Home » Eclipse Projects » BPMN 2.0 Modeler » ClassCastException when I execute the customTask example
ClassCastException when I execute the customTask example [message #1352691] Tue, 13 May 2014 15:32 Go to next message
Mickael BOREL is currently offline Mickael BORELFriend
Hello Bob,
We must create a customTask objects and to understand how this works I executed your example "org.eclipse.bpmn2.modeler.examples.customtask". And here is what I have :
org.eclipse.bpmn2.modeler.core.features.MultiAddFeature cannot be cast to org.eclipse.bpmn2.modeler.core.features.AbstractBpmn2AddFeature
Thanks in advance for your help Smile
Mickael
Re: ClassCastException when I execute the customTask example [message #1352758 is a reply to message #1352691] Tue, 13 May 2014 16:14 Go to previous messageGo to next message
Robert Brodt is currently offline Robert BrodtFriend
Hi Mickael,
Can you tell me the build tag# (version & timestamp) that you're using? Also, a more complete stack trace would help.
Thanks!
Bob
Re: ClassCastException when I execute the customTask example [message #1354169 is a reply to message #1352758] Wed, 14 May 2014 06:20 Go to previous message
Hi Bob,
I use the 1.1.0 - 201405092212 Smile
And here is the full stack trace :
Java.lang.ClassCastException: org.eclipse.bpmn2.modeler.core.features.MultiAddFeature cannot be cast to org.eclipse.bpmn2.modeler.core.features.AbstractBpmn2AddFeature
at org.eclipse.bpmn2.modeler.core.features.CustomShapeFeatureContainer$AddCustomShapeFeature.<init>(CustomShapeFeatureContainer.java:262)
at org.eclipse.bpmn2.modeler.core.features.CustomShapeFeatureContainer.getAddFeature(CustomShapeFeatureContainer.java:96)
at org.eclipse.bpmn2.modeler.ui.diagram.BPMN2FeatureProvider.getAddFeature(BPMN2FeatureProvider.java:438)
at org.eclipse.bpmn2.modeler.core.di.DIImport.createShape(DIImport.java:504)
at org.eclipse.bpmn2.modeler.core.di.DIImport.importShapes(DIImport.java:386)
at org.eclipse.bpmn2.modeler.core.di.DIImport.access$4(DIImport.java:286)
at org.eclipse.bpmn2.modeler.core.di.DIImport$1.doExecute(DIImport.java:183)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.graphiti.ui.internal.editor.GFWorkspaceCommandStackImpl.execute(GFWorkspaceCommandStackImpl.java:117)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.bpmn2.modeler.core.di.DIImport.generateFromDI(DIImport.java:137)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.importDiagram(BPMN2Editor.java:556)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.access$0(BPMN2Editor.java:534)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor$2.doExecute(BPMN2Editor.java:508)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:208)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.graphiti.ui.internal.editor.GFWorkspaceCommandStackImpl.execute(GFWorkspaceCommandStackImpl.java:84)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.setInput(BPMN2Editor.java:505)
at com.axway.pm.workbench.modeler.ui.editor.PMEditor.setInput(PMEditor.java:24)
at org.eclipse.graphiti.ui.editor.DiagramEditor.init(DiagramEditor.java:217)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.init(BPMN2Editor.java:397)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:359)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:306)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1096)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:61)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:526)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:511)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:61)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:66)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4688)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:3885)
at org.eclipse.ui.internal.Workbench.showPerspective(Workbench.java:2868)
at org.eclipse.ui.internal.Workbench.showPerspective(Workbench.java:2808)
at com.axway.pm.workbench.launcher.plugin.ApplicationWorkbenchWindowAdvisor.postWindowOpen(ApplicationWorkbenchWindowAdvisor.java:55)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpened(WorkbenchWindow.java:1299)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1408)
at org.eclipse.ui.internal.Workbench.openWorkbenchWindow(Workbench.java:2473)
at org.eclipse.ui.internal.Workbench.getWorkbenchPage(Workbench.java:1893)
at org.eclipse.ui.internal.Workbench.setReference(Workbench.java:1912)
at org.eclipse.ui.internal.Workbench.access$25(Workbench.java:1909)
at org.eclipse.ui.internal.Workbench$35.handleEvent(Workbench.java:1849)
at org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl.setContext(PartImpl.java:399)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:614)
I hope it will help you.
Rgds
Mickael
Previous Topic:BPMN 2.0 Metamodel
Next Topic:Pardon our dust while we remodel
Current Time: Sat Aug 08 06:02:31 GMT 2020
Powered by FUDForum. Page generated in 0.02095 seconds
