x002DB958)
3CLTEXTCLASS java/io/DataInput(0x002D9A78)
3CLTEXTCLASS java/lang/ref/ReferenceQueue$Lock(0x002D7218)
3CLTEXTCLASS sun/security/util/ManifestEntryVerifier(0x024B7218)
3CLTEXTCLASS com/ibm/bidiTools/bdlayout/ArabicOptionSet(0x024BB828)
3CLTEXTCLASS sun/io/ByteToCharSingleByte(0x024B90F8)
3CLTEXTCLASS java/security/cert/Certificate(0x024B2C08)
3CLTEXTCLASS java/util/Collections$EmptyList(0x002DE8D8)
3CLTEXTCLASS java/lang/NoSuchMethodError(0x002D7938)
3CLTEXTCLASS java/util/Enumeration(0x002D4628)
3CLTEXTCLASS com/ibm/bidiTools/bdlayout/BidiConvert(0x024BB238)
3CLTEXTCLASS sun/misc/SharedSecrets(0x024B4E78)
3CLTEXTCLASS sun/misc/URLClassPath(0x024B31F8)
3CLTEXTCLASS java/lang/ClassLoader$Finalizer(0x024B2878)
3CLTEXTCLASS java/io/ExpiringCache$Entry(0x002DF848)
3CLTEXTCLASS java/util/Collections$UnmodifiableMap(0x002DEC68)
3CLTEXTCLASS java/io/ObjectOutput(0x002D9F38)
3CLTEXTCLASS com/ibm/jvm/classloader/Shareable(0x002D4E78)
3CLTEXTCLASS java/net/URLClassLoader$2(0x024BD118)
3CLTEXTCLASS sun/net/www/MimeEntry(0x024BA658)
3CLTEXTCLASS java/lang/NumberFormatException(0x024B88A8)
3CLTEXTCLASS java/security/ProtectionDomain(0x024B3328)
3CLTEXTCLASS [Z(0x002D1578)
3CLTEXTCLASS sun/misc/URLClassPath$3(0x024B43C8)
3CLTEXTCLASS sun/reflect/ReflectionFactory$1(0x002DF258)
3CLTEXTCLASS [Ljava/io/File;(0x024BA9E8)
3CLTEXTCLASS sun/io/ByteToCharUTF8(0x024B6D58)
3CLTEXTCLASS com/ibm/bidiTools/bdlayout/BidiOrder(0x024BBA88)
3CLTEXTCLASS java/util/Locale(0x002DED98)
3CLTEXTCLASS java/net/URLDecoder(0x024B9228)
3CLTEXTCLASS java/lang/Math(0x024B5A58)
3CLTEXTCLASS java/lang/ref/Reference$Lock(0x002DB498)
3CLTEXTCLASS java/util/Map(0x002D43C8)
3CLTEXTCLASS java/net/UnknownContentHandler(0x024B7B98)
3CLTEXTCLASS com/ibm/jvm/ExtendedSystem$2(0x024B2AD8)
3CLTEXTCLASS sun/reflect/MethodAccessorImpl(0x002D5468)
3CLTEXTCLASS java/lang/CharSequence(0x002D0868)
3CLTEXTCLASS java/net/ContentHandler(0x024B7CC8)
3CLTEXTCLASS java/lang/reflect/Method(0x002D5928)
3CLTEXTCLASS [F(0x002D23B8)
3CLTEXTCLASS sun/reflect/FieldAccessorImpl(0x002D0BF8)
3CLTEXTCLASS sun/io/ByteToCharCp1252(0x024B8FC8)
3CLTEXTCLASS java/util/jar/Manifest$FastInputStream(0x024B6768)
3CLTEXTCLASS java/util/zip/ZipConstants(0x002DCC58)
3CLTEXTCLASS com/ibm/jvm/io/LocalizedInputStream(0x002DC9F8)
3CLTEXTCLASS [Ljava/lang/Class;(0x002DA9E8)
3CLTEXTCLASS java/security/UnresolvedPermission(0x024B82B8)
3CLTEXTCLASS java/net/Parts(0x024B24E8)
3CLTEXTCLASS java/io/ObjectStreamClass$FieldReflector(0x002DAB18)
3CLTEXTCLASS java/io/ObjectStreamConstants(0x002D9BA8)
3CLTEXTCLASS java/util/Map$Entry(0x002D7808)
3CLTEXTCLASS java/lang/Throwable(0x002D03A8)
