Home » Archived » EMF-IncQuery » plugin.xml is not being generated automatically
plugin.xml is not being generated automatically [message #1348024] |
Sun, 11 May 2014 15:52 |
Emre T Messages: 119 Registered: April 2013 |
I have been playing with different versions of the IncQuery and changing a bunch of setups for my projects. Then I have noticed that my derived queries weren't working like before in my runtime instances, even though the getters were generated into the model codes correctly.
I am getting the following error:
Handler initialization failed, query specification is null. Make sure to include your EMF-IncQuery project with the query definitions in the configuration.
Then again, I have noticed that the plugin.xml's weren't generated with the clean builds of the IncQuery projects, which should have been holding the extensions of the wellbehaving derived features.
The version I am on right now is from the Integration build, since they are also supporting Xtext 2.5 (right?).
EMF-IncQuery SDK (Incubation) 0.8.0.201405091632 org.eclipse.incquery.sdk.feature.source.feature.group Budapest University of Technology and Economics, Fault Tolerant Systems Research Group
Why is this the case for all of a sudden? Or I am missing something? I just can't remember that I had to do something extra to let plugin.xml generated.
Would be very happy for a quick response. Thanks a lot!
Emre
[Updated on: Mon, 12 May 2014 14:02] Report message to a moderator
Re: plugin.xml is not being generated automatically [message #1350084 is a reply to message #1349502] |
Mon, 12 May 2014 13:46 |
Hello Zoltan,
I wasn't working with any 0.7 versions of EMF-IncQuery either. Since the end of last summer I am on 0.8 and have already migrated all my projects successfully.
Though the problem is solved like mentioned in my previous post. It was a an IncQuery preferences issue.
But do you mean, that the plugin.xml should have been created independently of this preference?
Emre
[Updated on: Mon, 12 May 2014 13:46] Report message to a moderator
Re: plugin.xml is not being generated automatically [message #1384839 is a reply to message #1384549] |
Mon, 02 June 2014 13:15 |
Hi Zoltan,
yes, indeed.
And sorry, that I haven't corrected it, but the workaround, that I have mentioned before to change the IncQuery preferences regarding plugin.xml generation, hasn't actually worked in a new environment later. So I had to copy/paste an existing plugin.xml from another IncQuery project, that was also handling some derived features, and adjust it myself.
But nice to hear, that the problem is now fixed.
Emre
Current Time: Thu Apr 25 09:03:32 GMT 2024
Powered by FUDForum. Page generated in 0.04018 seconds
