Re: Serializing Documenation elements [message #231652 is a reply to message #231491] |
Wed, 20 May 2009 05:28 |
Originally posted by: valentinbaciu.hotmail.com
Ravikanath, you seem to have run into a limitation of the WSDL EMF model.
I have opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=277056 to track
this.
In the mean time, try this working example, which shows you how to work
around the limitation.
public class DocumentationSample extends TestCase
private static final String WSDL_PREFIX = "wsdl"; //$NON-NLS-1$
public void testSupportsDocumentationElements() throws Exception
ResourceSetImpl resourceSet = new ResourceSetImpl();
WSDLResourceImpl wsdlResource =
(WSDLResourceImpl)resourceSet.createResource(URI.createFileU RI( "documentationTest.wsdl"));
WSDLFactory factory = WSDLFactory.eINSTANCE;
Definition definition = factory.createDefinition();
wsdlResource.getContents().add(definition);
definition.setTargetNamespace("http://www.example.org");
definition.addNamespace(WSDL_PREFIX, WSDLConstants.WSDL_NAMESPACE_URI);
definition.updateElement(true);
Document document = definition.getDocument();
Element documentationElement =
document.createElementNS(WSDLConstants.WSDL_NAMESPACE_URI, WSDL_PREFIX + ":"
+ WSDLConstants.DOCUMENTATION_ELEMENT_TAG);
// Workaround WSDL EMF model limitation.
Element definitionElement = definition.getElement();
// Change this line appropriately to ,ake sure you insert
// the definition element as the first child.
definitionElement.insertBefore(documentationElement, null);
// End workaround
definition.setDocumentationElement(documentationElement);
Element docChild = document.createElement("DocumentationElement");
docChild.setAttribute("ProcessInfo", "someValue");
documentationElement.appendChild(docChild);
wsdlResource.save(null);
The above code creates a WSDL document that looks like this:
<wsdl:definitions xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
targetNamespace="http://www.example.org">
<wsdl:documentation>
<DocumentationElement ProcessInfo="someValue"/>
</wsdl:documentation>
</wsdl:definitions>
"Ravikanth " <ravikanth.somayaji@gmail.com> wrote in message
news:c92b98a5d999b68c6119fdf781322c51$1@www.eclipse.org...
> Thanks for the reply Gabriel.
> That's the piece I have in my code to add a documentation element to the
> wsdlelement.
> public static void createDocElement(Object definitionObj,
> Object wsdlElementObj, String elementName, String attrib,
> String val) {
> if (definitionObj instanceof Definition) {
> Definition definition = (Definition) definitionObj;
> if (wsdlElementObj instanceof ExtensibleElement) {
> WSDLElement wsdlElement = (WSDLElement) wsdlElementObj;
> Attr attr =
> definition.getDocument().createAttribute("ProcessInfo");
> attr.setValue(elementName + ":::" + val);
> wsdlElement.getDocumentationElement();
> if (documentationElement == null) {
> documentationElement.setAttributeNode(attr);
> wsdlElement.setDocumentationElement(documentationElement);
> try {
> definition.eResource().save(null);
> } catch (IOException e) {
> // TODO Auto-generated catch block
> e.printStackTrace();
> System.out.println("Document##"
> + wsdlElement.getDocumentationElement());
> However, the wsdl fragment for which i run the code against still looks
> like this
> <wsdl:portType name="RTestW">
> <wsdl:operation name="NewOperation">
> <wsdl:input message="tns:NewOperationRequest"/>
> <wsdl:output message="tns:NewOperationResponse"/>
> </wsdl:operation>
> </wsdl:portType>
> and I would expect <wsdl:portType name="RTestW">
> <wsdl:documentation>ProcessInfo=elementName:::value</wsdl:documentation >
> </wsdl:operation>
> </wsdl:portType>
> Gabriel Indik wrote:
>> Ravi,
>> To better understand the problem, could you please paste a small code
>> fragment/snippet that shows the API calls you are making to incorporate
>> the documentation elements as well as the document serialization?
FUDForum. Page generated in 0.24418 seconds
