Home » Newcomers » Newcomers » Resetting Eclipse?(I need to start all over!)
icon9.gif  Resetting Eclipse? [message #1341749] Thu, 08 May 2014 16:31 Go to next message
Linsey Gabaldon is currently offline Linsey GabaldonFriend
Hello! I am new to Eclipse and I am trying to teach myself Java. I, being myself, immediately closed part of the workbench display and cannot figure out how to open it again. Then I made a serious series of errors that I cannot undo. I need to start all over. I deleted Eclipse, reloaded it, and opened it again, and it gave me the same horribly altered workbench and I cannot figure out how to get back to my original screen. Can you help please? I'm so frustrated!
Thank you so much!
Re: Resetting Eclipse? [message #1342113 is a reply to message #1341749] Thu, 08 May 2014 20:15 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
From the Window menu select Reset Perspective. This should return the perspective to the default.
Re: Resetting Eclipse? [message #1342230 is a reply to message #1342113] Thu, 08 May 2014 21:23 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
If that doesn't work, you can delete your workspace (not Eclipse itself) on disk. Be aware that doing so will delete any code that you might have put in the workspace.
Re: Resetting Eclipse? [message #1351935 is a reply to message #1341749] Tue, 13 May 2014 08:15 Go to previous message
teodora chiru is currently offline teodora chiruFriend
I agree with Eric, that's best.
Previous Topic:Eclipse Error
Next Topic:Log error when starting eclipse
Current Time: Sun Jun 20 10:25:13 GMT 2021
Powered by FUDForum. Page generated in 0.02531 seconds
