Home » Eclipse Projects » SWTBot » SWTBotStyledText#navigateTo, line number vs. line index
SWTBotStyledText#navigateTo, line number vs. line index [message #23501] |
Fri, 20 February 2009 22:40 |
Joe Luebker Messages: 36 Registered: July 2009 |
Member |
Hello all,
I was using the SWTBotStyledText#navigateTo(line, column) method in a
test and discovered that the line is actually a line index. This is not
indicated in the comment for the method. A suggestion would be to make
this more clear in the comment of the function. The SWT StyledText
widget uses an 'index' argument in many methods to make this clear. See
below for the method in SWTBotStyledText:
* @param line the line numnber.
* @param column the column number.
* @see SWTBotStyledText#navigateTo(int, int)
public void navigateTo(int line, int column) {
styledText.navigateTo(line, column);
Also, a minor issue, there is a typo in the description of the line
argument - "numnber".
Joe
Re: SWTBotStyledText#navigateTo, line number vs. line index [message #23586 is a reply to message #23501] |
Sat, 21 February 2009 16:52 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
If you could attach a patch, that'd be great.
-- Ketan
On 21/2/09 04:10, Joe Luebker wrote:
> Hello all,
> Joe
Re: SWTBotStyledText#navigateTo, line number vs. line index [message #23713 is a reply to message #23586] |
Mon, 23 February 2009 16:42 |
Member |
I created a bug for this as Ketan Patel suggested,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=265841
I haven't created any patches for Eclipse projects yet. If the scope of
change for this issue is small (because I don't have much familiarity
with SWTBot code base yet) I can attempt to create a patch for this. Can
anyone provide a link to a good overview/guidelines for creating patches?
I have pulled the trunk branch of SWTBot code and have a subversion
plug-in installed that will allow me to create a patch I think. I just
haven't done it yet and don't have a complete SWTBot development
environment setup yet.
Joe
> -- Ketan
>> Hello all,
>> Thanks,
>> Joe
Re: SWTBotStyledText#navigateTo, line number vs. line index [message #23755 is a reply to message #23713] |
Mon, 23 February 2009 17:03 |
Hi Joe,
Assuming that you have imported the sources into your workspace, and
have everything compiling, you just open up the classes you need to
change, and rightclick on the project explorer>Team>Create Patch, and
upload the file on bugzilla.
If things aren't compiling because of dependencies, then you just need
to install swtbot from the update site, in your eclipse instance.
-- Ketan
> Joe
>> -- Ketan
>>> Hello all,
>>> Thanks,
>>> Joe
Current Time: Thu Mar 28 21:25:01 GMT 2024
Powered by FUDForum. Page generated in 0.03209 seconds
