Home » Eclipse Projects » e(fx)clipse » DS services problem
DS services problem [message #1342596] Thu, 08 May 2014 21:06 Go to next message
I have created empty efx application. It just shows plain window. I'v
added plugin with DS component to application feature. When I run
product it does not register my service. When I run the same plugin
under OSGi framework it registers its service. org.eclipse.equinox.ds,
org.eclipse.osgi.services and org.eclipse.equinox.util plugin are
mentioned in feature.
What may be wrong?
I am using nightly efx all in one :
eclipse-SDK-4.4M6-win32-x86_64-efx-1.0.0-SNAPSHOT
En iyi dileklerimle
Jeyhun MAMEDOV
Ekser Bilişim Danışmanlık Ltd.Şti.
Dinamik Hukuk Grubu
Yazılım Uzmanı
www.dinamikhukuk.com
<http://s.wisestamp.com/links?url=http%3A%2F%2Fwww.dinamikhukuk.com>
Tel : (0312) 431 0905
Faks : (0312) 431 0965
GSM : (0554) 402 4441
Re: DS services problem [message #1343149 is a reply to message #1342596] Fri, 09 May 2014 02:47 Go to previous messageGo to next message
Is your bundle marked with
Bundle-ActivationPolicy: lazy
Tom
On 09.05.14 03:06, tjey wrote:
> What may be wrong?
> En iyi dileklerimle
> Jeyhun MAMEDOV
> Dinamik Hukuk Grubu
> Yazılım Uzmanı
Re: DS services problem [message #1343831 is a reply to message #1343149] Fri, 09 May 2014 09:29 Go to previous messageGo to next message
Hi Tom
No, plugin is not marked with Bundle-ActivationPolicy.
I'v figured out that it must be checked on "Activate this plug-in when one
of its classes is loaded".
What is interesting that this is required when you launch this plugin whith
PDE or JavaFX e4 application. Running under standart OSGi configuration
does not create problem. Is this a bug?
Re: DS services problem [message #1343897 is a reply to message #1343831] Fri, 09 May 2014 10:08 Go to previous message
Yes - checking that box makes the bundle activation policy lazy!
Yes that's expected - if you start with the OSGi-Launcher ALL bundles
are started by default whereas in PDE/Eclipse mode they are launched on
demand and then the policy is needed to make equinox.ds do the right
thing for you.
Tom
On 09.05.14 15:29, Jeyhun MAMEDOV wrote:
> Hi Tom
Previous Topic:Custom Preloader
Next Topic:How to avoid crashing the JVM on Linux with GTK3
Current Time: Sat May 24 04:01:38 EDT 2025
Powered by FUDForum. Page generated in 0.04530 seconds
