LinkageError in Scout [message #1357496] |
Thu, 15 May 2014 14:53 |
Hi all,
now when I start my application in SWT and press the first character to write the username, return immediately the error message show below:
And in the console I found the following messages:
!MESSAGE Unable to create class 'org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon' from bundle '72'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.LinkageError: loader constraint violation: when resolving interface method "org.eclipse.e4.ui.bindings.EBindingService.createBinding(Lorg/eclipse/jface/bindings/TriggerSequence;Lorg/eclipse/core/commands/ParameterizedCommand;Ljava/lang/String;Ljava/util/Map;)Lorg/eclipse/jface/bindings/Binding;" the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current class, org/eclipse/e4/ui/workbench/swt/util/BindingProcessingAddon, and the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) for resolved class, org/eclipse/e4/ui/bindings/EBindingService, have different Class objects for the type org/eclipse/jface/bindings/Binding used in the signature
Caused by: java.lang.LinkageError: loader constraint violation: when resolving interface method "org.eclipse.e4.ui.bindings.EBindingService.createBinding(Lorg/eclipse/jface/bindings/TriggerSequence;Lorg/eclipse/core/commands/ParameterizedCommand;Ljava/lang/String;Ljava/util/Map;)Lorg/eclipse/jface/bindings/Binding;" the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current class, org/eclipse/e4/ui/workbench/swt/util/BindingProcessingAddon, and the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) for resolved class, org/eclipse/e4/ui/bindings/EBindingService, have different Class objects for the type org/eclipse/jface/bindings/Binding used in the signature
!ENTRY org.eclipse.core.net 4 0 2014-05-15 16:37:03.633
!MESSAGE WinHttp.DetectAutoProxyConfigUrl for wpad failed with error 'Can not find the URL of the proxy auto-configuration.' #12180.
!ENTRY org.eclipse.core.jobs 4 2 2014-05-15 16:42:48.657
!MESSAGE LockManager.handleException
!STACK 0
java.lang.reflect.UndeclaredThrowableException
at org.eclipse.scout.rt.ui.swt.login.internal.InternalNetAuthenticator$1.run(InternalNetAuthenticator.java:112)
at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockListener.java:164)
at org.eclipse.ui.internal.UILockListener.aboutToWait(UILockListener.java:126)
at org.eclipse.core.internal.jobs.LockManager.aboutToWait(LockManager.java:123)
at org.eclipse.core.internal.jobs.JobManager.join(JobManager.java:845)
at org.eclipse.core.internal.jobs.InternalJob.join(InternalJob.java:380)
at org.eclipse.core.runtime.jobs.Job.join(Job.java:385)
at org.eclipse.scout.rt.ui.swt.AbstractSwtEnvironment.createAndStartClientSession(AbstractSwtEnvironment.java:497)
at org.eclipse.scout.rt.ui.swt.AbstractSwtEnvironment.init(AbstractSwtEnvironment.java:391)
at org.eclipse.scout.rt.ui.swt.AbstractSwtEnvironment.ensureInitialized(AbstractSwtEnvironment.java:362)
at org.eclipse.scout.rt.ui.swt.AbstractSwtStartup$P_InitWorkbenchJob.runInUIThread(AbstractSwtStartup.java:102)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1045)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:940)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:587)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:542)
at org.zeiss.mo.scout.CZVEDIController.ui.swt.application.Application.startSecure(Application.java:45)
at org.zeiss.mo.scout.CZVEDIController.ui.swt.application.Application$1.run(Application.java:37)
at javax.security.auth.Subject.doAs(Unknown Source)
at org.zeiss.mo.scout.CZVEDIController.ui.swt.application.Application.start(Application.java:34)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.LinkageError: loader constraint violation: loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) previously initiated loading for a different type with name "org/eclipse/swt/widgets/Event"
at org.eclipse.jface.bindings.keys.SWTKeySupport.convertEventToUnmodifiedAccelerator(SWTKeySupport.java:95)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.generatePossibleKeyStrokes(KeyBindingDispatcher.java:142)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:323)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:314)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:83)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
