Re: Big Performance Issue - Hit Testing on Editor Activation [message #231544 is a reply to message #231434] |
Sat, 10 March 2007 13:44 |
Originally posted by: none.ibm.com
That code is known to have n^2 performance, unfortunately. A patch could
probably improve it. You can also short circuit the whole focus search by
setting the top figure as disabled or no focusable or something like that.
That probably makes the most sense.
"AdamC" <acabler@hotmail.com> wrote in message
news:esq4dm$d63$1@utils.eclipse.org...
>I did some more digging and it looks like all the time is being spent in
>FocusTraverseManager.getNextFocusableFigure. This is making things
>unusable for me atm. If anyone has some thoughts on this, I would
>appreciate it.
> adam
> AdamC wrote:
>> I recently added several thousand connections to my diagram. I fixed
>> some scrolling problems, but now I am having a problem I don't think I
>> can fix. When selecting the diagram editor, it is taking around 5
>> seconds to become active. I profiled it and it seems that hit testing
>> (containsPoint()) is being done on _every_ edit part in the diagram and
>> this is what is consuming the time. I wanted to see if anyone else has
>> this problem and if there is something that can be done.
>> thanks,
>> adam
Re: Big Performance Issue - Hit Testing on Editor Activation [Solved - FocusTraversalManager] [message #231568 is a reply to message #231441] |
Sat, 10 March 2007 21:07 |
Originally posted by: kvdijken.tiscali.nl
I also had troubles with performance on very large models. Besides doing your trick, I also
implemented a spatial index in figures with many children. This made it (selection and such) fly again.
Koen
AdamC wrote:
> ok - I think I fixed the problem. I made my diagram figures focus
> traversable. This makes getNextFocusableFigure return really quickly and
> doesn't have to iterate over the 100k figures in my diagram. I hope
> maybe this helps someone else...
> adam
>> in FocusTraverseManager.getNextFocusableFigure. This is making things
>> appreciate it.
>> adam
>>> I can fix. When selecting the diagram editor, it is taking around 5
>>> testing (containsPoint()) is being done on _every_ edit part in the
>>> diagram and this is what is consuming the time. I wanted to see if
>>> anyone else has this problem and if there is something that can be done.
>>> thanks,
>>> adam
FUDForum. Page generated in 0.03837 seconds
