problem with eclipse editor plugin configuration [message #238283] |
Tue, 04 September 2007 13:05 |
Originally posted by: anderazpeitia.hotmail.com
hi,
I have a problem with a plug-in of G.E.F. editor i want to do for eclipse.
When i run new eclipse configuration "clasenotfound" error is given.
My plugin is very similar to the example called "flow" of G.E.F.
I have downloaded this example completely but i have problems with the configuration when i run it like a eclipse configuration.
(i don´t have any error to install the plugin) althrought i have the manifest and plugin.xml files.
If someone could help me or give me any advice i would thank a lot.
Re: problem with eclipse editor plugin configuration [message #238289 is a reply to message #238283] |
Tue, 04 September 2007 13:15 |
Ander,
Which class isn't found? Which plugin is that class in? Did you add
that project to the MANIFEST.MF of your plugin via the Dependencies tab
in the editor?
Ander wrote:
> hi,
FUDForum. Page generated in 0.02860 seconds
