Home » Eclipse Projects » Remote Application Platform (RAP) » Java Exception when using RAP Google Maps Widget
Java Exception when using RAP Google Maps Widget [message #1336198] Tue, 06 May 2014 05:24 Go to next message
I have problems with the RAP Google Maps Widget.
When updates in the maps occur (e.g. setting or removing a marker) sometimes an exception occurs.
type Exception report
message Failed to evaluate Javascript expression
description The server encountered an internal error that prevented it from fulfilling this request.
exception
org.eclipse.swt.SWTException: Failed to evaluate Javascript expression
	org.eclipse.swt.browser.Browser.createException(Browser.java:596)
	org.eclipse.swt.browser.Browser.evaluate(Browser.java:335)
	com.eclipsesource.widgets.gmaps.GMap.addMarker(GMap.java:168)
	org.eclipse.rap.demo.gmaps.internal.GMapsExamplePage$8.widgetSelected(GMapsExamplePage.java:204)
	org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:262)
	org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:85)
	org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:699)
	org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:601)
	org.eclipse.swt.widgets.Display.executeNextEvent(Display.java:1208)
	org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1189)
	org.eclipse.swt.widgets.Display.safeReadAndDispatch(Display.java:1172)
	org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1164)
	org.eclipse.swt.browser.Browser.execute(Browser.java:260)
	org.eclipse.swt.browser.Browser.evaluate(Browser.java:333)
	org.eclipse.rap.rwt.application.AbstractEntryPoint.createUI(AbstractEntryPoint.java:62)
	org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:186)
	org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:298)
	java.lang.Thread.run(Thread.java:722)
	org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:104)
This can be reproduced with the demo at
rap.eclipsesource.com/demo/release/rapdemo/examples#gmaps
(sorry I'm not allowed to use links yet)
by clicking "Add Marker" several times quite fast.
Sometimes it occurs on the first few clicks sometimes it takes some seconds of fast clicking.
(BTW fast clicking is not the reason it just raises the chance, it happens also with sporadic update events)
I reproduced this with
Firefox 28.0 on Windows 7
Firefox 18.0.2 on Linux
IE 11.0 on Windows 7
best regards
Richard
Re: Java Exception when using RAP Google Maps Widget [message #1336851 is a reply to message #1336198] Tue, 06 May 2014 11:52 Go to previous messageGo to next message
Hi.
I could reproduce it in Firefox. It might be a bug in the Browser
widget. We are looking into it. In the meanwhile you could a bug report
here:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=RAP&rep_platform=All&op_sys=all
Greetings,
Tim
Am 06.05.2014 15:45, schrieb Richard Skriwanek:
> exception
> best regards
> Richard
Tim Buschtöns
Twitter: @EclipseRAP
Re: Java Exception when using RAP Google Maps Widget [message #1336994 is a reply to message #1336198] Tue, 06 May 2014 13:19 Go to previous messageGo to next message
Hi Richard,
I can reproduce the issue with our Examples Demo -> GMap page too. I did
some debugging and here are the results. addMarker is called in button
selection event. When you click fast it's possible to have more than one
button Selection notify operation in a single protocol message
(request). This schedule multiple Selection events. When first event is
processed -> addMarker is called -> Browser#evaluate is called. Inside
Browser#evaluate the readAndDispatch loop is executed, which trigger the
next Selection event and call addMarker again. This second call
immediately throw SWTException in Browser#evaluate, because another
evaluate operation is already scheduled (Browser#executeScript is not
null) and this second call can't be processed. From my point of view
this behavior is expected - SWTException SWT.ERROR_FAILED_EVALUATE is
thrown. You should always wrap Browser#evaluate in a try/catch clause,
because such exception is expected in case of evaluation failure.
Best,
Ivan
Ivan Furnadjiev
Re: Java Exception when using RAP Google Maps Widget [message #1337028 is a reply to message #1336994] Tue, 06 May 2014 13:37 Go to previous messageGo to next message
Thanks for the analysis.
I have written an application that is based on the demo code. There the marker is modified depending on the value of some database records. These records do currently not change more often than once every 10s. This application never runs any longer than a few hours without generating this exception. Therefore i suspected it to be a timing problem and not a problem of frequeny.
But probably this is another issue. I'll check if i can catch the exception as you mentioned.
Best regards
Richard
Re: Java Exception when using RAP Google Maps Widget [message #1338456 is a reply to message #1337028] Wed, 07 May 2014 04:11 Go to previous messageGo to next message
Wraping Browser#evaluate catches the fast-click induced exceptions. I have it running now with the slow automatic updates and will see if this catches also the exceptions that occured without user interaction.
--Richard
Re: Java Exception when using RAP Google Maps Widget [message #1338515 is a reply to message #1336994] Wed, 07 May 2014 04:47 Go to previous messageGo to next message
I'm not sure if this should be expected behavior, but for now I will
just adjust the GMap widget.
Am 06.05.2014 19:19, schrieb Ivan Furnadjiev:
> Hi Richard,
> Best,
> Ivan
Tim Buschtöns
Re: Java Exception when using RAP Google Maps Widget [message #1338979 is a reply to message #1338515] Wed, 07 May 2014 09:08 Go to previous messageGo to next message
I copy your doubts.
As for my aplication lost updates are not acceptable this means I have to implement some queuing mechanism.
--Richard
Re: Java Exception when using RAP Google Maps Widget [message #1339177 is a reply to message #1338979] Wed, 07 May 2014 10:59 Go to previous message
This seems to be the same case as either [1] or [2]. I created a patch which has been updated to the 2.2 maintenance branch but would need updated for the latest 2.3 milestone. I'll try to get it converted to a Gerrit review.
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=371133
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=371132
-- Cole
Previous Topic:How to reload resources on the fly?
Next Topic:Is Copy operation supported in Drag And Drop ?
Current Time: Sun Nov 02 01:14:25 EDT 2025
Powered by FUDForum. Page generated in 0.04173 seconds
