Re: Galileo Installation [message #233087] |
Mon, 29 June 2009 22:41 |
Originally posted by: eclipse-news.rizzoweb.com
Redirecting this to the eclipse.webtools newsgroup where the JST gurus
likely can help.
zapping wrote:
> I did an installation(fresh one) of Galileo on my machine. I was using the
> Europa vesion before. But when i open my project i get 3 messages
> frequently.
> The project was imported to the Galileo workspace using import -> General -
> File system.
> org.eclipse.jst.jsp.core.internal.parser.JSPSourceParser: input could
> not be
> parsed correctly at position 13234
> java.lang.StackOverflowError
> when i click ok another one pops up saying
> An internal error occurred during: "Updating JSP Index".
> Then another one saying An internal error occured do you want to exit the
> workbench?
> Closing and reopening the workbench does not have any effect. The 3
> messages keeps popping up after sometime. Help appriciated thanks in
> advance. The eclipse log shows the following 3 entries.
> eclipse.buildId=I20090611-1540
> java.version=1.5.0_14
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Framework arguments: -product org.eclipse.epp.package.jee.product
> Command-line arguments: -os win32 -ws win32 -arch x86 -product
> Error
> Mon Jun 29 16:11:19 IST 2009
> at
> org.eclipse.jst.jsp.core.internal.contenttype.BooleanStack.p ush(BooleanStack.java:98)
> at
> org.eclipse.jst.jsp.core.internal.parser.internal.JSPTokeniz er.primGetNextToken(JSPTokenizer.java:3102)
> at
> org.eclipse.jst.jsp.core.internal.parser.internal.JSPTokeniz er.assembleEmbeddedContainer(JSPTokenizer.java:1140)
> at
> org.eclipse.jst.jsp.core.internal.parser.internal.JSPTokeniz er.assembleEmbeddedTagSequence(JSPTokenizer.java:1053)
> at
> org.eclipse.jst.jsp.core.internal.parser.internal.JSPTokeniz er.primGetNextToken(JSPTokenizer.java:2952)
> at
> org.eclipse.jst.jsp.core.internal.parser.internal.JSPTokeniz er.getNextToken(JSPTokenizer.java:1579)
> at
> org.eclipse.wst.xml.core.internal.parser.XMLSourceParser.get NextRegion(XMLSourceParser.java:180)
> at
> org.eclipse.jst.jsp.core.internal.parser.JSPSourceParser.par seNodes(JSPSourceParser.java:237)
> at
> org.eclipse.wst.xml.core.internal.parser.XMLSourceParser.get DocumentRegions(XMLSourceParser.java:164)
> at
> org.eclipse.wst.sse.core.internal.text.StructuredDocumentReP arser._core_reparse_text(StructuredDocumentReParser.java:309 )
> at
> org.eclipse.wst.sse.core.internal.text.StructuredDocumentReP arser.core_reparse(StructuredDocumentReParser.java:708)
> at
> org.eclipse.jst.jsp.core.internal.parser.JSPReParser.reparse (JSPReParser.java:143)
> at
> org.eclipse.wst.sse.core.internal.text.StructuredDocumentReP arser.reparse(StructuredDocumentReParser.java:1284)
> at
> org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.updateModel(BasicStructuredDocument.java:2704)
> at
> org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.internalReplaceText(BasicStructuredDocument.java:1919)
> at
> org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.replaceText(BasicStructuredDocument.java:2414)
> at
> org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.setText(BasicStructuredDocument.java:2601)
> at
> org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment.setText(JobSafeStructuredDocument.java:225)
> at
> org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.set(BasicStructuredDocument.java:2476)
> at
> org.eclipse.jst.jsp.core.internal.java.XMLJSPRegionHelper.fo rceParse(XMLJSPRegionHelper.java:108)
> at
> org.eclipse.jst.jsp.core.internal.java.JSPTranslator.decodeS criptBlock(JSPTranslator.java:1193)
> at
> org.eclipse.jst.jsp.core.internal.java.JSPTranslator.transla teRegionContainer(JSPTranslator.java:1157)
> at
> org.eclipse.jst.jsp.core.internal.java.JSPTranslator.transla te(JSPTranslator.java:979)
> at
> org.eclipse.jst.jsp.core.internal.java.JSPTranslationAdapter .getJSPTranslation(JSPTranslationAdapter.java:127)
> at
> org.eclipse.jst.jsp.core.internal.java.search.JSPSearchDocum ent.getJSPTranslation(JSPSearchDocument.java:120)
> at
> org.eclipse.jst.jsp.core.internal.java.search.JSPSearchDocum ent.getPath(JSPSearchDocument.java:159)
> at
> org.eclipse.jst.jsp.core.internal.java.search.JavaSearchDocu mentDelegate. <init>(JavaSearchDocumentDelegate.java:30)
> at
> org.eclipse.jst.jsp.core.internal.java.search.JSPSearchSuppo rt.createSearchDocument(JSPSearchSupport.java:385)
> at
> org.eclipse.jst.jsp.core.internal.java.search.JSPSearchSuppo rt.addJspFile(JSPSearchSupport.java:279)
> at
> org.eclipse.jst.jsp.core.internal.java.search.JSPIndexManage r$ProcessFilesJob.run(JSPIndexManager.java:267)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> then this one
> Error
> Mon Jun 29 16:10:50 IST 2009
> Program Error: invalid structured document event
> Then this one
> Error
> Mon Jun 29 16:10:49 IST 2009
> not be
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Galileo Installation [message #233095 is a reply to message #233087] |
Tue, 30 June 2009 04:35 |
Originally posted by: david_williams.linux.vnet.ibm.com
zapping wrote:
>> Hi,
>> using the
>> frequently.
>> General -
>> File system.
>> not be
How confident are you that all is installed correctly and is really the
Galileo Release? Seems to be, from the stack traces you attached but I
ask because I recall seeing those sorts of errors in some early Ganymede
releases, but don't recall seeing them in the Galileo stream. Not that
I'd know for sure.
But, if you wanted to be sure, I'd recommend you try the Java EE IDE
package from
http://www.eclipse.org/downloads/
If that's what you meant by your "fresh install" then that should suffice.
And, in that case, then I'd suggest you open a bug in Web Tools, JSP
Component
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20So urce%20Editing&component=jst.jsp
In cases like this, it's often helpful (if not required) to provide some
sample input that can be used to reproduce the problem.
It sounds like what you are doing is reasonable and maybe your
particular JSP files cause the bug to show up.
Re: Galileo Installation [message #233177 is a reply to message #233087] |
Wed, 01 July 2009 17:22 |
Nick Sandonato Messages: 126 Registered: July 2009 |
If others come searching, the bug that was opened to address this is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281838
> likely can help.
> zapping wrote:
>> Hi,
>> the
>> frequently.
>> General -
>> File system.
>> not be
>> workbench?
>> Error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> then this one
>> Error
>> Then this one
>> Error
>> not be
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
FUDForum. Page generated in 0.05671 seconds