3CLTEXTCLASS java/util/NoSuchElementException(0x024BC2D8)
3CLTEXTCLASS java/text/DateFormat(0x024B8C38)
3CLTEXTCLASS sun/misc/JarFilter(0x024B1B68)
3CLTEXTCLASS java/lang/StringCoding$EncoderCache(0x002DD968)
3CLTEXTCLASS sun/misc/Signal(0x002D8B08)
3CLTEXTCLASS java/lang/ref/Finalizer(0x002DBA88)
3CLTEXTCLASS java/util/EventObject(0x024BEA08)
3CLTEXTCLASS java/io/InvalidClassException(0x002D9488)
3CLTEXTCLASS [Ljava/lang/ThreadGroup;(0x002DAFD8)
3CLTEXTCLASS java/lang/StackOverflowError(0x002D5208)
3CLTEXTCLASS java/nio/charset/spi/CharsetProvider(0x024BE548)
3CLTEXTCLASS java/nio/charset/UnsupportedCharsetException(0x024BE418)
3CLTEXTCLASS sun/misc/JarIndex(0x024B4FA8)
3CLTEXTCLASS java/lang/reflect/Constructor(0x002D69C8)
3CLTEXTCLASS [I(0x002D1EF8)
3CLTEXTCLASS java/lang/NoSuchMethodException(0x024BC078)
3CLTEXTCLASS java/util/zip/Inflater(0x024B5928)
3CLTEXTCLASS com/ibm/jvm/io/FileOutputStream(0x002DC2D8)
3CLTEXTCLASS java/util/Hashtable$EmptyIterator(0x002D4758)
3CLTEXTCLASS sun/misc/MessageUtils(0x024BB498)
3CLTEXTCLASS sun/reflect/NativeMethodAccessorImpl(0x024B9488)
3CLTEXTCLASS java/net/MalformedURLException(0x024B8B08)
3CLTEXTCLASS java/util/AbstractSet(0x002DE678)
3CLTEXTCLASS java/lang/Long(0x002D8778)
3CLTEXTCLASS java/util/WeakHashMap$Entry(0x024BEEC8)
3CLTEXTCLASS java/lang/UnsatisfiedLinkError(0x024B2E68)
3CLTEXTCLASS java/net/URLClassLoader(0x024B17D8)
3CLTEXTCLASS java/util/zip/ZipFile(0x002DCB28)
3CLTEXTCLASS java/io/FileInputStream(0x002DC078)
3CLTEXTCLASS java/io/ObjectStreamClass(0x002D6C28)
3CLTEXTCLASS sun/reflect/FieldAccessor(0x002D0E58)
3CLTEXTCLASS java/lang/SecurityManager(0x024BC668)
3CLTEXTCLASS java/io/ObjectOutputStream(0x002D9CD8)
3CLTEXTCLASS java/lang/ref/ReferenceQueue(0x002D6FB8)
3CLTEXTCLASS java/lang/reflect/ReflectPermission(0x002D5CB8)
3CLTEXTCLASS java/util/Collections$SynchronizedSet(0x024BE7A8)
3CLTEXTCLASS com/ibm/bidiTools/bdlayout/BidiFlagSet(0x024BB6F8)
3CLTEXTCLASS sun/misc/JavaUtilJarAccess(0x024B4D48)
3CLTEXTCLASS java/lang/StringIndexOutOfBoundsException(0x024B4888)
3CLTEXTCLASS sun/reflect/ReflectionFactory(0x002D6508)
3CLTEXTCLASS com/ibm/jvm/classloader/Middleware(0x002D4FA8)
3CLTEXTCLASS java/net/JarURLConnection(0x024BAC48)
3CLTEXTCLASS sun/misc/URLClassPath$5(0x024B6048)
3CLTEXTCLASS java/util/ArrayList(0x024B1DC8)
3CLTEXTCLASS sun/nio/cs/StreamEncoder$ConverterSE(0x024B0738)
3CLTEXTCLASS java/util/Hashtable$EntrySet(0x024BE678)
3CLTEXTCLASS sun/misc/URLClassPath$FileLoader(0x024
Re: JVM crash on TPTP run [message #24425 is a reply to message #24384] |
Tue, 02 August 2005 16:58 |
If I turn on -verbose (with -Xj9) I get the following...
