MAT fails to run inside Eclipse due to known seg fault - workarounds don't appear to work [message #1343880] |
Fri, 09 May 2014 13:57 |
Grant Y Messages: 2 Registered: May 2014 |
Hey
So I'm currently working on a plugin for the Memory Analyzer Tool. I'm using eclipse for this work of course. However on my machine I can't seem to get MAT running in Eclipse to test out changes, etc...
Some background first I have MAT installed separately in it's own folder and am using eclipse to work specifically on the plugin files. I have however pointed eclipse to the MAT install as the Target Platform under the Plug-In development settings. For running the MAT + Plugin I have specified a standard Eclipse application Run Configuration. With the target platform already set up the default settings for this configuration seemed to all check out, specifically the program to run that was set to org.eclipse.mat.ui.rcp.MemoryAnalyzer. However it may be the case that the issue I'm getting is due to this ootb configuration. Thought I would call these out just in case.
On to the actual issue. It's this resolved bug here - https://bugs.eclipse.org/bugs/show_bug.cgi?id=404776. I'm on linux mint 16 petra and indeed it appears my libsoup install is too new and causing webkit to freak out.
I got the issue in two places - When I start MAT (1.3.1) on it's own as well as when I tried to run it in eclipse (4.3.2). I found the above bug and indeed applied the workaround of specifying -Dorg.eclipse.swt.browser.DefaultType=mozilla in the MemoryAnalyzer.ini. This indeed seem to solve my issue for MAT standalone.
However the problem I'm having is in eclipse. Not eclipse itself I should state, it has never given me this issue. It's when I try to run MAT from eclipse. I just get the same error log in the console. I've applied the workaround to the eclipse.ini but this hasn't solved the issue.
It would appear that eclipse is starting the MAT without that specific setting.
Any ideas?
As an aside is the above linked bug only for eclipse or does it also cover MAT? As it's currently in resovled status I was confused to why I would be seeing it but I realized MAT may be separate.
Many Thanks.
[Updated on: Mon, 12 May 2014 08:57] Report message to a moderator
FUDForum. Page generated in 0.07497 seconds