at org.eclipse.swt.widgets.Text.sendKeyEvent(Text.java:1704)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1100)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1521)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4640)
at org.eclipse.swt.widgets.Text.WM_CHAR(Text.java:2584)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4528)
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2570)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
at org.eclipse.scout.rt.ui.swt.login.internal.LoginDialog.open(LoginDialog.java:50)
at org.eclipse.scout.rt.ui.swt.login.internal.InternalNetAuthenticator.showModalDialog(InternalNetAuthenticator.java:137)
at org.eclipse.scout.rt.ui.swt.login.internal.InternalNetAuthenticator.access$0(InternalNetAuthenticator.java:101)
at org.eclipse.scout.rt.ui.swt.login.internal.InternalNetAuthenticator$1.run(InternalNetAuthenticator.java:109)
... 41 more
!ENTRY org.eclipse.scout.rt.client 4 0 2014-05-15 16:42:48.657
!MESSAGE org.eclipse.scout.rt.client.AbstractClientSession.startSession(AbstractClientSession.java:264) load session
!STACK 0
at $Proxy14.getAllCodeTypeClasses(Unknown Source)
at org.eclipse.scout.rt.client.services.common.code.CodeServiceClientProxy.getAllCodeTypeClasses(CodeServiceClientProxy.java:342)
at org.eclipse.scout.rt.client.services.common.code.CodeServiceClientProxy.getAllCodeTypes(CodeServiceClientProxy.java:363)
at org.eclipse.scout.rt.shared.services.common.code.CODES.getAllCodeTypes(CODES.java:64)
at org.zeiss.mo.scout.CZVEDIController.client.ClientSession.execLoadSession(ClientSession.java:36)
at org.eclipse.scout.rt.client.AbstractClientSession.startSession(AbstractClientSession.java:259)
at org.eclipse.scout.rt.client.services.common.session.internal.ClientSessionRegistryService$1.runVoid(ClientSessionRegistryService.java:70)
at org.eclipse.scout.rt.client.ClientJob.runStatus(ClientJob.java:189)
at org.eclipse.scout.rt.client.ClientJob.runTransactionWrapper(ClientJob.java:172)
at org.eclipse.scout.rt.client.ClientJob.run(ClientJob.java:159)
at org.eclipse.scout.commons.job.JobEx.runNow(JobEx.java:50)
at org.eclipse.scout.rt.client.services.common.session.internal.ClientSessionRegistryService.createAndStartClientSession(ClientSessionRegistryService.java:74)
at org.eclipse.scout.rt.client.services.common.session.internal.ClientSessionRegistryService.newClientSession(ClientSessionRegistryService.java:45)
at org.eclipse.scout.rt.ui.swt.AbstractSwtEnvironment$3.run(AbstractSwtEnvironment.java:489)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: ProcessingException[ProcessingStatus[ERROR code=0 Calling ICodeService.getAllCodeTypeClasses() org.eclipse.scout.rt.shared.servicetunnel.HttpException: 401 - UNAUTHORIZED]]
at org.eclipse.scout.rt.client.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:163)
at org.eclipse.scout.rt.client.servicetunnel.http.internal.InternalHttpServiceTunnel.invokeService(InternalHttpServiceTunnel.java:175)
at org.eclipse.scout.rt.client.servicetunnel.http.HttpServiceTunnel.invokeService(HttpServiceTunnel.java:115)
at org.eclipse.scout.rt.client.servicetunnel.ServiceTunnelInvocationHandler.invoke(ServiceTunnelInvocationHandler.java:47)
at org.eclipse.scout.rt.client.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:167)
... 15 more
Caused by: org.eclipse.scout.rt.shared.servicetunnel.HttpException: 401 - UNAUTHORIZED
at org.eclipse.scout.rt.client.servicetunnel.http.internal.HttpBackgroundJob.runStatus(HttpBackgroundJob.java:85)
... 1 more
Also when I start my application in RAP, return a similar error.
I already try:
- validate the various .product
- check if there are errors in the various plugin.xml
- clean and rebuild all project
I use Eclipse Juno 3.8 with Scout.
Anyone have a suggestion to solve this situation?
Thanks in advance for any help
Re: LinkageError in Scout [message #1366167 is a reply to message #1359176] |
Mon, 19 May 2014 07:26 |
Ok, now I solved this problem in the following ways:
- Remove totally my Eclipse IDE + Scout
- Download a new version of Eclipse Juno
- Download a new version of Scout for Juno IDE
- Install Eclipse Juno in new folder
- Apply Scout to my new Eclipse IDE just installed
- Check online for the update
- In my case, I downloaded my project from my SVN repository
after all this, the error that I reported disappeared.
FUDForum. Page generated in 0.02320 seconds