class load: java/util/Dictionary[]
class load: org/eclipse/osgi/service/resolver/ExportPackageDescription[]
class load: org/eclipse/osgi/service/resolver/VersionRange
class load: org/eclipse/osgi/service/resolver/BundleDescription[]
class load: org/eclipse/osgi/internal/module/ResolverImpl
class load: org/eclipse/osgi/internal/module/VersionSupplier
class load: org/eclipse/osgi/internal/module/ResolverBundle
class load: org/eclipse/osgi/internal/module/PermissionChecker
Unhandled exception
Type=GPF vmState=0x00000000
Target=2_20_20050124_1708_lHdSMR (Windows XP 5.1 build 2600 Service Pack 2)
CPU=x86 (1 logical CPUs) (0x1ff6c000 RAM)
ExceptionCode=c0000005 ExceptionAddress=1130B074 ContextFlags=0001003f
Handler1=1130B07C
Handler2=1130B080
EDI=00000083 ESI=00c87ac0 EAX=80676582 EBX=00c80000
ECX=000000ff EDX=00c87ac8 EBP=063ffdf4
EIP=7c91142e ESP=063ffbd4
Module=C:\WINDOWS\system32\ntdll.dll
Module_base_address=7c900000 Offset_in_DLL=0001142e
class load: org/eclipse/osgi/service/urlconversion/URLConverter
class load: org/eclipse/core/runtime/internal/adaptor/URLConverterImpl
class load: org/eclipse/osgi/framework/console/CommandProvider
class load: org/eclipse/core/runtime/internal/adaptor/EclipseCommandProv ider
class load: org/eclipse/osgi/service/localization/BundleLocalization
class load: org/eclipse/core/runtime/internal/adaptor/BundleLocalization Impl
class load: org/eclipse/osgi/internal/resolver/StateBuilder
class load:
JVMDUMP006I Processing Dump Event "gpf", detail "" - Please Wait.
JVMDUMP007I JVM Requesting System Dump using
'C:\DOCUME~1\dawood\LOCALS~1\Temp\core.20050802.125610.1304. dmp'
class load: org/eclipse/osgi/service/resolver/ImportPackageSpecification []
class load: java/util/AbstractList$Itr
class load: org/eclipse/osgi/framework/internal/core/SystemBundleLoader
class load: org/eclipse/osgi/framework/internal/core/PackageSource
class load: org/eclipse/osgi/framework/internal/core/SingleSourcePackage
class load:
class load: org/eclipse/osgi/framework/internal/core/FilteredSourcePacka ge
class load: org/eclipse/osgi/framework/internal/core/BundleFragment[]
class load: org/eclipse/osgi/framework/internal/core/BundleLoaderProxy[]
class load: org/osgi/framework/FrameworkEvent
class load: org/eclipse/osgi/framework/eventmgr/EventManager$EventThread
class load: org/eclipse/core/runtime/adaptor/EclipseStarter$1
class load: org/eclipse/osgi/framework/internal/protocol/reference/Handl er
class load:
org/eclipse/osgi/framework/internal/protocol/reference/Refer enceURLConnection
class load: org/eclipse/osgi/framework/internal/protocol/ProtocolActivat or
class load: org/eclipse/osgi/framework/internal/core/ReferenceInputStrea m
class load: org/eclipse/core/runtime/adaptor/EclipseStarter$InitialBundl e[]
class load: org/osgi/framework/Bundle[]
class load: org/osgi/service/startlevel/StartLevel
class load: org/eclipse/osgi/framework/internal/core/ServiceUse
class load: org/eclipse/osgi/framework/internal/core/ServiceUse$1
class load: org/eclipse/osgi/framework/internal/core/StartLevelImpl
class load: org/eclipse/osgi/framework/internal/core/ServiceUse$2
class load: org/eclipse/osgi/framework/internal/core/AbstractBundle$1
class load: org/eclipse/core/runtime/internal/adaptor/Semaphore
class load: org/eclipse/core/runtime/adaptor/EclipseStarter$4
class load: org/eclipse/osgi/framework/internal/core/StartLevelEvent
class load:
org/eclipse/osgi/framework/eventmgr/EventManager$EventThread $Queued
JVMDUMP010I System Dump written to
C:\DOCUME~1\dawood\LOCALS~1\Temp\core.20050802.125610.1304.d mp
JVMDUMP007I JVM Requesting Java Dump using
'C:\DOCUME~1\dawood\LOCALS~1\Temp\javacore.20050802.125617.1 304.txt'
JVMDUMP010I Java Dump written to
C:\DOCUME~1\dawood\LOCALS~1\Temp\javacore.20050802.125617.13 04.txt
JVMDUMP013I Processed Dump Event "gpf", detail "".
>> Navid Mehregani
>> IBM Canada
Re: JVM crash on TPTP run [message #24466 is a reply to message #23768] |
Tue, 02 August 2005 18:45 |
Originally posted by: carnevale.libero.it
I have the same problem with Windows 2000, Sun JDK 1.4.2_08, TPTP 4.0.0.0.
