Home » Newcomers » Newcomers » Conflict in downloaded version and "installed" version(I have downloaded 64 eclipse for Java using "eclipse-java-kepler-SR2-win32-x86_64.zip" but eclipse.ini specifies 32 library "plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200)
icon9.gif  Conflict in downloaded version and "installed" version [message #1373217] Thu, 22 May 2014 04:45 Go to next message
Sachin Sharma is currently offline Sachin SharmaFriend
I have downloaded 64 eclipse for Java using eclipse-java-kepler-SR2-win32-x86_64.zip but eclipse.ini specifies 32 bit library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20120522-1813
I have 64 bit windows 7, 64 bit Java(1.7.0).
I am attaching the eclipse.ini
Am I doing something wrong?
  • Attachment: eclipse.ini
    (Size: 0.45KB, Downloaded 73 times)
Re: Conflict in downloaded version and "installed" version [message #1374016 is a reply to message #1373217] Thu, 22 May 2014 12:32 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
How did you "install" Eclipse? Did you extract the ZIP into a location where another version of Eclipse was already installed? I just downloaded and checked the ZIP you refer to, and its eclipse.ini definitely specifies the correct x86_64 library, not the 32-bit one you mentioned above.
Re: Conflict in downloaded version and "installed" version [message #1375587 is a reply to message #1374016] Fri, 23 May 2014 04:11 Go to previous message
Eric thanks for the quick response. I tried to provide the feedback below yesterday, but since the issue was under moderation so I couldn't.
Yes This could have happened. I deleted all files in the folder. then I re-extracted the files from the archive eclipse-java-kepler-SR2-win32-x86_64.zip. Now this is working fine.
By the way I extracted the files with the assumption that the eclipse does not get installed like normal/abnormal windows SW. I hope my assumption is right!
Previous Topic:How to indent any XML files with two spaces (instead of tab)
Next Topic:Eclipse marketplace can't confirm selected features to install
Current Time: Wed Nov 25 06:09:59 GMT 2020
Powered by FUDForum. Page generated in 0.03704 seconds
