Remote Debug RCP Application [message #240183] |
Thu, 25 January 2007 10:35 |
Originally posted by: FIRSTNAME.LASTNAME.sphere.ae
Can I remote debug an Eclipse RCP Application? If so, please indicate me how
I have to set up Eclipse Remote Debugging for this issue.
Thanks in advance!
Re: Remote Debug RCP Application [message #240188 is a reply to message #240183] |
Sun, 28 January 2007 23:19 |
An Eclipse RCP app is just like any other Java app, so it would have to
be run in a debug-enabled JVM. The Eclipse Help contains lots of
information about setting up remote debugging, and this would be no
different.
Hope this helps,
Eric
Re: Remote Debug RCP Application [message #240209 is a reply to message #240188] |
Tue, 30 January 2007 20:57 |
Originally posted by: csae7511.uibk.ac.at
Start your exported RCP Application with
-vmargs -Xdebug
-Xrunjdwp:transport=dt_socket,address=8000,server=y,suspend= n
Then you need to create a new Remote Java Application run configuration
(in Run --> Debug ...). There you can specify the parameters for
connecting to your RCP.
HTH,
Stefan
Eric Rizzo schrieb:
>> me how I have to set up Eclipse Remote Debugging for this issue.
> different.
> Hope this helps,
> Eric
FUDForum. Page generated in 0.02253 seconds