The JVM crashes in almost all cases. A log of one of its failures follows.
Dows someone know if a Bug exists for this?
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77FCC3A0
Function=RtlAllocateHeap+0x2B1
Library=C:\WINNT\system32\ntdll.dll
Current Java thread:
- waiting on <0x104fb860> (a java.lang.ref.Reference$Lock)
at java.lang.Object.wait(Object.java:429)
at java.lang.ref.Reference$ReferenceHandler.run(Reference.java: 115)
- locked <0x104fb860> (a java.lang.ref.Reference$Lock)
Dynamic libraries:
0x00400000 - 0x0040B000 C:\j2sdk1.4.2_08\jre\bin\java.exe
0x77F80000 - 0x77FFD000 C:\WINNT\system32\ntdll.dll
0x7C2D0000 - 0x7C332000 C:\WINNT\system32\ADVAPI32.dll
0x7C570000 - 0x7C623000 C:\WINNT\system32\KERNEL32.DLL
0x77D30000 - 0x77DA1000 C:\WINNT\system32\RPCRT4.DLL
0x78000000 - 0x78045000 C:\WINNT\system32\MSVCRT.dll
0x08000000 - 0x08138000 C:\j2sdk1.4.2_08\jre\bin\client\jvm.dll
0x77E10000 - 0x77E6F000 C:\WINNT\system32\USER32.dll
0x77F40000 - 0x77F7B000 C:\WINNT\system32\GDI32.dll
0x77570000 - 0x775A0000 C:\WINNT\system32\WINMM.dll
0x75E60000 - 0x75E7A000 C:\WINNT\system32\IMM32.DLL
0x6CA60000 - 0x6CA68000 C:\WINNT\system32\LPK.DLL
0x66650000 - 0x666A4000 C:\WINNT\system32\USP10.dll
0x10000000 - 0x10007000 C:\j2sdk1.4.2_08\jre\bin\hpi.dll
0x007D0000 - 0x007DE000 C:\j2sdk1.4.2_08\jre\bin\verify.dll
0x007E0000 - 0x007F9000 C:\j2sdk1.4.2_08\jre\bin\java.dll
0x00800000 - 0x0080E000 C:\j2sdk1.4.2_08\jre\bin\zip.dll
0x18170000 - 0x18205000 C:\Develop\hyades\bin\piAgent.dll
0x75030000 - 0x75044000 C:\WINNT\system32\WS2_32.dll
0x75020000 - 0x75028000 C:\WINNT\system32\WS2HELP.DLL
0x18210000 - 0x1821B000 C:\Develop\hyades\bin\hcclco.dll
0x18220000 - 0x18228000 C:\Develop\hyades\bin\hccldt.dll
0x18230000 - 0x18241000 C:\Develop\hyades\bin\hcclsm.dll
0x18250000 - 0x1825D000 C:\Develop\hyades\bin\hccls.dll
0x18260000 - 0x1826B000 C:\Develop\hyades\bin\hcbnd.dll
0x782C0000 - 0x782CC000 C:\WINNT\System32\rnr20.dll
0x77980000 - 0x779A4000 C:\WINNT\system32\DNSAPI.DLL
0x75050000 - 0x75058000 C:\WINNT\system32\WSOCK32.DLL
0x77340000 - 0x77353000 C:\WINNT\system32\iphlpapi.dll
0x77520000 - 0x77525000 C:\WINNT\system32\ICMP.DLL
0x77320000 - 0x77337000 C:\WINNT\system32\MPRAPI.DLL
0x75150000 - 0x7515F000 C:\WINNT\system32\SAMLIB.DLL
0x75170000 - 0x751BF000 C:\WINNT\system32\NETAPI32.DLL
0x7C340000 - 0x7C34F000 C:\WINNT\system32\Secur32.dll
0x77BF0000 - 0x77C01000 C:\WINNT\system32\NTDSAPI.dll
0x77950000 - 0x7797A000 C:\WINNT\system32\WLDAP32.DLL
0x751C0000 - 0x751C6000 C:\WINNT\system32\NETRAP.dll
0x77A50000 - 0x77B3F000 C:\WINNT\system32\OLE32.DLL
0x779B0000 - 0x77A4B000 C:\WINNT\system32\OLEAUT32.DLL
0x773B0000 - 0x773DF000 C:\WINNT\system32\ACTIVEDS.DLL
0x77380000 - 0x773A3000 C:\WINNT\system32\ADSLDPC.DLL
0x77830000 - 0x7783E000 C:\WINNT\system32\RTUTILS.DLL
0x77880000 - 0x7790E000 C:\WINNT\system32\SETUPAPI.DLL
0x7C0F0000 - 0x7C151000 C:\WINNT\system32\USERENV.DLL
0x774E0000 - 0x77513000 C:\WINNT\system32\RASAPI32.DLL
0x774C0000 - 0x774D1000 C:\WINNT\system32\RASMAN.DLL
0x77530000 - 0x77552000 C:\WINNT\system32\TAPI32.DLL
0x71710000 - 0x71794000 C:\WINNT\system32\COMCTL32.DLL
