Home » Modeling » GMF (Graphical Modeling Framework) » Programatically making editor dirty and saving them
Programatically making editor dirty and saving them [message #234442] Mon, 22 June 2009 12:30 Go to next message
Vikas Goyal is currently offline Vikas GoyalFriend
Member
Hi ,
My plugin has two versions. In older version in my ***.genmodel file my
resource type is XML. In my later version in my ***.genmodel file I have
changed resource type is XMI and I have overridden public boolean
useUUIDs() {return true} . So In my later version in my model I am getting
xmi:id.
Now when I am copying my diagram and model file from older version to
newer version in my model file xmi:id is not there in my model file . In
the editor when I do anything and save my diagram file , In my model file
I am getting xmi:id automatically.
Now what I want is without opening the editor and making it dirty and
saving it I want to programatically get these xmi:id's in my model. For
this one option I have is programatically I should make the editor dirty
and save it (I have not checked if this will generate xmi:id or not). If
this is the only way how I can make editor dirty for all the files I have
copied programatically and how to save these file programatically without
opening the editor.
Thanks in advance
Best Regards,
Vikas
Re: Programatically making editor dirty and saving them [message #234477 is a reply to message #234442] Mon, 22 June 2009 15:47 Go to previous messageGo to next message
Alexander Shatalin is currently offline Alexander ShatalinFriend
Hello Vikas,
You can simply use EMF resources API to update XMI id attributes i hope.
Try loading both model and diagram file saved by "old" version into EMF ResourceSet
and then save both EMF resources.
AFAIU, id attribute will be save by EMF automatically.
Alex Shatalin
Re: Programatically making editor dirty and saving them [message #234672 is a reply to message #234477] Thu, 25 June 2009 12:52 Go to previous messageGo to next message
Member
Hi Alex ,
Thanks for your answer.
Could you please tell me how I can pass my model file and diagram file to
EMF resources API. All I have is these file names. I dont want to open my
diagram file.
Thanks in advance,
Best Regards,
Vikas
Re: Programatically making editor dirty and saving them [message #234734 is a reply to message #234672] Fri, 26 June 2009 11:05 Go to previous message
Hello Vikas,
ResourceSetImpl resourceSet = new ResourceSetImpl();
Resoruce diagramResource = resourceSet.getResource(diagramURI, true);
Resoruce modelResource = resourceSet.getResource(modelURI, true);
for(Resource nextResource : resourceSet.getResources()) {
nextResource.save(Collections.emptyMap());
Alex Shatalin
Previous Topic:ApplyAppearanceProperties Action error
Next Topic:Diagram resource modified
Current Time: Sun Jan 24 01:24:40 GMT 2021
Powered by FUDForum. Page generated in 0.02310 seconds
