Home » Eclipse Projects » GEF » JUnit testing of GEF application
JUnit testing of GEF application [message #231576] |
Mon, 12 March 2007 04:11 |
Originally posted by: sushant.sirsikar.gmail.com
Hello Everyone,
I developed one application using GEF. Now i want to use strategy XP(
extreme Programming) to modify it. How can i use jUnit testing framework
to test it? Is it possible to to test GEF application using jUnit? Can i
create dummy request to test the commands? How can i check GUI events
which are generated by GEF?( for example .... i clicked on pallet and
drag one object on graphical window) I want all test scripts to be run
automatically. Please help me with your suggestions and examples or
documentations if you have any. Thanks in advance.
Sushant
Re: JUnit testing of GEF application [message #231584 is a reply to message #231576] |
Mon, 12 March 2007 09:50 |
Originally posted by: jakub.jurkiewicz.gmail.com
Hi Sushant,
I used to have the same problem until I started using Easy Mock
http://www.easymock.org/ . Thanks to it, you can create a mocks objects
that can simulate a behavior of GEF components.
Here http://www.easymock.org/EasyMock2_2_Documentation.html you can find
some examples, which just have to be transformed into GEF specific ones.
If anyone knows any other ways to test GEF applications, please let us
know :)
Hope this helps,
Jakub Jurkiewicz
Sushant wrote:
> Hello Everyone,
> Sushant
Re: JUnit testing of GEF application [message #231610 is a reply to message #231584] |
Mon, 12 March 2007 20:45 |
Thomas Maier Messages: 117 Registered: July 2009 |
--------------050103070407050408090209
Content-Type: text/plain; charset=ISO-8859-15
Hi Sushant, hi Jakub, do you have some code to share? Here is some I
hacked a while ago. Beware, it's ugly. Basically, I send fake events,
to simulate user input and test the whole flow down to the code finally
handling the events. Not very nice to program, though. Once I tried
feeding events into a DomainEventDispatcher to work around problems with
the reliability of the event processing. However, this had the problem
that I could not test direct edit actions.
It works on Linux, does not really work on MacOS and is untested on Windows.
HTH, Thomas.
Jakub Jurkiewicz wrote:
> Hi Sushant,
> objects that can simulate a behavior of GEF components.
> find some examples, which just have to be transformed into GEF
> specific ones.
> know :)
> Hope this helps,
> Jakub Jurkiewicz
> Sushant wrote:
>> Hello Everyone,
>> XP( extreme Programming) to modify it. How can i use jUnit testing
>> framework to test it? Is it possible to to test GEF application using
>> jUnit? Can i create dummy request to test the commands? How can i
>> check GUI events which are generated by GEF?( for example .... i
>> clicked on pallet and drag one object on graphical window) I want all
>> test scripts to be run automatically. Please help me with your
>> suggestions and examples or documentations if you have any. Thanks
>> in advance.
>> Sushant
Content-Type: text/x-java;
name="UITestCase.java"
Content-Disposition: inline;
filename="UITestCase.java"
* Janus Plugin -- Java'n'UML Simultanously.
* Janus Plugin aims to extend Eclipse's Java Environment with UML editing capabilities.
* Java code and UML diagrams can both be edited and update each other.
* Copyright (C) 2003, 2004, 2005, 2006, 2007 Thomas Maier, University of Kassel.
* Janus Plugin is free software; you can redistribute it and/or modify it under the
* terms of the GNU General Public License as published by the Free Software Foundation;
* Janus Plugin is licensed using version 2 of the License and not any later version.
* Janus Plugin is distributed in the hope that it will be useful, but WITHOUT ANY
* WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A
* PARTICULAR PURPOSE. See the GNU General Public License for more details.
