Home » Modeling » GMF (Graphical Modeling Framework) » How to add a menu item on the context menu
How to add a menu item on the context menu [message #234727] Fri, 26 June 2009 09:23 Go to next message
Originally posted by: billgrand08.gmail.com
I see that we can use the
" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders "
extension point, can someone give a example how to add a menu item on the
context menu, I define as below, but it doesn't work(add a menu named
"AssignToGlossaryMenu"), thanks.
<extension
id="ContributionItemProvider"
name="ContributionItemProvider"
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<contributionItemProvider
checkPluginLoaded="false"
class="com.mine.actions.ContributionItemProvider">
<Priority
name="Lowest">
</Priority>
<popupContribution
id="org.eclipse.gmf.runtime.diagram.ui.DiagramEditorContextMenu ">
<popupMenuGroup
id="PopupMenuGroup"
path="/"
separator="true">
</popupMenuGroup>
<popupMenu
id="AssignToGlossaryMenu"
path="/PopupMenuGroup">
</popupMenu>
<popupAction
id="AssignToGlossaryAction"
path="/AssignToGlossaryMenu">
</popupAction>
</popupContribution>
</contributionItemProvider>
</extension>
Re: How to add a menu item on the context menu [message #234913 is a reply to message #234727] Tue, 30 June 2009 18:18 Go to previous message
Tatiana Fesenko is currently offline Tatiana FesenkoFriend
Hello Bill,
Does it help when you add 'popupStructuredContributionCriteria' element (
like this - <popupStructuredContributionCriteria objectClass="com.mine.edit.parts.ElementEditPart"/>)
If not, does the program ever enter com.mine.actions.ContributionItemProvider#createAction()
method?
Best wishes,
Tanya.
> iders
Previous Topic:can't open GMF Editor after adding Audit Rules to mapping model since using Galileo
Next Topic:Issue with Decorator, Hanger, and Icons
Current Time: Tue Apr 16 12:30:41 GMT 2024
Powered by FUDForum. Page generated in 0.02524 seconds
