Re: Help: WTK2.5.2 + MTJ 0.9 + Eclipse 3.4.1 + JRE6_10 [message #22963 is a reply to message #22919] |
Wed, 19 November 2008 00:30 |
Originally posted by: craigjunk.setera.org
Can you run emulator.exe from the command line? If not, I would agree
with Gustavo that this appears to be a bad installation of the WTK.
Gustavo de Paula wrote:
> there is no problem to use the dev list. we are just trying to drive
> more the user community to the newsgroup :)
> about the issue, it is really strange. the emaulator.exe is the base
> executable that is called by MTJ so it is not support to generate that
> error. can you use wtk "run as" and run a jar/jad ? besides that, can
> you try other SDK such as motorola or sony ericsson. my last suggestion
> is to download wtk again and see if it solves the problem. it really
> seems like an issue with the wtk install. netbeans might work because
> maybe they don't call the emulator.exe file since everything is done by sun
> if you are not able to fix this, please let me know and i will see if i
> have more ideas
> regards,
> gustavo
Re: Help: WTK2.5.2 + MTJ 0.9 + Eclipse 3.4.1 + JRE6_10 [message #26756 is a reply to message #22963] |
Wed, 18 February 2009 17:32 |
Luciano Mollea Messages: 2 Registered: July 2009 |
Sorry to bump this old thread, but it seems that I have the same problem.
My environment is the same as in this issue, safe from the latest version
of MTJ (WinXP + Ganymede SR1 + MTJ 0.9.1 + WTK 2.5.2).
When I try to inspect WTK dir for devices no device are found. I've been
using EclipseME and it worked fine.
jad files can be executed via Explorer, *but* i found that in
WTK2.5.5/bin directory, the emulator.exe is missing, there is only
emulatorw.exe
Could be this the problem? Strange because I installed WTK long time ago
and EclipseME (as I said) worked fine.
Thanks in advance for the help.
>> have more ideas
>> regards,
>> gustavo
Re: Help: WTK2.5.2 + MTJ 0.9 + Eclipse 3.4.1 + JRE6_10 [message #27109 is a reply to message #26756] |
Wed, 25 February 2009 01:02 |
That would definitely cause an issue. The Unified Emulator Interface
specification requires the "emulator.exe" and that is what MTJ is
looking for when searching. You could try copying emulatorw.exe to
emulator.exe and see what happens. I believe that emulator.exe just
delegates to emulatorw.exe on Windows anyway. I can't offer guarantees
it will work though.
The more interesting question in my mind is why this happened and is
there some specific scenario that is causing these invalid WTK
installations?
Craig
> version of MTJ (WinXP + Ganymede SR1 + MTJ 0.9.1 + WTK 2.5.2).
> emulatorw.exe
Re: Help: WTK2.5.2 + MTJ 0.9 + Eclipse 3.4.1 + JRE6_10 [message #571236 is a reply to message #22963] |
emulatorw.exe
>> have more ideas
>> regards,
>> gustavo
FUDForum. Page generated in 0.03288 seconds