* You should have received a copy of the GNU General Public License along with this
* program; if not, write to the Free Software Foundation, Inc., 59 Temple Place, Suite
* 330, Boston, MA 02111-1307 USA
* Contact Address:
* URL: janus-plugin.sourceforge.net
* email: Thomas.Maier@uni-kassel.de
* Thomas Maier
* University of Kassel
* Research Group Software Engineering
* Wilhelmshöher Allee 73
* 34121 Kassel
* Germany
package de.unikassel.janus.tests;
import java.io.ByteArrayInputStream;
import java.io.ByteArrayOutputStream;
import java.io.IOException;
import java.lang.reflect.Method;
import junit.framework.Test;
import junit.framework.TestCase;
import junit.framework.TestSuite;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.resources.IProjectDescription;
import org.eclipse.core.resources.IWorkspaceRoot;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.geometry.Rectangle;
import org.eclipse.gef.GraphicalViewer;
import org.eclipse.gef.ui.palette.PaletteViewer;
import org.eclipse.jdt.core.JavaCore;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.MessageBox;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IPerspectiveDescriptor;
import org.eclipse.ui.IViewReference;
import org.eclipse.ui.IWorkbenchPage;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.PlatformUI;
import org.eclipse.ui.ide.IDE;
import org.eclipse.uml2.uml.Model;
import de.unikassel.janus.classdiagrams.editor.palette.ClassDiagram EditorPalette;
import de.unikassel.janus.uml2.JanusUML2;
public abstract class UITestCase extends TestCase
public static final String OUTLINE_VIEW_ID = "org.eclipse.ui.views.ContentOutline";
public static final String RESOURCE_PERSPECTIVE_ID= "org.eclipse.ui.resourcePerspective";
private Display display;
private Shell workbenchShell;
private IWorkbenchWindow workbenchWindow;
public void runBare() throws Throwable
if (getName().startsWith("uitest"))
runBareHack();
else
super.runBare();
private void runBareHack() throws Exception, Throwable
System.err.println("runBare() hack for " + getName() + " in " + this);
setUp();
try
for (int i=0; i<getVoodooCount(); ++i)
try
setUpUITest();
runTest();
finally
tearDownUITest();
finally
tearDown();
public static Test createSuiteHack(Class uiTestCaseClass)
// Collect all "standard" junit testFoo() methods.
TestSuite standardJUnitTestSuite = new TestSuite(uiTestCaseClass);
TestSuite suite = standardJUnitTestSuite;
// If there is no standard testFoo() method, TestSuite will add a warning.
if (suite.testCount() == 1 && suite.testAt(0) instanceof TestCase)
TestCase testCase = (TestCase) suite.testAt(0);
if (testCase.getName().equals("warning"))
suite = new TestSuite(uiTestCaseClass.getName());
// Now add all "UI test" uitestFoo() methods.
Method[] methods = uiTestCaseClass.getDeclaredMethods();
for (Method method : methods)
if (method.getName().startsWith("uitest"))
suite.addTest(TestSuite.createTest(uiTestCaseClass, method.getName()));
// If there is no testFoo() or uitestFoo() method, take the warning :).
if (suite.testCount() == 0)
return suite;
protected void setUpUITest() throws Exception
// Do nothing
protected void tearDownUITest() throws Exception
// Do nothing
protected void setUp() throws Exception
super.setUp();
display = Display.getCurrent();
// Close all perspectives but Resource, close all views, set workbench window size.
workbenchWindow = PlatformUI.getWorkbench().getActiveWorkbenchWindow();
workbenchShell = workbenchWindow.getShell();
IWorkbenchPage page = workbenchWindow.getActivePage();
boolean foundPerspective = false;
IPerspectiveDescriptor[] perspectives = page.getOpenPerspectives();
for (int i = 0; i < perspectives.length; i++)
IPerspectiveDescriptor perspective = perspectives[i];
if (perspective.getId().equals(RESOURCE_PERSPECTIVE_ID))
foundPerspective = true;
else
page.closePerspective(perspective, false, false);
if (!foundPerspective)
PlatformUI.getWorkbench().showPerspective(RESOURCE_PERSPECTI VE_ID, workbenchWindow);
IViewReference[] views = page.getViewReferences();
for (int i = 0; i < views.length; i++)
page.hideView(views[i]);
workbenchWindow.getShell().setSize(1000, 800);
protected void tearDown() throws Exception
super.tearDown();
protected Display getDisplay()
return display;
protected Shell getWorkbenchShell()
return workbenchShell;
protected IWorkbenchWindow getWorkbenchWindow()
return workbenchWindow;
* I do not really understand what to do to make this "post events and read and dispatch them"
* thing work reliably. It seems to have to do with the number of times I call
* display.readAndDispatch() and the amount of millis I sleep. However, letting the tests run
* several times seems to reliably expose if things work or do not work. In other words, if the
* tests run several times and pass then probably everything is good. I have seen things pass
* two times and fail at the third time, so I bump this up to 5 here to kind of be on the safe
* side.
