Home » Language IDEs » ServerTools (WTP) » Re: AprLifecycleListener not initializing in Tomcat Startup
Re: AprLifecycleListener not initializing in Tomcat Startup [message #228767] |
Wed, 11 March 2009 01:31 |
Ed Merks Messages: 33139 Registered: July 2009 |
Matt,
Maybe it's better to ask on the WTP newsgroup, which I've added to the
"to" list of this reply.
Matt wrote:
> I am currently getting a feel for writing Servlets and JSP in Eclipse
> and WTP, something I've previously always used NetBeans for in the past.
> One issue I'm having [at least it looks like an issue] is that when I
> start Tomcat either by itself or via running a JSP or Servlet 'on the
> server', the console shows this message:
> Mar 10, 2009 7:57:19 PM org.apache.catalina.core.AprLifecycleListener
> init
> INFO: The Apache Tomcat Native library which allows optimal
> performance in production environments was not found on the
> java.library.path: [it then lists the folders/files in my classpath ].
> In java.library.path it lists is the folder that contains
> catalina.jar [ C:\apache-tomcat-6.0.14\lib ].
> In addition, I have copied catalina.jar to the web directory in Tomcat
> it is using:
> C:\apache-tomcat-6.0.14\wtpwebapps\web1\WEB-INF\lib
> but that actually caused an error, so I removed it.
> I am not sure if this is the issue or not, but in my project's Properties
>>> Java Build Path, the Libraries tab has a library, "Apache Tomcat v6.0
> [Apache Tomcat v6.0]", and under that there is "catalina.jar", which
> points to the correct place. However, for the three attributes of the
> jar file [Source Attachment, Javadoc Location, Native Library
> Location] are listed as (None), and the Access Rules are (No
> restrictions).
> I don't know if there is supposed to be something else there.
> I don't know if this is actually a problem, because things are
> working, but it does seem that there is an issue. Any help fixing
> this would be greatly appreciated.
> Matt
> Eclipse 3.4.1
> WTP Windows XP Pro, SP3
Ed Merks
Re: AprLifecycleListener not initializing in Tomcat Startup [message #228787 is a reply to message #228767] |
Wed, 11 March 2009 13:53 |
Originally posted by: dcarver.starstandard.org
Matt:
Check out the WTP Tomcat FAQ, it may have your answer:
http://wiki.eclipse.org/WTP_Tomcat_FAQ
Depending on how you installed your Tomcat instance you can get some
strange errors with WTP's server adaptor.
Dave
>> init
>> it is using:
>> restrictions).
>> Matt
>> Eclipse 3.4.1
Re: AprLifecycleListener not initializing in Tomcat Startup [message #228795 is a reply to message #228787] |
Wed, 11 March 2009 14:43 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
I'm not sure this one covered by the FAQ because it is normal Tomcat
behavior. It occurs outside of Eclipse as well.
The message can be ignored if you aren't trying to use APR (Apache
Portable Runtime). Use of APR is enabled by default in server.xml by
the inclusion of the AprLifecycleListener. If this listener finds the
APR library, plus a couple of other things, use of APR occurs, i.e.
connectors use APR instead of Java equivalents to do the work. If the
APR library isn't found, this fact is logged to inform you that APR
isn't being used. Note that the message is just information, i.e. INFO.
It doesn't qualify as an error or warning.
For APR info, see: http://tomcat.apache.org/tomcat-6.0-doc/apr.html
Larry
David Carver wrote:
> Matt:
> Dave
>>> init
>>> Tomcat it is using:
>>> Properties
>>> the jar file [Source Attachment, Javadoc Location, Native Library
>>> restrictions).
>>> Matt
>>> Eclipse 3.4.1
Current Time: Mon Apr 22 23:08:50 GMT 2024
Powered by FUDForum. Page generated in 0.04274 seconds