0x70A70000 - 0x70AD6000 C:\WINNT\system32\SHLWAPI.DLL
0x77360000 - 0x77379000 C:\WINNT\system32\DHCPCSVC.DLL
0x777E0000 - 0x777E8000 C:\WINNT\System32\winrnr.dll
0x777F0000 - 0x777F5000 C:\WINNT\system32\rasadhlp.dll
0x1CED0000 - 0x1CEDF000 C:\j2sdk1.4.2_08\jre\bin\net.dll
0x1CEE0000 - 0x1CEE8000 C:\j2sdk1.4.2_08\jre\bin\nio.dll
0x77920000 - 0x77943000 C:\WINNT\system32\imagehlp.dll
0x72A00000 - 0x72A2D000 C:\WINNT\system32\DBGHELP.dll
0x690A0000 - 0x690AB000 C:\WINNT\system32\PSAPI.DLL
Heap at VM Abort:
Heap
def new generation total 576K, used 0K [0x10010000, 0x100b0000,
0x104f0000)
eden space 512K, 0% used [0x10010000, 0x10010140, 0x10090000)
from space 64K, 0% used [0x100a0000, 0x100a0000, 0x100b0000)
to space 64K, 0% used [0x10090000, 0x10090000, 0x100a0000)
tenured generation total 5508K, used 4205K [0x104f0000, 0x10a51000,
0x14010000)
the space 5508K, 76% used [0x104f0000, 0x1090b6d0, 0x1090b800,
0x10a51000)
compacting perm gen total 4096K, used 1243K [0x14010000, 0x14410000,
0x18010000)
the space 4096K, 30% used [0x14010000, 0x14146d70, 0x14146e00,
0x14410000)
Local Time = Tue Aug 02 20:42:02 2005
Elapsed Time = 8
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_08-b03 mixed mode)
Another exception has been detected while we were handling last error.
Dumping information about last error:
ERROR REPORT FILE = hs_err_pid3376.log
PC = 0x77fcc3a0
SIGNAL = -1073741819
FUNCTION NAME = RtlAllocateHeap
OFFSET = 0x2B1
LIBRARY NAME = C:\WINNT\system32\ntdll.dll
Please check ERROR REPORT FILE for further information, if there is any.
Good bye.
# An error report file has been saved as hs_err_pid3376.log.
# Please refer to the file for further information.
Re: JVM crash on TPTP run [message #24507 is a reply to message #24384] |
Tue, 02 August 2005 20:16 |
Originally posted by: dawood.us.ibm.com
Hmmm. I tried profiling remotely from a different machine and things
worked fine, so this might have more to do with the remote client and
NOT the machine running the raserver. Not sure why, but it's a data point.
David
David Wood wrote:
> I'm having similar problems. My scenario uses 3.1.0 with the 4.0
> release of TPTP and required components EMF and XMI. I can successfully
> run the profiler against an raserver running on the same machine (call
> it A). The problem comes when I try and profile the same app on machine
> A from a remote machine running the same platform. I'm using the IBM
> Classic 1.4.2 JVM dated 12/2004 on the machine A. I've attached the
> java core file in case this helps. It does NOT seem to help to turn on
> -Djava.compiler=none as was suggested in a separate thread. All
> machines involved are running Windows XP.
> Thanks for any help.
> Navid Mehregani wrote:
>> Can you try using the IBM JRE instead:
>> http://www-307.ibm.com/pc/support/site.wss/document.do?sites tyle=lenovo&lndocid=MIGR-56888
>> You'll need to regen the agent controller's config file and to change
>> your JRE in the Eclipse workbench click on Windows->preferences->
>> Java-> installed JREs -> Add
>> Navid Mehregani
>> IBM Canada
Current Time: Thu Mar 28 09:53:26 GMT 2024
Powered by FUDForum. Page generated in 0.05780 seconds
