Home » Language IDEs » Java Development Tools (JDT) » Is there an easy way to mass refactor packages?
Is there an easy way to mass refactor packages? [message #1369752] Tue, 20 May 2014 18:33 Go to next message
Jeff Falkenham is currently offline Jeff FalkenhamFriend
So I used to be a Java Master. Then I didn't touch it for like 2 or more years.
So I'm going through the tutorials, trying to actually keep proper notes this time, and trying to pick up new features and things I may have never known about because I never needed to use them (eg: while the "basic" tutorials are boring, they do have neat tidbits of information I never knew about, such as putting underscores in numeric literals: long creditCard = 1234_1234_1234_1234;).
And as the breadth of information increases, I want to keep my sample code more organized, so I need more packages:
http://i.imgur.com/80lTuJT.jpg
I want to move all 5 of my packages into the first.languagebasics package.
So "controlflow" becomes "first.languagebasics.controlflow", etc...
Is there an easy way to do this? Sure I can manually do it with 5 packages. But what about when my project gets bigger? Can you do mass refactoring of packages, and place them into a new parent?
Current solution: "refactor -> rename" all 5 packages individually.
Wanted solution: "refactor -> rename" or "refactor -> move" all 5 packages at once, in one action instead of 5 actions.
[Updated on: Tue, 20 May 2014 19:07]
Report message to a moderator
Re: Is there an easy way to mass refactor packages? [message #1369794 is a reply to message #1369752] Tue, 20 May 2014 18:56 Go to previous messageGo to next message
Nikolay Metchev is currently offline Nikolay MetchevFriend
http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.jdt.doc.user%2Freference%2Fref-menu-refactor.htm&resultof=%22rename%22%20%22renam%22%20%22subpackage%22%20%22subpackag%22%20
Sounds like you need to use the rename refactoring on the top package. Make sure you tick the rename sub packages option.
Re: Is there an easy way to mass refactor packages? [message #1369814 is a reply to message #1369794] Tue, 20 May 2014 19:06 Go to previous messageGo to next message
Nikolay Metchev wrote on Tue, 20 May 2014 14:56
The thing is, though, they aren't subpackages yet. They don't have a top package.
But in order to put them into a new top package, the only way to do so seems to be individually.
Re: Is there an easy way to mass refactor packages? [message #1369850 is a reply to message #1369814] Tue, 20 May 2014 19:27 Go to previous messageGo to next message
Noopur Gupta is currently offline Noopur GuptaFriend
Member
You can do that from "Navigator" view. Select folders (packages to move) > Right-click > Move...
However, it considers them as just resources and hence the references (import statements etc) are not updated.
Re: Is there an easy way to mass refactor packages? [message #1369869 is a reply to message #1369850] Tue, 20 May 2014 19:39 Go to previous messageGo to next message
Noopur Gupta wrote on Tue, 20 May 2014 15:27
That sounds like more work than "refactor->rename" individually.
Since they don't have a top package until I move them, I don't even have a string of text I can use for a mass "find/replace".
Re: Is there an easy way to mass refactor packages? [message #1370094 is a reply to message #1369869] Tue, 20 May 2014 21:52 Go to previous message
Try this,
First create the package you want them to go into. After that is done,
then do a select all of the classes you want to move, and then
mouse-button 2, refactor, move to... and select the package to move them
to. That should handle all of them at once.
Rich
Previous Topic:How to get (or set) what a class extends?
Next Topic: JFrame is not accessible due to restriction?
Current Time: Fri Jan 17 19:21:14 GMT 2025
Powered by FUDForum. Page generated in 0.03485 seconds
