Home » Eclipse Projects » DSDP - Target Management » ftp connection hangs after a long inactive time.
Re: ftp connection hangs after a long inactive time. [message #22954 is a reply to message #22778] |
Thu, 15 May 2008 22:53 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
For ssh / sftp, what version of RSE are you using?
We added a keepalive feature in RSE 2.0.3 / RSE 3.0M6, which
should avoid that kind of issues.
For FTP, I was under the impression that it does reconnect
automatically, in fact doesn't even notice the dropped
connection, or am I mistaken?
If I am mistaken, would you please file a bug (enhancement
request) for this?
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
David Harel wrote:
> I am connected to a remote site which uses some
> routers/switches/firewalls that drop a session after some idle time (I
> read somewhere that cheap Cisco firewalls have that problem).
> So every time I take a coffee break ssh and ftp sessions with or without
> Eclipse hang.
> Can dsdp target management be configured to restart a session whenever
> that happens?
> Thanks
> David Harel
> Amuka
> Israel
Re: ftp connection hangs after a long inactive time. [message #23040 is a reply to message #22954] |
Fri, 16 May 2008 16:11 |
David Harel Messages: 8 Registered: July 2009 |
I use RSE 2.0.3.v20080225
I couldn't find where this setting is. Please guide me.
I had the same impression but I don't know how to verify that and
therefore I would avoid submitting a bug report until I know what I see.
Anyway, I changed to fssh which seems to get disconnected after every
file transfer and therefore avoids the problem all together.
Thanks for your help.
> request) for this?
> David Harel wrote:
>> Hi,
>> without Eclipse hang.
>> that happens?
>> Thanks
>> David Harel
>> Amuka
>> Israel
Thanks.
David Harel,
Home office +972 77 7657645
Fax: +972 77 7657645
Cellular: +972 54 4534502
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #23087 is a reply to message #22954] |
Fri, 16 May 2008 16:23 |
> request) for this?
> David Harel wrote:
>> Hi,
>> that happens?
>> Thanks
>> David Harel
>> Amuka
>> Israel
Thanks.
David Harel,
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #23128 is a reply to message #23087] |
Sun, 18 May 2008 14:03 |
In the New Connection Wizard, below "SSH Connector Service" there
is an "SSH Settings" node. Select it and you can enter the
keepalive (default is 300 seconds, so RSE would send a keepalive
packet every 5 minutes).
If your connection already exists, select the host, right-click
> properties, select the "Connector Servcies" / "SSH Settings"
node, and voila you see the keepalive time (300 by default).
Window > Show View > Other... > General > Console
Click on "Computer" icon to switch to the FTP Log Console
You'll see the log of FTP commands so you'll see if and where
the connection is (re-)established.
In general, don't be afraid of entering a bug. In the worst
case, a committer will come and set it to "WORKSFORME" or
ask you to provide more information. Please, don't be shy.
Just see bugzilla as a communication platform, where the
comments (just as I'm typing right now) are stored in a
much more accessible, ordered and searchable database than
here on the newsgroup.
Martin
Re: ftp connection hangs after a long inactive time. [message #23233 is a reply to message #23128] |
Tue, 20 May 2008 08:04 |
Thank you for your help.
I filed a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=232915
I didn't find the "SSH settings" node. Is it a version issue?
> Cheers,
> Martin
Thanks.
David Harel,
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #574666 is a reply to message #22778] |
request) for this?
David Harel wrote:
> Eclipse hang.
> that happens?
> Thanks
> David Harel
> Amuka
> Israel
Re: ftp connection hangs after a long inactive time. [message #574720 is a reply to message #22954] |
> request) for this?
> David Harel wrote:
>> Hi,
>> that happens?
>> Thanks
>> David Harel
>> Amuka
>> Israel
Thanks.
David Harel,
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #574727 is a reply to message #22954] |
> request) for this?
> David Harel wrote:
>> Hi,
>> that happens?
>> Thanks
>> David Harel
>> Amuka
>> Israel
Thanks.
David Harel,
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #574754 is a reply to message #23087] |
Martin
Re: ftp connection hangs after a long inactive time. [message #574836 is a reply to message #23128] |
> Cheers,
> Martin
Thanks.
David Harel,
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Current Time: Thu Apr 25 03:44:56 GMT 2024
Powered by FUDForum. Page generated in 0.04006 seconds
