Re: No authentication service [message #23647 is a reply to message #23604] |
Wed, 25 March 2009 07:39 |
Stefan Liebig Messages: 124 Registered: July 2009 |
Hi Carsten,
The cause of this exception is that the RemoteLoginProxy is missing an
implementation of the IAuthenticationService service. A default
implementation is provided within the plugin
org.eclipse.riena.security.services. Maybe this is missing in your
sample app?
Documentation is available here:
- http://wiki.eclipse.org/Riena_Getting_started_security
- http://wiki.eclipse.org/Riena_Login_support
and of course:
- http://www.eclipse.org/equinox/incubator/security/
HTH
Tschüß,
Stefan
Carsten Spieker wrote:
> BTW: I have switched to Riena 1.1.0M6 now.
> "Carsten Spieker" <carsten.spieker@d-velop.de> schrieb im Newsbeitrag
> news:gqckib$1sj$1@build.eclipse.org...
>> Hey Frank,
>> the VM-argument you mentioned was existing in the app server launch
>> configuration...but the specified plugin
>> "org.eclipse.riena.security.simpleservice" not. After importing it into
>> workspace it works fine.
>> But when I take the login mechanism over to my own little sample
>> application I still get the following error when ILoginContext.login() is
>> performed:
>> javax.security.auth.login.LoginException: no authentication service
>> at
>> org.eclipse.riena.security.common.authentication.RemoteLogin Proxy.login(RemoteLoginProxy.java:79)
>> at
>> com.pa.eai.spieker.client.authentication.RemoteLoginModule.l ogin(RemoteLoginModule.java:96)
>> at
>> org.eclipse.equinox.security.auth.module.ExtensionLoginModul e.login(ExtensionLoginModule.java:61)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> at javax.security.auth.login.LoginContext.invoke(Unknown Source)
>> at javax.security.auth.login.LoginContext.access$000(Unknown Source)
>> at javax.security.auth.login.LoginContext$4.run(Unknown Source)
>> at java.security.AccessController.doPrivileged(Native Method)
>> at javax.security.auth.login.LoginContext.invokePriv(Unknown Source)
>> at javax.security.auth.login.LoginContext.login(Unknown Source)
>> at
>> org.eclipse.equinox.internal.security.auth.SecureContext.log in(SecureContext.java:50)
>> at
>> com.pa.eai.spieker.client.views.LoginDialogController.checkL ogin(LoginDialogController.java:142)
>> at
>> com.pa.eai.spieker.client.views.LoginDialogController.access $0(LoginDialogController.java:125)
>> at
>> com.pa.eai.spieker.client.views.LoginDialogController$1.call back(LoginDialogController.java:78)
>> at
>> org.eclipse.riena.internal.ui.ridgets.swt.ActionObserver.fir eAction(ActionObserver.java:63)
>> at
>> org.eclipse.riena.internal.ui.ridgets.swt.ActionObserver.wid getSelected(ActionObserver.java:34)
>> at
>> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
>> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
>> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
>> at
>> org.eclipse.riena.navigation.ui.swt.splashHandlers.AbstractL oginSplashHandler.doEventLoop(AbstractLoginSplashHandler.jav a:88)
>> at
>> org.eclipse.riena.navigation.ui.swt.splashHandlers.AbstractL oginSplashHandler.init(AbstractLoginSplashHandler.java:67)
>> at org.eclipse.ui.internal.Workbench$6.run(Workbench.java:605)
>> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
>> at
>> org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbe nch.java:621)
>> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2238)
>> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 09)
>> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:499)
>> at
>> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
>> at
>> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:492)
>> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
>> at
>> org.eclipse.riena.navigation.ui.swt.application.SwtApplicati on.createView(SwtApplication.java:62)
>> at
>> org.eclipse.riena.navigation.ui.application.AbstractApplicat ion.start(AbstractApplication.java:66)
>> at
>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
>> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 556)
>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:511)
>> at org.eclipse.equinox.launcher.Main.run(Main.java:1284)
>> at org.eclipse.equinox.launcher.Main.main(Main.java:1260)
>> Are there any documents or tutorials or something like that which can be
>> used to understand the whole Login mechanism with all the involved
>> components?
>> BTW: I´m working on Win32.
>> Greetz and Thanks!
>> Carsten
>> "Frank Schepp" <Frank.Schepp@compeople.de> schrieb im Newsbeitrag
>> news:gq87hj$ps2$1@build.eclipse.org...
