Re: WTP project configuration is failing [message #230243 is a reply to message #230232] |
Fri, 10 April 2009 19:41 |
Originally posted by: dcarver.starstandard.org
You might get a better response from the m2eclipse projects newsgroup.
I've copied them on this response.
David Durham wrote:
> Ok, so the project is a maven project with a packaging of 'war'.
> M2Eclipse recognizes that it should setup a web project, and this
> generally works, but one of my coworkers is running into this issue on
> his machine. Any help is appreciated. Stack trace follows:
> !ENTRY org.maven.ide.eclipse 4 0 2009-04-10 11:58:37.396
> !MESSAGE Unable to configure core-persistence-service
> !STACK 0
> org.maven.ide.eclipse.wtp.MarkedException: Unable to configure
> at
> org.maven.ide.eclipse.wtp.AbstractProjectConfiguratorDelegat e.configureProject(AbstractProjectConfiguratorDelegate.java: 69)
> at
> org.maven.ide.eclipse.wtp.WTPProjectConfigurator.configure(W TPProjectConfigurator.java:42)
> at
> org.maven.ide.eclipse.internal.project.ProjectConfigurationM anager.updateProjectConfiguration(ProjectConfigurationManage r.java:292)
> at
> org.maven.ide.eclipse.internal.project.ProjectConfigurationM anager.configureNewMavenProject(ProjectConfigurationManager. java:215)
> at
> org.maven.ide.eclipse.internal.project.ProjectConfigurationM anager.importProjects(ProjectConfigurationManager.java:154)
> at
> org.maven.ide.eclipse.wizards.MavenImportWizard$1.runInWorks pace(MavenImportWizard.java:94)
> at
> org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by: org.eclipse.core.runtime.CoreException: Failed while
> installing Dynamic Web Module 2.4.
> at
> org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.callDelegate(FacetedProject.java:1423)
> at
> org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.modifyInternal(FacetedProject.java:401)
> at
> org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.mergeChangesInternal(FacetedProject.java:1134)
> at
> org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.access$2(FacetedProject.java:1070)
> at
> org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject$1.run(FacetedProject.java:309)
> at
> org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
> at
> org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.modify(FacetedProject.java:319)
> at
> org.maven.ide.eclipse.wtp.WebProjectConfiguratorDelegate.con figure(WebProjectConfiguratorDelegate.java:90)
> at
> org.maven.ide.eclipse.wtp.AbstractProjectConfiguratorDelegat e.configureProject(AbstractProjectConfiguratorDelegate.java: 65)
> ... 7 more
> Caused by: java.lang.NullPointerException
> at
> org.eclipse.jst.j2ee.web.project.facet.WebFacetInstallDelega te.setContentPropertyIfNeeded(WebFacetInstallDelegate.java:2 65)
> at
> org.eclipse.jst.j2ee.web.project.facet.WebFacetInstallDelega te.execute(WebFacetInstallDelegate.java:89)
> at
> org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.callDelegate(FacetedProject.java:1394)
> ... 15 more
> !ENTRY org.eclipse.core.jobs 4 2 2009-04-10 11:58:37.443
> !MESSAGE An internal error occurred during: "Importing Maven projects".
> !STACK 0
> at
> org.maven.ide.eclipse.wtp.WebProjectConfiguratorDelegate.set ModuleDependencies(WebProjectConfiguratorDelegate.java:131)
> at
> org.maven.ide.eclipse.wtp.WTPProjectConfigurator.mavenProjec tChanged(WTPProjectConfigurator.java:60)
> at
> org.maven.ide.eclipse.project.configurator.AbstractProjectCo nfigurator.mavenProjectChanged(AbstractProjectConfigurator.j ava:112)
> at
> org.maven.ide.eclipse.internal.project.ProjectConfigurationM anager.mavenProjectChanged(ProjectConfigurationManager.java: 638)
> at
> org.maven.ide.eclipse.internal.project.MavenProjectManagerIm pl.notifyProjectChangeListeners(MavenProjectManagerImpl.java :698)
> at
> org.maven.ide.eclipse.internal.project.ProjectConfigurationM anager.configureNewMavenProject(ProjectConfigurationManager. java:218)
> at
> at
> at
> !ENTRY org.eclipse.jst.j2ee 4 0 2009-04-10 11:58:38.865
> !MESSAGE
> !STACK 0
> at
> org.eclipse.jst.j2ee.internal.deployables.J2EEDeployableFact ory.createModuleDelegates(J2EEDeployableFactory.java:82)
> at
> org.eclipse.jst.j2ee.internal.deployables.J2EEDeployableFact ory.createModules(J2EEDeployableFactory.java:68)
> at
> org.eclipse.jst.j2ee.internal.deployables.J2EEDeployableFact ory.createModules(J2EEDeployableFactory.java:56)
> at
> org.eclipse.wst.server.core.util.ProjectModuleFactoryDelegat e.cacheModules(ProjectModuleFactoryDelegate.java:59)
> at
> org.eclipse.wst.server.core.util.ProjectModuleFactoryDelegat e.getModules(ProjectModuleFactoryDelegate.java:255)
> at
> org.eclipse.wst.server.core.internal.ModuleFactory.getModule s(ModuleFactory.java:131)
> at
> org.eclipse.wst.server.core.ServerUtil.getModules(ServerUtil .java:96)
> at
> org.eclipse.wst.server.core.internal.ResourceManager.publish HandleProjectChange(ResourceManager.java:965)
> at
> org.eclipse.wst.server.core.internal.ResourceManager$ServerR esourceChangeListener$1.visit(ResourceManager.java:122)
> at
> org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:68)
> at
> org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:79)
> at
> org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:48)
> at
> org.eclipse.wst.server.core.internal.ResourceManager$ServerR esourceChangeListener.resourceChanged(ResourceManager.java:1 16)
> at
> org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:288)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at
> org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:282)
> at
> org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:148)
> at
> org.eclipse.core.internal.resources.Workspace.broadcastBuild Event(Workspace.java:297)
> at
> org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:143)
> at
> org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:238)
> !ENTRY org.maven.ide.eclipse 4 0 2009-04-10 11:58:38.974
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> org.maven.ide.eclipse.internal.project.MavenProjectManagerIm pl.refresh(MavenProjectManagerImpl.java:366)
> at
> org.maven.ide.eclipse.internal.project.MavenProjectManagerRe freshJob.run(MavenProjectManagerRefreshJob.java:94)
Re: WTP project configuration is failing [message #230251 is a reply to message #230243] |
Fri, 10 April 2009 20:49 |
Originally posted by: igor.ifedorenko.com
I've seen problems like this with partially installed WTP. If the same
project works on other machines, this is what I would check first,
ideally reinstall eclipse/wtp/m2e clean.
If the problem is reproducible in other environments, then create new
bugreport in m2e JIRA [1] and provide sample project and steps to reproduce.
Igor
[1] https://issues.sonatype.org/browse/MNGECLIPSE
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 7 more
>> at
>> at
>> at
>> ... 15 more
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !MESSAGE
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !MESSAGE
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
FUDForum. Page generated in 0.03028 seconds
