Re: "Invalid view - remove from diagram" on diagrams created with olderGMF opened in lates [message #234322 is a reply to message #234316] |
Fri, 19 June 2009 22:55 |
Brian Jakubik Messages: 140 Registered: July 2009 |
--------------070904030000080906060008
Attached files this time
Alex, sorry it took so long to get back to you...
Attached are my 2 diagram files, the old was from our tool using the 3.3
GMF, the new is our diagram created from the same model file.
Most of the changes appear to be in line with what I originally posted,
however the old one still has a ConnectorStyle that the new does not.
The old I am getting invalid view on the connections... the new appears
to be fine.
any help would be appreciated.
Alex Shatalin wrote:
> Hello Brian,
> All these changes are known and should be backward compatible. Are you
> sure there are no other differences in diagram files?
> Alex Shatalin
Content-Type: text/xml;
name="Voice-old.diagram"
Content-Disposition: inline;
filename="Voice-old.diagram"
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:icxml="http://www.intervoice.com/icxml" xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.2/notation" xmi:id="_fcVDMV0gEd6NTtdAqnR5mA" type="Icxml" name="Voice-6.0.1.diagram" measurementUnit="Pixel">
<children xmi:type="notation:Node" xmi:id="_fcVDMl0gEd6NTtdAqnR5mA" type="2044">
<children xmi:type="notation:Node" xmi:id="_fcVDM10gEd6NTtdAqnR5mA" type="5044">
<layoutConstraint xmi:type="notation:Location" xmi:id="_fcVDNF0gEd6NTtdAqnR5mA" y="5"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_fcVDNV0gEd6NTtdAqnR5mA"/>
<element xmi:type="icxml:VoiceBegin" href="Voice-6.0.1.icxml#_fbvNUF0gEd6NTtdAqnR5mA"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_fcVDNl0gEd6NTtdAqnR5mA" x="24" y="24" width="58" height="43"/>
</children>
<children xmi:type="notation:Node" xmi:id="_fcVDN10gEd6NTtdAqnR5mA" type="2045">
<children xmi:type="notation:Node" xmi:id="_fcVDOF0gEd6NTtdAqnR5mA" type="5045">
<layoutConstraint xmi:type="notation:Location" xmi:id="_fcVDOV0gEd6NTtdAqnR5mA" y="5"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_fcVDOl0gEd6NTtdAqnR5mA"/>
<element xmi:type="icxml:VoiceEnd" href="Voice-6.0.1.icxml#_fcCIQF0gEd6NTtdAqnR5mA"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_fcVDO10gEd6NTtdAqnR5mA" x="264" y="24" width="58" height="43"/>
</children>
<children xmi:type="notation:Node" xmi:id="_gAijgV0gEd6NTtdAqnR5mA" type="2003">
<children xmi:type="notation:Node" xmi:id="_gAijhF0gEd6NTtdAqnR5mA" type="5003">
<layoutConstraint xmi:type="notation:Location" xmi:id="_gAijhV0gEd6NTtdAqnR5mA" y="5"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_gAijgl0gEd6NTtdAqnR5mA"/>
<element xmi:type="icxml:Comment" href="Voice-6.0.1.icxml#_gAYygF0gEd6NTtdAqnR5mA"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_gAijg10gEd6NTtdAqnR5mA" x="144" y="24" width="58" height="43"/>
</children>
<styles xmi:type="notation:DiagramStyle" xmi:id="_fcVDPF0gEd6NTtdAqnR5mA"/>
<element xmi:type="icxml:RootType" href="Voice-6.0.1.icxml#_fbcSYV0gEd6NTtdAqnR5mA"/>
<edges xmi:type="notation:Edge" xmi:id="_ffUFwF0gEd6NTtdAqnR5mA" type="4001" source="_fcVDMl0gEd6NTtdAqnR5mA" target="_gAijgV0gEd6NTtdAqnR5mA">
<children xmi:type="notation:Node" xmi:id="_ffUFxF0gEd6NTtdAqnR5mA" type="6001">
<layoutConstraint xmi:type="notation:Location" xmi:id="_ffUFxV0gEd6NTtdAqnR5mA" y="7"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_ffUFwV0gEd6NTtdAqnR5mA"/>
<styles xmi:type="notation:FontStyle" xmi:id="_ffUFwl0gEd6NTtdAqnR5mA"/>
