TOPCASED Connect to a SVN Server using https [message #1333792] |
Mon, 05 May 2014 08:23 |
Philip LOUCOPOULOS Messages: 30 Registered: May 2014 |
Member |
I'm having problem to connect TOPCASED to my SVN server. When I use the function
SVN repositories or SVN repository browser, I fill in the URL to my freshly created SVN server then my user + password. But it doesn't pass the "validate repository location" and requires continuously my user+pwd...
On the other side, I can access to my SVN server by using a browser.
Can you help me solve this problem ?
Thanks in advance for any support !
Philip LOUCOPOULOS
Attachment: Capturer.JPG
(Size: 133.24KB, Downloaded 224 times)
[Updated on: Tue, 06 May 2014 13:41] Report message to a moderator
TOPCASED Connect to a SVN Server using https [message #1334354 is a reply to message #1334276] |
Mon, 05 May 2014 14:33 |
Member |
Hi Ed,
Thank you for your answer !
Actually, I am running with the following version TortoiseSVN: 1.7.1. So this is not the pb.
What is happening is the following:
The connection to my https SVN server does not happen, the message is:
java.lang.SecurityException: Impossible de trouver une configuration de connexion
What is this configuration connection ?
Does TOPCASED 5.3.0 allow to connect via htpps to a Visual SVN Server ?
Thank you
Philip
FUDForum. Page generated in 0.02702 seconds