>>> Hi Carsten,
>>> sorry, the launcher i wanted to mentioned is also in
>>> org.eclipse.riena.example.client and is named SWT
>>> ExampleApplication.product.launch. Please can you check/make sure that
>>> also the following VM
>>> argument -Djava.security.auth.login.config==${workspace_loc}\org.ecli pse.riena.security.simpleservices\config\sample_jaas.config
>>> is present in the launch configuration of Riena Sample App Server (the
>>> exception indicates that information provided by this file is missing)?!
>>> By the way on which OS platform you are on?
>>> regards, Frank
>>>> Hi Frank,
>>>> I use the product "example_product" defined in plugin
>>>> "org.eclipse.riena.example.client".
>>>> I cannot find the launcher you mentioned. Where can I find it?
>>>> Here the stacktrace the Sample App Server gives:
>>>> WARNUNG:
>>>> org.eclipse.riena.security.common.authentication.Authenticat ionFailure:
>>>> AuthenticationService login failed
>>>> at
>>>> org.eclipse.riena.internal.security.authenticationservice.Au thenticationService.login(AuthenticationService.java:146)
>>>> at
>>>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
>>>> at
>>>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
>>>> at java.lang.reflect.Method.invoke(Method.java:597)
>>>> at
>>>> org.eclipse.riena.communication.core.hooks.AbstractHooksProx y.invoke(AbstractHooksProxy.java:69)
>>>> at
>>>> org.eclipse.riena.communication.core.hooks.AbstractHooksProx y.invoke(AbstractHooksProxy.java:38)
>>>> at
>>>> org.eclipse.riena.internal.communication.publisher.ServiceHo oksProxy.invoke(ServiceHooksProxy.java:70)
>>>> at $Proxy13.login(Unknown Source)
>>>> at
>>>> at
>>>> at
>>>> com.caucho.hessian.server.HessianSkeleton.invoke(HessianSkel eton.java:155)
>>>> at
>>>> org.eclipse.riena.communication.publisher.hessian.RienaHessi anDispatcherServlet.service(RienaHessianDispatcherServlet.ja va:147)
>>>> at
>>>> org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
>>>> at
>>>> org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
>>>> at
>>>> org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
>>>> at
>>>> org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:67)
>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
>>>> at
>>>> org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:269)
>>>> at
>>>> org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
>>>> at
>>>> org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
>>>> at
>>>> org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
>>>> at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
>>>> at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
>>>> at org.mortbay.http.HttpServer.service(HttpServer.java:909)
>>>> at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
>>>> at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
>>>> at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
>>>> at
>>>> org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
>>>> at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
>>>> at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
>>>> Caused by: javax.security.auth.login.LoginException: Für CentralSecurity
>>>> sind keine Anmeldemodule konfiguriert.
>>>> at javax.security.auth.login.LoginContext.init(LoginContext.jav a:256)
>>>> at javax.security.auth.login.LoginContext.<init>(LoginContext.java:403)
>>>> at
>>>> org.eclipse.equinox.internal.security.auth.SecureContext.get LoginContext(SecureContext.java:98)
>>>> at
>>>> org.eclipse.equinox.internal.security.auth.SecureContext.log in(SecureContext.java:46)
>>>> at
>>>> org.eclipse.riena.internal.security.authenticationservice.Au thenticationService.login(AuthenticationService.java:125)
>>>> ... 32 more
>>>> Greetz
>>>> Carsten
>>>> news:gq7n3l$b90$1@build.eclipse.org...
>>>>> Hi Carsten,
>>>>> which example are you using? Did you try launcher SWT SCP
>>>>> ExampleApplication.product (client) and Riena Sample App Server? Which
>>>>> riena version are you using? Could you please provide a stacktrace?
>>>>> Regards, Frank
>>>>>> Hi,
>>>>>> I´m playing around with the Riena sample applications.
>>>>>> When I try to learn more about the riena login support I´m reaching my
>>>>>> limits quite early.
>>>>>> I always get the message "Log-in failed" which is caused by an
>>>>>> LoginException "No authentication service".
>>>>>> I´m quite new to riena and Java Security. Can anyone help me
>>>>>> understanding or simply using the login support?
>>>>>> Thanks and greetz
>>>>>> Carsten
Re: No authentication service [message #581497 is a reply to message #23604] |
Hi Carsten,
sample app?
and of course:
HTH
Tschüß,
Stefan
>> Hey Frank,
>> performed:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> components?
>> Greetz and Thanks!
>> Carsten
>>> Hi Carsten,
>>> regards, Frank
>>>> Hi Frank,
>>>> WARNUNG:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 32 more
>>>> Greetz
>>>> Carsten
>>>>> Hi Carsten,
>>>>> Regards, Frank
>>>>>> Hi,
>>>>>> limits quite early.
>>>>>> Thanks and greetz
>>>>>> Carsten
FUDForum. Page generated in 0.26817 seconds
