EditPart selection feedback [message #233127] |
Tue, 17 April 2007 16:22 |
Originally posted by: michele.l.evinco.it
I want to change the backgroud color of the an editpart when i click on
it so i've written this code in createEditPolicies of my editpart:
installEditPolicy(EditPolicy.SELECTION_FEEDBACK_ROLE,
new SelectionEditPolicy(){
protected void hideSelection() {
((AntennaFigure)getFigure()).setOpaque(true);
((AntennaFigure)getFigure()).setBackgroundColor(org.eclipse. draw2d.ColorConstants.black);
protected void showSelection() {
((AntennaFigure)getFigure()).setOpaque(false);
((AntennaFigure)getFigure()).setBackgroundColor(org.eclipse. draw2d.ColorConstants.white);
When i click on the figure that rappresent my editpart notthing appends
and the code of showSelection is never executed.
My way is correct?
What 's the best way to do this?
When an editPart is Selected? on mouse click?
Thank's
Michele
Re: EditPart selection feedback [message #233151 is a reply to message #233135] |
Wed, 18 April 2007 08:37 |
Thank you for your reply David,
i've try with your way but when i click or double click on the figure
the code of createDragSourceFeedbackFigure() is never executed.
I've register it as EditPolicy.SELECTION_FEEDBACK_ROLE.
How do you register it?
Sun Seng David TAN wrote:
> hi
> My way to do it would be to create a resizableEditPolicy
> and override the method
> protected IFigure createDragSourceFeedbackFigure()
> where you create the feedback figure (that would be the same figure with
> a different background)
>> on it so i've written this code in createEditPolicies of my editpart:
>> appends and the code of showSelection is never executed.
>> My way is correct?
>> Thank's
>> Michele
Re: EditPart selection feedback [message #233229 is a reply to message #233199] |
Thu, 19 April 2007 08:15 |
thank's David for your replay,
I've find this solution :
i've register my SelectionEditPolicy as EditPolicy.SELECTION_FEEDBACK_ROLE.
then in the edit part i've add a EditPartListener and implement his
selectedStateChanged method where i change the background of figure.
I don't know if this is the right way to do that but it work.
Bye
Michele
> So ....
> i'm registering it from the parent layoutEditPolicy from the method
> createChildEditPolicy.. if you have a look to the Logic diagram example
> you will find in the class
> org.eclipse.gef.examples.logicdesigner.edit.LogicXYLayoutEdi tPolicy the
> way to do it :
> protected EditPolicy createChildEditPolicy(EditPart child) {
> if (child instanceof LEDEditPart
> || child instanceof OutputEditPart) {
> ResizableEditPolicy policy = new LogicResizableEditPolicy();
> policy.setResizeDirections(0);
> return policy;
> } else if (child instanceof LogicLabelEditPart) {
> policy.setResizeDirections(PositionConstants.EAST |
> PositionConstants.WEST);
> return policy;
> return new LogicResizableEditPolicy();
>>> hi
>>> with a different background)
>>>> My way is correct?
>>>> Thank's
>>>> Michele
Re: EditPart selection feedback [message #233237 is a reply to message #233229] |
Thu, 19 April 2007 08:27 |
correction:
It works without register the policy.
In the deactivate method of editpart i must remove the listener
otherwise an errror will be generated.
> Bye
> Michele
>> So ....
>> example you will find in the class
>> the way to do it :
>> return policy;
>> return policy;
>>>> hi
>>>>> click on it so i've written this code in createEditPolicies of my
>>>>> editpart:
>>>>> My way is correct?
>>>>> Thank's
>>>>> Michele
FUDForum. Page generated in 0.03621 seconds