* This weird thing is probably dependent on the machine's performance it is run on.
protected int getVoodooCount()
try
return Integer.valueOf(System.getProperty("JanusTests.VoodooCount", "5"));
catch (NumberFormatException e)
return 5;
* @return number of times <code>display.readAndDispatch()</code> is called
private int getReadAndDispatchVoodooCount()
return 5;
* @return number of milliseconds to <code>sleep()</code> between
* <code>display.readAndDispatch()</code> calls
private int getReadAndDispatchVoodooSleep()
return 1;
* Return the number of milliseconds to prevent two consecutive mouse clicks being interpreted
* as a double click.
* @return the number of milliseconds to prevent two consecutive mouse clicks being interpreted
* as a double click
protected int getPreventDoubleClickTime()
return Display.getCurrent().getDoubleClickTime() + 100;
* Return the delay in milliseconds that a direct edit operation starts with.
* @return the delay that a direct edit operation starts with
protected int getDirectEditDelay()
return 400;
protected IEditorPart openEditor(IFile file) throws PartInitException
return IDE.openEditor(getWorkbenchWindow().getActivePage(), file);
protected void closeEditor(IEditorPart editor)
editor.getEditorSite().getPage().closeEditor(editor, false);
protected IProject getOrCreateProject(String projectName) throws CoreException
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
IProject project = root.getProject(projectName);
if (!project.exists()) { project.create(null); }
if (!project.isOpen()) { project.open(null); }
IProjectDescription description = project.getDescription();
String[] natures = description.getNatureIds();
String[] newNatures = new String[natures.length + 1];
System.arraycopy(natures, 0, newNatures, 0, natures.length);
newNatures[natures.length] = JavaCore.NATURE_ID;
description.setNatureIds(newNatures);
project.setDescription(description, null);
JavaCore.create(project);
return project;
protected IFile createEmptyDiagramFile(String projectName, String fileName) throws CoreException, IOException
Model model = JanusUML2.createModel();
model.setName("emptyDiag");
return createDiagramFile(projectName, fileName, model);
protected IFile createDiagramFile(String projectName, String fileName, Model model) throws CoreException, IOException
IProject project = getOrCreateProject(projectName);
IFile file = project.getFile(fileName);
ByteArrayOutputStream outputStream = JanusUML2.createStream(model, file);
file.create(new ByteArrayInputStream(outputStream.toByteArray()), false, null);
JanusUML2.disposeDiagram(file);
return file;
protected void deleteFile(String projectName, String fileName) throws CoreException
if (file.exists())
file.delete(false, null);
protected void selectTool(GraphicalViewer graphicalViewer, String toolID)
PaletteViewer paletteViewer = graphicalViewer.getEditDomain().getPaletteViewer();
ClassDiagramEditorPalette palette = (ClassDiagramEditorPalette) paletteViewer.getPaletteRoot();
paletteViewer.setActiveTool(ClassDiagramEditorPalette.findTo olEntry(palette, toolID));
protected Event post(Event event)
* It seems I do not need to fill in the time and current mouse pointer position. Let's see.
