Tooltip extra large [message #234860] |
Thu, 31 May 2007 15:15 |
Originally posted by: bch.openbluelab.org
When I create a tool tip on an element with a label, the tool tip is
very big.
Label labelView = new Label(text);
labelView.setSize(10, 10);
((ClasseFigure) getFigure()).setToolTip(labelView);
Have you an idea ?
Re: Tooltip extra large [message #235158 is a reply to message #235145] |
Wed, 06 June 2007 07:30 |
I use Windows XP so I understand why the tooltip is not resized. So have
you a solution to reduce the size of my tooltip ?
Anthony Hunter a écrit :
> Hi Benjamin,
> What platform are you using? setSize() on windows has no affect on the
> tooltip.
> Cheers...
> Anthony
> "Benjamin CHEVALLEREAU" <bch@openbluelab.org> wrote in message
> news:f3mopv$vdd$1@build.eclipse.org...
>> Hi,
>> very big.
>> Have you an idea ?
>> Thanks
Re: Tooltip extra large [message #235201 is a reply to message #235188] |
Wed, 06 June 2007 14:52 |
--------------020109010302030108000409
The question is why I have a big tooltip ?
Thanls
Anthony Hunter a
Re: Tooltip extra large [message #235298 is a reply to message #235260] |
Fri, 08 June 2007 08:22 |
I use Topcased wich permit to generate simply an editor; topcased is
based on GEF and the team Topcased say me that I must post my question
on GEF. The team topcased have never used tool tip so they don't know if
they have the same problem.
> Hi Benjamin,
> I cannot duplicate this with the GEF examples I have. What is special about
> the diagram? Can you duplicate this somewhere other than your code? (This
> may be a stretch, but are you using GMF?)
> Cheers...
> Anthony
> news:f46ho6$8nb$1@build.eclipse.org...
>> Hi
>> Thanls
>>> Hi Benjamin,
>>> I tried your snippet and it worked as I expected on windows XP. What is
>>> the
>>> question? Perhaps a screenshot of what you are looking for?
>>> Cheers...
>>> Anthony
>>> news:f45nr6$vpo$1@build.eclipse.org...
>>>> Thanks
>>>>> Hi Benjamin,
>>>>> tooltip.
>>>>> Cheers...
>>>>> Anthony
>>>>>> Hi,
>>>>>> very big.
>>>>>> Have you an idea ?
>>>>>> Thanks
Re: Tooltip extra large [message #240350 is a reply to message #235298] |
Mon, 24 December 2007 14:25 |
Originally posted by: trommas.yahoo.com
How can the size of the tooltip be set?
I get a long line of characters, when really what I want is a box
(textarea) - like eclipse makes.
Merry Christmas,
Tomas Zijdemans
Benjamin CHEVALLEREAU wrote:
> Hi
> Thanks
>> Hi Benjamin,
>> about the diagram? Can you duplicate this somewhere other than your
>> code? (This may be a stretch, but are you using GMF?)
>> Cheers...
>> Anthony
>>> Hi
>>> Thanls
>>>> Hi Benjamin,
>>>> is the
>>>> Cheers...
>>>> Anthony
>>>>> have
>>>>> Thanks
>>>>>> Hi Benjamin,
>>>>>> the
>>>>>> tooltip.
>>>>>> Cheers...
>>>>>> Anthony
>>>>>>> Hi,
>>>>>>> very big.
>>>>>>> Have you an idea ?
>>>>>>> Thanks
Re: Tooltip extra large [message #240541 is a reply to message #235298] |
Wed, 09 January 2008 18:28 |
Jacques LESCOT Messages: 247 Registered: July 2009 |
Benjamin,
while trying to add a Tooltip label using Topcased, I also noticed that
the default tooltip size was very large by default. But this might be
easily fixed by using a org.eclipse.draw2d.Label instead of the one
redefined at the Topcased level which inherits from the GMF WrapLabel
causing such a big size.
Benjamin CHEVALLEREAU a écrit :
> Hi
> Thanks
>> Hi Benjamin,
>> Cheers...
>> Anthony
>>> Hi
>>> Thanls
>>>> Hi Benjamin,
>>>> is the
>>>> Cheers...
>>>> Anthony
>>>>> have
>>>>> Thanks
>>>>>> Hi Benjamin,
>>>>>> the
>>>>>> tooltip.
>>>>>> Cheers...
>>>>>> Anthony
>>>>>>> Hi,
>>>>>>> very big.
>>>>>>> Have you an idea ?
>>>>>>> Thanks
FUDForum. Page generated in 0.03254 seconds
