Home » Eclipse Projects » e(fx)clipse » Override captions on Dialogs
Override captions on Dialogs [message #1346184] Sat, 10 May 2014 09:39 Go to next message
I am tring to localize button caption on org.eclipse.fx.ui.dialogs.Dialog
What is the best way to do it?
Re: Override captions on Dialogs [message #1348033 is a reply to message #1346184] Sun, 11 May 2014 12:29 Go to previous messageGo to next message
You mean ok, cancel, ...? In the nightly builds those are already loaded
from a messages.properties
(org/eclipse/fx/ui/dialogs/messages.properties) providing one for your
language will make the UI reflect that.
Tom
Re: Override captions on Dialogs [message #1357424 is a reply to message #1348033] Thu, 15 May 2014 10:13 Go to previous messageGo to next message
Thanks for answer, but ...
May be you can help me with some details, like
1. How should I name my property file? ( Turkish locale :
messages_tr_TR.properties or messages_tr.properties)
2. Where should I put this file?
Re: Override captions on Dialogs [message #1357633 is a reply to message #1357424] Thu, 15 May 2014 12:15 Go to previous messageGo to next message
On 15.05.14 16:13, Jeyhun MAMEDOV wrote:
messages_tr.properties is fine.
> Thanks
You create an OSGi-fragment with the dialogs bundle as its host and put
the translation exactly in the same package as the original file, then
you add the fragment to you feature/.... and you are ready to go.
I'll try to get efxclipse to babel but i need to figure out the process.
Tom
Re: Override captions on Dialogs [message #1357694 is a reply to message #1357633] Thu, 15 May 2014 12:49 Go to previous message
Babel seems to be down a bit - let's host the few translations we
currently have inside e(fx)clipse. File a bug and attach your translations.
Tom
>> Hi,
>> Thanks
> Tom
Previous Topic:How to avoid crashing the JVM on Linux with GTK3
Next Topic:Problem with Tycho compiling with java8
Current Time: Mon May 12 09:08:09 EDT 2025
Powered by FUDForum. Page generated in 0.06239 seconds
