Home » Archived » Maven Integration (M2E) » Import multi-module project from Bazaar SCM
Import multi-module project from Bazaar SCM [message #23156] Fri, 20 March 2009 16:44 Go to next message
Originally posted by: jonathan.magma.ca
I have just setup a new Eclipse 3.5M6 installation with a new workspace,
installed the required and optional prerequisites for M2Eclipse and then
installed M2Eclipse 0.9.7.200902090947 without problems.
The first operation I tried to perform was to import a multi-module
project from a Bazaar SCM. About half way through the import (3 modules
imported) I got an internal error report with the following details:
An internal error occurred during: "Importing Maven projects".
Attempted to beginRule:
MultiRule[P/bzr-eclipse,P/.org.eclipse.jdt.core.external.fol ders], does
not match outer scope rule:
org.maven.ide.eclipse.internal.project.SchedulingRule@5e20dc10
The complete error log contained the following:
!SESSION 2009-03-19 22:07:37.932
eclipse.buildId=I20090313-0100
java.version=1.6.0_12
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_CA
Command-line arguments: -os linux -ws gtk -arch x86_64 -clean
!ENTRY org.eclipse.ui.workbench 2 0 2009-03-19 22:07:57.358
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-03-19 22:07:57.358
!MESSAGE Conflict for
'AUTOGEN:::org.eclipse.jst.jee.ui.CreateDeploymentFilesActio n/createDeploymentFiles':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.jst.jee.ui .CreateDeploymentFilesAction/createDeploymentFiles,
handler=ActionDelegateHandlerProxy(null,org.eclipse.jst.jee. ui.internal.CreateDeploymentFilesActionDelegate),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@dc737be),sourcePriority=16384)
!SESSION 2009-03-19 22:10:32.206
!ENTRY org.eclipse.ui.workbench 2 0 2009-03-19 22:10:50.225
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-03-19 22:10:50.225
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@5b8099a),sourcePriority=16384)
!ENTRY org.eclipse.osgi 2 1 2009-03-19 22:21:45.518
!MESSAGE NLS unused message:
ValidationMessageFactory_DefaultElSeverityDisplayName in:
org.eclipse.jst.jsf.ui.internal.validation.messages
!ENTRY org.eclipse.osgi 2 1 2009-03-19 22:21:45.519
ValidationMessageFactory_DefaultTypeComparatorDisplayName in:
!SESSION 2009-03-19 22:28:02.337
!ENTRY org.eclipse.ui.workbench 2 0 2009-03-19 22:28:27.768
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-03-19 22:28:27.768
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@527a9c0f),sourcePriority=16384)
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2009-03-19
22:28:32.730
!MESSAGE No repository found at
file:/home/jonathan/Downloads/Eclipse/eclipse-3.5M6-mk2/conf iguration/org.eclipse.osgi/bundles/138/data/listener_1925729 951/.
!SESSION 2009-03-19 22:35:32.122
!ENTRY org.eclipse.ui.workbench 2 0 2009-03-19 22:35:50.118
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-03-19 22:35:50.118
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@7656acfa),sourcePriority=16384)
!SESSION 2009-03-20 08:24:33.315
!ENTRY org.eclipse.ui.workbench 2 0 2009-03-20 08:25:06.572
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-03-20 08:25:06.572
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@12f53870),sourcePriority=16384)
!ENTRY org.eclipse.core.jobs 4 2 2009-03-20 08:48:47.481
!MESSAGE An internal error occurred during: "Importing Maven projects".
!STACK 0
java.lang.IllegalArgumentException: Attempted to beginRule:
org.maven.ide.eclipse.internal.project.SchedulingRule@2c478134
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.internal.jobs.ThreadJob.illegalPush(ThreadJ ob.java:122)
at org.eclipse.core.internal.jobs.ThreadJob.push(ThreadJob.java :232)
at org.eclipse.core.internal.jobs.ImplicitJobs.begin(ImplicitJo bs.java:80)
at org.eclipse.core.internal.jobs.JobManager.beginRule(JobManag er.java:232)
at
org.eclipse.core.internal.resources.WorkManager.checkIn(Work Manager.java:117)
at
org.eclipse.core.internal.resources.Workspace.prepareOperati on(Workspace.java:1747)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1795)
at
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:793)
at
org.eclipse.jdt.internal.core.JavaProject.setRawClasspath(Ja vaProject.java:2836)
at
org.eclipse.jdt.internal.core.JavaProject.setRawClasspath(Ja vaProject.java:2867)
at
org.maven.ide.eclipse.jdt.internal.JavaProjectConfigurator.a ddMavenClasspathContainer(JavaProjectConfigurator.java:586)
at
org.maven.ide.eclipse.jdt.internal.JavaProjectConfigurator.c onfigure(JavaProjectConfigurator.java:90)
at
org.maven.ide.eclipse.internal.project.ProjectConfigurationM anager.updateProjectConfiguration(ProjectConfigurationManage r.java:292)
at
org.maven.ide.eclipse.internal.project.ProjectConfigurationM anager.configureNewMavenProject(ProjectConfigurationManager. java:215)
at
org.maven.ide.eclipse.internal.project.ProjectConfigurationM anager.importProjects(ProjectConfigurationManager.java:154)
at
org.maven.ide.eclipse.wizards.MavenProjectCheckoutJob$Checko utJobChangeListener$3.runInWorkspace(MavenProjectCheckoutJob .java:224)
at
org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
The project being imported is under active development so it is quite
likely that there are either questionable or possibly downright wrong
entries in the POM's. Right now I am looking for initial suggestions for
trouble-shooting as well as an initial assessment as to whether an issue
should be raised. I am willing to help in any way necessary to resolve
this issue. Just let me know what I should be doing. I have a reasonable
knowledge of Eclipse including some plug-in development a few years ago
but I am completely new to Maven.
Jonathan Gossage
Re: Import multi-module project from Bazaar SCM [message #23195 is a reply to message #23156] Fri, 20 March 2009 21:56 Go to previous message
Eugene Kuleshov is currently offline Eugene KuleshovFriend
Jonathan,
This is a known issue in m2eclipse when it is running on Eclipse 3.5
(not really related to Bazaar). Please use Eclipse 3.4.x until it is
fixed (hopefully in 0.9.8 build).
Eugene
> 22:28:32.730
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Thanks
> Jonathan Gossage
Previous Topic:[tycho] mvn package and NullPointerException
Next Topic:Add maven dependency?
Current Time: Mon Jan 27 01:02:41 GMT 2020
Powered by FUDForum. Page generated in 0.01920 seconds