getDisplay().post(event);
readAndDispatchEvents();
return event;
protected void activateDirectEdit()
postTwoLeftMouseClicks();
sleep(getDirectEditDelay());
protected void postTwoLeftMouseClicks()
postLeftMouseClick();
sleep(getPreventDoubleClickTime());
protected void postLeftMouseClick()
postMouseClick(1);
protected void postMouseClick(int button)
postMouseDown(button);
postMouseUp(button);
protected void postLeftMouseDrag(Control control, int x, int y)
postMouseDrag(control, 1, x, y);
protected void postMouseDrag(Control control, int button, int x, int y)
postMouseMove(control, x, y, SWT.BUTTON1); // FIXME
postMouseUp(button); // FIXME: See below: statemask
/* mouse drag:
mouse down: MouseEvent{FigureCanvas {} time=15876882 data=null button=1 stateMask=0 x=137 y=92}
mouse move: MouseEvent{FigureCanvas {} time=15879432 data=null button=0 stateMask=524288 x=138 y=92}
mouse move: MouseEvent{FigureCanvas {} time=15887473 data=null button=0 stateMask=524288 x=139 y=92}
mouse up: MouseEvent{FigureCanvas {} time=15892969 data=null button=1 stateMask=524288 x=139 y=92}
protected Event postMouseDown(int button)
Event event = new Event();
event.type = SWT.MouseDown;
event.button = button;
return post(event);
protected Event postMouseUp(int button)
event.type = SWT.MouseUp;
return post(event);
protected Event postMouseMove(Control control, org.eclipse.draw2d.geometry.Point point)
return postMouseMove(control, point.x, point.y, SWT.NONE);
protected Event postMouseMove(Control control, int x, int y)
return postMouseMove(control, x, y, SWT.NONE);
protected Event postMouseMove(Control control, int x, int y, int stateMask)
Point point = getDisplay().map(control, null, x, y);
event.type = SWT.MouseMove;
event.x = point.x;
event.y = point.y;
event.stateMask = stateMask;
return post(event);
protected void postDoubleEscape()
postKey(SWT.ESC);
postKey(SWT.ESC);
protected void postKeys(String string)
for (int i=0; i<string.length(); i++)
char character = string.charAt(i);
boolean shift = Character.isUpperCase(character);
character = Character.toLowerCase(character);
if (shift)
postKeyDown(SWT.SHIFT);
postKeyDown(character);
postKeyUp(character);
if (shift)
postKeyUp(SWT.SHIFT);
protected void postKey(char character)
protected Event postKeyDown(char character)
event.type = SWT.KeyDown;
event.character = character;
return post(event);
protected Event postKeyUp(char character)
event.type = SWT.KeyUp;
return post(event);
protected void postKey(int keyCode)
postKeyDown(keyCode);
postKeyUp(keyCode);
protected Event postKeyDown(int keyCode)
event.keyCode = keyCode;
return post(event);
protected Event postKeyUp(int keyCode)
return post(event);
protected void sleep(long millis)
try { Thread.sleep(millis); } catch (InterruptedException e) { /* Empty */ }
protected void readAndDispatchEvents()
readAndDispatchEventsLoop(getReadAndDispatchVoodooCount(), getReadAndDispatchVoodooSleep());
private void readAndDispatchEventsLoop(int times, int millis)
while (times > 0)
readAndDispatchEventsOnce();
sleep(millis);
--times;
private void readAndDispatchEventsOnce()
while (getDisplay().readAndDispatch())
// Do nothing.
protected void waitUserInput()
getDisplay().syncExec(new Runnable() {
public void run()
waitForMessageBox();
void waitForMessageBox()
final Shell shell = new Shell(getDisplay(), SWT.NO_FOCUS );
shell.setText("Bla Shell");
shell.setLocation(1500, 100);
shell.setSize(50, 50);
shell.open();
while (true)
MessageBox box = new MessageBox(shell, SWT.NO_FOCUS | SWT.OK | SWT.PRIMARY_MODAL);
box.setText("bla");
box.setMessage("Click to continue.");
box.open();
break;
shell.close();
* Without this, Draw2D figures have bounds (0, 0, 0, 0).
