Re: looking for suggesting to locate/interact with the context menu of a source editor [message #23144 is a reply to message #23016] |
Thu, 19 February 2009 17:47 |
Joe Luebker Messages: 36 Registered: July 2009 |
Member |
Thanks for the responses (both Ketans). I quickly tried to use the
EventContextMenuFinder as suggested in JavaDoc documentation. No success
yet.
Has something changed with the SWTBotMenu constructors since the snippet
was written.
Example usage:
EventContextMenuFinder eventContextMenuFinder = new
EventContextMenuFinder();
try {
eventContextMenuFinder.register();
button.click(); // a popup menu appears below the button
SWTBotMenu menu = new SWTBotMenu(new Finder(new
ControlFinder(), eventContextMenuFinder), "Menu Text");
menu.click();
} finally {
eventContextMenuFinder.unregister();
I didn't see where SWTBotMenu takes a Finder in a constructor.
Joe
Ketan Padegaonkar wrote:
> Hi Joe,
> The vertical ruler is not supported in swtbot, please open a bug if
> you're interested in this support.
> Sending CTRL+F10 will definitely not help in finding the context menu
> unless you hook in the EventContextMenuFinder *before* the menu pops up.
> Note that at the moment chaining in context menus is not possible so you
> cannot do:
> editor.contextMenu("foo").menu("bar").click();
> so you'll just need to do:
> editor.contextMenu("bar").click();
> instead.
> -- Ketan
> On 19/2/09 02:17, Joe Luebker wrote:
>> Hello,
>> I am trying to interact with a context menu of a vertical ruler in a
>> source editor in Eclipse. I have discovered one way to open the context
>> menu but haven't yet successfully been able to interact with it. Below
>> is the snippet of code that actually opens the context menu.
>> SWTBotEclipseEditor actMainEditor = bot.editor("act_main.c");
>> actMainEditor.setFocus();
>> actMainEditor.navigateTo(64, 0);
>> // Open the context menu of the vertical ruler in the editor
>> actMainEditor.notifyKeyboardEvent(SWT.CTRL, (char)0, SWT.F10);
>> I have tried interacting with the focused widget which didn't work and
>> haven't been able to find the menu using SWTBot yet. Any suggestions?
>> Thanks,
>> Joe
Re: looking for suggesting to locate/interact with the context menu of a source editor [message #23272 is a reply to message #23144] |
Thu, 19 February 2009 19:08 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
Hi Joe,
The usages I see for EventContextMenuFinder are in
SWTBotToolbarDropDownButton#menuItem and SWTBotTrayItem#contextMenu
-- Ketan
> yet.
> was written.
> Example usage:
> try {
> SWTBotMenu menu = new SWTBotMenu(new Finder(new ControlFinder(),
> menu.click();
> } finally {
> Joe
>> Hi Joe,
>> you cannot do:
>> instead.
>> -- Ketan
>>> Hello,
>>> Thanks,
>>> Joe
Re: looking for suggesting to locate/interact with the context menu of a source editor [message #23458 is a reply to message #23272] |
Fri, 20 February 2009 20:47 |
Member |
Thanks again to both Ketans for their suggestions. I did find a way find
and interact with a menu item on the context menu of a vertical ruler. I
do have a follow up question. When I performed a click on a found menu
item the context menu did not close as it would during user interaction.
Is this a bug in SWTBot? As a workaround a set the visibility of the
parent of the menu item to false. See below for the code that finally
worked for me:
// Open the source editor vertical ruler context menu and find the
// "Add Breakpoint" menu item
SWTBotMenu addBreakpointMenu = null;
try {
actMainEditor.notifyKeyboardEvent(SWT.CTRL,(char) 0, SWT.F10);
List<MenuItem> foundMenus = eventContextMenuFinder
..findMenus(withMnemonic("Add Breakpoint"));
// We only expect to find one "Add Breakpoint" // Menu item
if (foundMenus.isEmpty()) { fail("Failed to find the 'Add
Breakpoint' menu item");
addBreakpointMenu = new SWTBotMenu((MenuItem) foundMenus.get(0));
} finally {
// Click the Add Breakpoint menu item
addBreakpointMenu.click();
// Close the vertical ruler context menu
final SWTBotMenu menu = addBreakpointMenu;
Display.getDefault().syncExec(new Runnable() {
public void run() {
try {
menu.widget.getParent().setVisible(false);
} catch (Exception e) {
// Ignore
> Hi Joe,
> -- Ketan
>> yet.
>> was written.
>> Example usage:
>> try {
>> menu.click();
>> } finally {
>> Thanks,
>> Joe
>>> Hi Joe,
>>> you cannot do:
>>> instead.
>>> -- Ketan
>>>> Hello,
>>>> Thanks,
>>>> Joe
FUDForum. Page generated in 0.02561 seconds