<element xmi:type="icxml:DefaultConnection" href="Voice-6.0.1.icxml#_fcVDMF0gEd6NTtdAqnR5mA"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_ffUFw10gEd6NTtdAqnR5mA" points="[29, 0, -89, 0]$[89, 0, -29, 0]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_hVdvEF0gEd6NTtdAqnR5mA" type="4001" source="_gAijgV0gEd6NTtdAqnR5mA" target="_fcVDN10gEd6NTtdAqnR5mA">
<children xmi:type="notation:Node" xmi:id="_hVdvFF0gEd6NTtdAqnR5mA" type="6001">
<layoutConstraint xmi:type="notation:Location" xmi:id="_hVdvFV0gEd6NTtdAqnR5mA" y="7"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_hVdvEV0gEd6NTtdAqnR5mA"/>
<styles xmi:type="notation:FontStyle" xmi:id="_hVdvEl0gEd6NTtdAqnR5mA"/>
<element xmi:type="icxml:DefaultConnection" href="Voice-6.0.1.icxml#_hVT_EF0gEd6NTtdAqnR5mA"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_hVdvE10gEd6NTtdAqnR5mA" points="[29, 0, -89, 0]$[89, 0, -29, 0]"/>
</edges>
</notation:Diagram>
name="Voice-new.diagram"
filename="Voice-new.diagram"
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:icxml="http://www.intervoice.com/icxml" xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.2/notation" xmi:id="_H4Zz8F0iEd6Ku5MbvafxOA" type="Icxml" measurementUnit="Pixel">
<children xmi:type="notation:Shape" xmi:id="_IDlJMF0iEd6Ku5MbvafxOA" type="2044" fontName="Microsoft Sans Serif">
<children xmi:type="notation:DecorationNode" xmi:id="_IDlJMl0iEd6Ku5MbvafxOA" type="5044">
<layoutConstraint xmi:type="notation:Location" xmi:id="_IDlJM10iEd6Ku5MbvafxOA" y="5"/>
</children>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_IDlJMV0iEd6Ku5MbvafxOA" x="24" y="24" width="58" height="43"/>
</children>
<children xmi:type="notation:Shape" xmi:id="_IDlJNF0iEd6Ku5MbvafxOA" type="2045" fontName="Microsoft Sans Serif">
<children xmi:type="notation:DecorationNode" xmi:id="_IDlJNl0iEd6Ku5MbvafxOA" type="5045">
<layoutConstraint xmi:type="notation:Location" xmi:id="_IDlJN10iEd6Ku5MbvafxOA" y="5"/>
</children>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_IDlJNV0iEd6Ku5MbvafxOA" x="264" y="24" width="58" height="43"/>
</children>
<children xmi:type="notation:Shape" xmi:id="_IDlJOF0iEd6Ku5MbvafxOA" type="2003" fontName="Microsoft Sans Serif">
<children xmi:type="notation:DecorationNode" xmi:id="_IDu6MF0iEd6Ku5MbvafxOA" type="5003">
<layoutConstraint xmi:type="notation:Location" xmi:id="_IDu6MV0iEd6Ku5MbvafxOA" y="5"/>
</children>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_IDlJOV0iEd6Ku5MbvafxOA" x="144" y="24" width="58" height="43"/>
</children>
<styles xmi:type="notation:DiagramStyle" xmi:id="_H4Zz8V0iEd6Ku5MbvafxOA"/>
<edges xmi:type="notation:Connector" xmi:id="_ID4EIF0iEd6Ku5MbvafxOA" type="4001" source="_IDlJMF0iEd6Ku5MbvafxOA" target="_IDlJOF0iEd6Ku5MbvafxOA">
<children xmi:type="notation:DecorationNode" xmi:id="_ID4EI10iEd6Ku5MbvafxOA" type="6001">
<layoutConstraint xmi:type="notation:Location" xmi:id="_ID4EJF0iEd6Ku5MbvafxOA" y="7"/>
</children>
<styles xmi:type="notation:FontStyle" xmi:id="_ID4EIV0iEd6Ku5MbvafxOA" fontName="Microsoft Sans Serif"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_ID4EIl0iEd6Ku5MbvafxOA" points="[29, 0, -89, 0]$[89, 0, -29, 0]"/>
</edges>
<edges xmi:type="notation:Connector" xmi:id="_IEUwEF0iEd6Ku5MbvafxOA" type="4001" source="_IDlJOF0iEd6Ku5MbvafxOA" target="_IDlJNF0iEd6Ku5MbvafxOA">
<children xmi:type="notation:DecorationNode" xmi:id="_IEUwE10iEd6Ku5MbvafxOA" type="6001">
<layoutConstraint xmi:type="notation:Location" xmi:id="_IEUwFF0iEd6Ku5MbvafxOA" y="7"/>
</children>
<styles xmi:type="notation:FontStyle" xmi:id="_IEUwEV0iEd6Ku5MbvafxOA" fontName="Microsoft Sans Serif"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_IEUwEl0iEd6Ku5MbvafxOA" points="[29, 0, -89, 0]$[89, 0, -29, 0]"/>
</edges>
</notation:Diagram>
--------------070904030000080906060008--
FUDForum. Page generated in 0.03707 seconds