protected void warmupDraw2D()
protected org.eclipse.draw2d.geometry.Point getLeftSide(IFigure figure)
Rectangle bounds = figure.getBounds();
return new org.eclipse.draw2d.geometry.Point(bounds.x + 3, bounds.y + bounds.height/2);
protected org.eclipse.draw2d.geometry.Point getCenter(IFigure figure)
return new org.eclipse.draw2d.geometry.Point(bounds.x + bounds.width/2, bounds.y + bounds.height/2);
name="DirectEditTest.java"
filename="DirectEditTest.java"
* Contact Address:
* Thomas Maier
* 34121 Kassel
* Germany
import org.eclipse.gef.commands.CommandStack;
import org.eclipse.uml2.uml.Property;
import de.unikassel.janus.classdiagrams.editparts.AttributeEditPart ;
import de.unikassel.janus.classdiagrams.editparts.ClassEditPart;
import de.unikassel.janus.classdiagrams.model.commands.CreateAttrib uteCommand;
import de.unikassel.janus.classdiagrams.model.commands.CreateClassC ommand;
public class DirectEditTest extends UITestCase
private IFile file;
private IEditorPart editorPart;
private Model model;
private CommandStack commandStack;
private GraphicalViewer graphicalViewer;
public static Test suite()
return createSuiteHack(DirectEditTest.class);
super.setUp();
file = createEmptyDiagramFile("de.unikassel.janus.tests", "DirectEditTest.uml");
super.tearDown();
editorPart = openEditor(file);
model = (Model) editorPart.getAdapter(Model.class);
commandStack = (CommandStack) editorPart.getAdapter(CommandStack.class);
graphicalViewer = (GraphicalViewer) editorPart.getAdapter(GraphicalViewer.class);
closeEditor(editorPart);
public void uitestRenameClass() throws Exception
CreateClassCommand createClassCommand = CommandTest.createClass(commandStack, model, 50, 50);
org.eclipse.uml2.uml.Class uml2Class = createClassCommand.getNewClass();
warmupDraw2D();
String newClassName = "Foobar";
assertFalse(newClassName.equals(uml2Class.getName())); // be sure to test something
ClassEditPart classEditPart = (ClassEditPart) graphicalViewer.getEditPartRegistry().get(uml2Class);
postMouseMove(graphicalViewer.getControl(), getLeftSide(classEditPart.getFigure()));
activateDirectEdit();
postKeys(newClassName + "\r");
assertEquals(newClassName, uml2Class.getName());
public void uitestRenameAttribute() throws Exception
CreateAttributeCommand createAttributeCommand = CommandTest.createAttribute(commandStack, uml2Class);
Property attribute = createAttributeCommand.getNewClassMember();
warmupDraw2D();
String newAttributeName = "foo";
assertFalse(newAttributeName.equals(attribute.getName())); // be sure to test something
AttributeEditPart attributeEditPart = (AttributeEditPart) graphicalViewer.getEditPartRegistry().get(attribute);
postMouseMove(graphicalViewer.getControl(), getLeftSide(attributeEditPart.getFigure()));
postKeys(newAttributeName + "\r");
assertEquals(newAttributeName, attribute.getName());
name="ClassTest.java"
filename="ClassTest.java"
* Contact Address:
* Thomas Maier
* 34121 Kassel
* Germany
import org.eclipse.draw2d.geometry.Dimension;
import org.eclipse.draw2d.geometry.Point;
import org.eclipse.gef.GraphicalEditPart;
import org.eclipse.uml2.uml.Type;
public class ClassTest extends UITestCase
private IFile file;
return createSuiteHack(ClassTest.class);
super.setUp();
file = createEmptyDiagramFile("de.unikassel.janus.tests", "ClassTest.uml");
public void uitestCreateMoveResizeClass() throws Exception
assertEquals(0, model.getOwnedTypes().size());
* Is this a GEF bug? It seems the mouse always has to be moved after activating a tool.
postMouseMove(graphicalViewer.getControl(), 50, 60);
selectTool(graphicalViewer, ClassDiagramEditorPalette.TOOL_ID_NEW_CLASS);
postMouseMove(graphicalViewer.getControl(), 70, 80);
assertEquals(1, model.getOwnedTypes().size());
Type newClass = model.getOwnedType("NewClass");
assertNotNull(newClass);
assertEquals(new Point(70, 80), JanusUML2.getLocation(newClass));
postMouseMove(graphicalViewer.getControl(), 70+10, 80+10);
postLeftMouseDrag(graphicalViewer.getControl(), 70+10+50, 80+10+60);
assertEquals(new Point(70+50+1, 80+60+1), JanusUML2.getLocation(newClass)); // FIXME: why +1?
GraphicalEditPart newClassEditPart = (GraphicalEditPart) graphicalViewer.getEditPartRegistry().get(newClass);
Dimension size = newClassEditPart.getFigure().getSize();
postMouseMove(graphicalViewer.getControl(), 120, 140);
postLeftMouseDrag(graphicalViewer.getControl(), 120-20, 140-10);
Dimension changedSize = newClassEditPart.getFigure().getSize();
assertEquals(size.width + 20, changedSize.width);
assertEquals(size.height+ 10, changedSize.height);
--------------050103070407050408090209--
Current Time: Tue Apr 23 12:26:55 GMT 2024
Powered by FUDForum. Page generated in 0.02929 seconds
