Focus on newly created connection [message #231865] |
Mon, 19 March 2007 18:44 |
Originally posted by: gary.pi4tech.com
When a component is created by being dragged from a palette, it
automatically obtains the focus.
However when using the connection tool, the same does not happen for the
created connection.
Is there a simple way to get the focus on the connection, without having
to specifically locate the new edit part and invoke setFocus on the viewer?
Gary
Re: Focus on newly created connection [message #232002 is a reply to message #231865] |
Thu, 22 March 2007 05:21 |
Originally posted by: none.unknown.com
CreationTool has a selectAddedObject() method that is invoked once the
creation command has executed. ConnectionCreationTool doesn't. You can
easily add that by subclassing CCT and setting that as the tool for your
palette entry.
"Gary Brown" <gary@pi4tech.com> wrote in message
news:etmlmu$qa6$1@utils.eclipse.org...
> created connection.
> viewer?
> Regards
> Gary
Re: Focus on newly created connection [message #232096 is a reply to message #232002] |
Fri, 23 March 2007 11:33 |
Thanks for the suggestion, but the method you refer to is on the GMF
CreationTool. I am not using GMF, so need to find a GEF solution.
> palette entry.
>> created connection.
>> viewer?
>> Regards
>> Gary
FUDForum. Page generated in 0.03205 seconds
