Problem with figures in draw2d [message #236432] |
Wed, 27 June 2007 17:25 |
Originally posted by: martin.lindblad.gmail.com
Hi!
I'm trying to use gradients on my figures, using draw2d. But I have some
trouble with that. In the paint method of the root figure, I use the
setBackgroundPattern, and to make it visible I call the method
fillRectangle. But that make all my other childfigures disappear because
of the fillRectangle method.
Is there a way to make gradients on figures instead of using the Graphic
object? Or how can I otherwise solve th problem?
Many thanks
Martin
Re: Problem with figures in draw2d [message #236453 is a reply to message #236439] |
Wed, 27 June 2007 21:15 |
Thanks Anthony
It worked great for all figures except for the root figure that is of
type FreeformLayer. Do you know what to to about that one?
One more thing. I do require zoom, do you know if there is a workaround
for solving that problem?
Thanks again
Martin
Anthony Hunter skrev:
> Hi Martin,
> Attached is an example for a GradientRectangleFigure.
> Note that setBackgroundPattern() is not implemented by ScaledGraphics. This
> may be a problem for you if you require zoom or print support.
> Cheers...
> Anthony
> "Martin" <martin.lindblad@gmail.com> wrote in message
> news:f5u6ij$44t$2@build.eclipse.org...
>> Hi!
>> Many thanks
>> Martin
FUDForum. Page generated in 0.04834 seconds
