Code to use connections with bending points [message #238981] |
Tue, 09 October 2007 15:38 |
Originally posted by: luis_dediego.yahoo.com
I have an editor where I have placed some elements. One of them is a
list of instances of a shape called ReferencePoint that try to represent
a path. Connecting them there are Polyline instances created using the
WireEditPart from the Flow example.
The lines are created, the connections can be selected but if I try to
create a new Bendingpoint by dragging the center point I got a
NullPointerException at
org.eclipse.gef.editpolicies.BendpointEditPolicy.showCreateB endpointFeedback(BendpointEditPolicy.java:312)
when trying to access the connection figure constraints. I get a null
instead an empty ArrayList.
I should have missed some code from the example but I am unable to found
where the constraint or any of such references gets created.
Please help. I have almost spent a whole day looking for a line of code
where I can create the constraint, even I have modified the original
code without success.
Thank you for any help.
Re: Code to use connections with bending points [message #239034 is a reply to message #238991] |
Wed, 10 October 2007 14:43 |
Hi, I have reviewed the code and it is true that the
getConnectionRouter() returns an instance of the default
PolylineConnection$RoutingNotifier that gives a
ConnectionRouter$NullConnectionRouter
This return a null constraint all times it is called. I have started to
review the original FLOW code to see where there is the setting for the
RoutingNotifier to check if that is the part I have forget.
Thank you for pointing my that direction.
Luis
Prakash wrote:
> I'm not sure, but why are you expecting an empty list? Digging thru the code, I can see that in PolylineConnection:
> public Object getRoutingConstraint() {
> if (getConnectionRouter() != null)
> return getConnectionRouter().getConstraint(this);
> else
> return null;
> So basically your connection route is null. Are you missing to set the BendpointConnectionRouter somewhere?
Re: Code to use connections with bending points [message #239037 is a reply to message #238991] |
Wed, 10 October 2007 15:07 |
I found the problem. I did not add the code to set the default Router on the connection layer of my diagram. I
located the code on the refreshVisuals() for the root diagram container and I added it to my our root
container and now the editing, creation and deletion of bending points works perfectly.
Thanks a lot for the help.
Luis
> else
> return null;
FUDForum. Page generated in 0.02080 seconds
